There might be a minute hole in the exhaust due to rust/wear and tear which might be the cause 0f leak.
Got the same welded through dealership at INR 100/-
Sorry to bump in late aakash, missed your thread.Nice crisp and superb long term report of your esteem and congratulations for the same.Can understand your dads attatchment with this car.We had the same with our padmini.
Regarding the exhaust, yes it may have developed the small hole which you can get it examined by uplifting it on the ramp.
Sorry buddy for not buzzed you. I had fixed that broader tires in rear wheels. In fact i had almost spend around Rs.9500 on car lastweek. I had repleced 2 front sturts, steering ball joint, 2 rear brake cylinder and cylinder kit( due to brake cylinder jam & fluid leak).
Tire shop guys filled 33 psi nitragen on all wheels. Car feels more planted on the road especially rear wheels.In front wheels i cant feel the cushion effect and like, pressure is more.
Buddy, i suggest you to replace all your tires to 175/70-13, Which is the stock tire size for your Esteem Vxi. There is huge differnce in ride comfort. May be you are not much experiancing it because your roads are better than here. You just think of the ride comfort of your City in rear seat, which has 175 section tire in rear.
You should take the car to ASS or local workshop for checking and in case it is from a hole due to rust, you can weld it.
Now, One thing that is haunting me,
The place from which I got the engine oil topped up, the owner told that there is "Compression" issue with the engine since the car has run 1.67L km as on date. He said after 1.2L or 1.3L km the car starts to consume engine oil and suggested me to overhaul the head of engine and some parts of pistons.
Listening to this I am in confusion as what to do. I have a few solution which are mentioned below:
1) Engine overhaul for Esteem and after that use my SX4 and Esteem for daily commute. This way Esteem will be run less from now. Discussed on same with dad.
2) Engine overhaul for Esteem and keep it for local running and use Honda and SX4 for long trips.
3) Keep Esteem maintained for another 2 years (Dad won't sell before that even If I jump from the roof) and as a lateral upgrade by Ciaz Zx in end 2015. Till then use SX4 for his commute.
4) I have seen Ciaz, In every respect its way better than Esteem. Dad will not settle for anything else than Ciaz so no point discussing that.
Finally, As discussed with dad, the compression seems to be related to combustion of engine too. So, at present my dad's chauffeur drives at 60-80km so can compression improve if I further reduce driving speed to 50-60km? Can a car with poor compression have any repercussions on highway? What are other apparent symptoms other than engine oil consumption of a poor compression?
