Re: Maruti Suzuki Ciaz: Technical Issues and Solutions
Aditya,
Defoggers only work to remove fogging if it isint instantaneous reformed. Whats happening is you are setting the aircon so cool that the glass surface on the outside is below ambient dew point. Defogger will try to raise this using hot air on the inside but if the glass is too cold, fog will reform immediately. to prevent this, raise your cabin temperature and use the mist system to spray water onto the windscreen. The bottle water is warmer from engine heat and will immediately heat the glass while the wiper clears the liquid
Ameyam
Aditya,
Ameyam
