Barricade - Yamaha FZ-16 (2009) - Midnight Black
Thread Starter #588
deville_56
November 2022 - Updates
Bought Valvoline 4T Premium 20W50. MRP ₹ 523.00, got for ₹ 410.00
The mechanic didn't mention changing oil. Just checked level before (attempting) oil change and it was fresh oil. Possibly MAK 20W40 mineral, which he stocks in barrel. Kept the Valvoline in the shelf for the time being.
Don't know how every mechanic manage to do this [frustration]
Had all them with me.
Straight Screw Plug - 90340-14117 - ₹ 11.00
Straight Screw Plug - 90340-32805 - ₹ 13.00
O-Ring (Big) - 93210-32813₹ - 18.00
O-Ring (Small) - 93210-14899 - ₹ 9.00
Had no tools with me. Borrowed an old chisel from the neighbour. Steel scale was perfect.
Simple unscrew.
Old vs new.
Installed. Why can't an experienced mechanic do the same?
Soot on the plug. Might've happened pre-valve replacement. Installed a less used clean OE NGK plug to check before getting a new plug.
Hit 154k. Took 3 months for the 1000.
Battery band, rusted, but factory stock.
Side panel had cracking. Fixed by the Chinese YouTube fix. Needs replacement.
Washed and lube.
Varanasi
I'm thinking of upgrading to a new bike (will also keep my FZ as primary bike) thinking about new duke 250 or Apache RTR 310 (base model). can you suggest which one is proper and good upgrade from FZ V2?
Thread Starter #590
deville_56
That would be a personal choice. Test drive both and see which one is more comfortable or tastes your taste better. Secondly, check for service quality and parts availability in your location.
Patiala
June 2021 - AIS (Air Induction System) (Repairing and) Cleaning
AIS is one of the most ignored part in the bike (so did I), some end up bypassing it when it starts misfiring. It's a small diaphragmatic valve controlled by intake pressure differences and feed clean air to exhaust port to burn off unburned fuel especially at lower rpms and decelerating. Faulty one would end up acting like an EGR valve feeding exhaust gas into the air filter box and into the intake. Never cleaned in my bike, kept postponing, until a friend asked doubts about cleaning (which I had no clue of).
To start with, it can be accessed by removing the RH tank panel.
Access is hindered in my case with the after-market horn.
Disconnected and removed the horn and found it was secured with the missing engine casing bolt [frustration] @n_g_rjun
The AIS. Has 3 hoses, small one to intake manifold which controls the whole system. Other two goes to air filter box and exhaust port.
Disconnect all of them and remove the 10-mm bolt.
And it will come off.
View attachment 290882 View attachment 290883 View attachment 290885 View attachment 290886 View attachment 290887
Four screws hold them to the clamp as well as secures the cover. Removing them opens up the AIS as well.
Base part where exhaust port connects. Coal-like debris.
Reed valve set up on the top part. Partially blocked with debris as well. Clean these two and you are good to go in normal case,
but on the other side I see an O-ring and a retainer washer. Something is not right.
It was oily all over.
Popped open the side cover and found the air shut off valve fallen off. This might be the reason for untraced oil depletion and/or quick plug darkening, but the reed valve in between made that theory speculative.
Opened the intake manifold-fed side. It's spring-loaded and negative pressure/suction force from intake manifold pulls the diaphragm outwards.
The shaft on the other end is where the fallen valve belongs.
Found the location of the o-ring.
Installed back the valve and secured with the retainer washer.
Normal/open position. Free flow of air to exhaust port.
Shut off position, when activated. This blocks air flow. At higher rpm, suction force will be high at intake manifold, pulling the diaphragm in, shutting off this valve. Pressure will be high at exhaust port too, causing reverse flow into filter box, which is blocked by this valve.
Cleaning up. Reed can be disassembled by removing the bolt.
View attachment 290903 View attachment 290904
Base and rubber lining can be separated and cleaned conveniently.
All cleaned and ready to install.
Reed assembled.
Cleaning the muck on the base.
View attachment 290909 View attachment 290910
Sprayed some throttle-body cleaner and wiped off. Effortless and effective.
Work in progress.
Spring on the diaphragm side.
Assembled and ready to install.
Rubber piping to exhaust port. Cleaned that with diesel and some TB cleaner.
Exhaust port outlet. When disconnected, makes mild FFE/induction-like noise. Commonly seen blocked with bearing balls especially in commuter bikes and Unicorns even by ASC.
Installed and all tubes connected.
This is where the tube connects to the intake manifold.
and where it meets the air filter box. Other tube is for crankcase ventilation. It's been a long since stripped and cleaned the bike. Full of dirt.
New flange bolt for horn/tank mounting.
Thread gone in one of the tank cover nut springs.
The ₹80 Yamaha part I have been saving for years. Heard new ones are cheaper.
Pulsar fairing bolts. Cheap and of good quality.
Checked air filter box for oil and there was just a trace.
All set and done.
Hi brother, I have a Yamaha Fazer v1 the earliest of models, I'm in the process of restoring it after it was abandoned for a few years. The AIS was making tik-tik noise, the moment I removed the ais hose the noise stops. So thought of cleaning it.
Now when I started cleaning it, I forgot to take pictures so that I could properly re-install(saw some yt videos, there the reeds seem to be a little different, perhaps Yamaha changed it). I was confused in the positioning of the reeds(saw your photo, I concur the flat reed would be placed below the curved one which has a rectangular cut). The retainer washer & o ring in my ais was also in the exact same chamber as yours, are you sure it has to placed on the needle, although it makes no sense where I found it?
And such a detailed thread/posts, congratulations & thanks, I'm sure we'll interact now, as I've only started restoring it. My next query would be the Carburettor (single vs dual).
I put the retainer washer different from yours(the bulge is towards the out side). Should I remove & reinstall, the rubber disc although wasn't coming/falling out.
Patiala
Hi brother, I have a Yamaha Fazer v1, the earliest of models, I'm in the process of restoring it after it was abandoned for a few years. The AIS was making tik-tik noise, the moment I removed the ais hose the noise stops. So thought of cleaning it.
Now when I started cleaning it, totally clueless, I forgot to take pictures so that I could properly re-install(saw some yt videos, there the reeds seem to be a little different, perhaps Yamaha changed it with later models). I was confused in the positioning of the reeds(saw your photo, I concur the flat reed would be placed below the curved one which has a rectangular cut). The retainer washer & o ring in my ais was also in the same chamber as yours, are you sure it has to placed on the needle, although it makes no sense where I (or we) found it?
And such a detailed thread/posts, congratulations & thanks, I'm sure we'll interact more, as I've only started restoring it. My next query would be regarding the Carburettor (single vs dual, mine has a single line Carb).
I put the retainer washer in a different position from yours(the bulge is towards the out side). Should I remove & reinstall, the rubber disc although wasn't coming/falling out.
Sorry I don't know how to edit my earlier reply, attaching another photo, depicting that my washer & o ring too were found in the exact(almost) location as yours.
Also after installing the cleaned ais, the tiktok noise is almost gone(about 70%) but still there. Will a faulty Ais affect the bike in any way(it does atleast as per the YT videos, which can't be easily trusted)? PXL_20230930_072435152~2.jpg
Thread Starter #593
deville_56
I believe, it leaves extra room for the valve, causing improper closure. Better get it reversed.
Also after installing the cleaned ais, the tiktok noise is almost gone(about 70%) but still there. Will a faulty Ais affect the bike in any way(it does atleast as per the YT videos, which can't be easily trusted)? View attachment 313952
Misfire might occur.
Patiala
I had never come across a retainer washer, it is placed in the attached picture with the bulge facing outside. I couldn't find any video where the correct placement of the ais(ours is a different, from the videos found on yt) could be seen.
Would you know how to test the ais manually by blowing method? Or otherwise I just might replace it(costs about ₹500).
Thread Starter #595
deville_56
Blow through either of the big inlets to check whether it's closing properly. There shouldn't be any leak.
Patiala
View attachment 313103 View attachment 313104 View attachment 313105 View attachment 313106
Simple unscrew.
Old vs new.
View attachment 313115 View attachment 313116
Washed and lube.
Simple unscrew.
Old vs new.
Washed and lube.
Same issue, with the side panels, what's the Chinese fix? I tried fevi quick but failed miserably.
I'm changing the engine oil tomorrow, have yet to purchase it.
I have a few questions on engine oil, as I would be replacing by myself for the first time, if you may :-
a) What is the manufacturer recommended oil(I couldn't find my manual but I think it was 20w40 & 20w50)?
b) Is yamalube a mineral or semi synthetic? If former, why doesn't Yamaha recommend semi/fully synth oils if they are considered to be better?
c) What is the quantity of oil that is to be put in (with & without oil filter)? And is dripping the filter in oil required/recommended?
Thread Starter #600
deville_56
for a set of two pieces or one?
Single tube.
Replaced soldering iron bit with a star screw and soldered the broken part from behind. Just temporary fix. I might replace sooner or later.
First version had 20W40 per book and the updated version had 20W50. Had option of 15W50 semisynthetic for R15 from dealer itself.
Yamalube for FZ was mineral, Yamalube SL 20W40. Most OEMs opts mineral for cost benefit. As said above, they silently gave an option to use R15 oil, which was semisynthetic. Newer versions from version 2 came with 10W40, mineral for FZ/SZ series and fully synthetic for premium bikes, which the former can opt for without affecting the warranty, and costs just ₹50 more, but sadly not compatible with our version. Initial Yamalubes were all repacked Motul 3000 and 5100 before switching the vendor.
With filter, 1.1 L and without filter, 1 L, but ASC and mechanics pour only a litre with filter change as oil came in 1 L pack. Soaking the filter is recommended per manual and eases up circulation.
