Barricade - Yamaha FZ-16 (2009) - Midnight Black
Thread Starter #646
deville_56
As far as I remember, the last time I swapped the hose, I measured the stock one at 31.5 inches (80cm). I’m guessing the Pulsar hose is 75cm, which is why it’s a tight fit.
So far, the 85cm hose is only available from RCB, but unfortunately, that doesn’t come with rubber grommets. I had a very bad experience buying from Amazon, one seller shipped the wrong size, and the other hasn't shipped yet. Given this, I’m now thinking of buying and importing from AliExpress instead.
View attachment 322076 \
Check in local accessory shops too. I have seen many in Cochin and way cheaper than Amazon, around ₹450 (I got from Amazon for ₹599 then). Same generic hoses. Not sure about length. AliExpress won't deliver to India nowadays. Rarely some seller do, but at high shipping rates and will definitely get caught by customs, who'd slap another 60-70% as duty. Not worth unless shipping to some other country and bringing in person by some acquaintance.
Already tried in Karol Bagh, and none of the shops there have the right length. The only exception is Moto Planet, which has RCB hoses for ₹2,399, but those come without rubber grommets.
Regarding the import, the only option I have is to order them to my client’s address, and he’ll ship them to me. But since the shipping cost is quite high (3k via Aramex), I’ll have to order 5-6 hoses to bring down the average cost.
UPDATE
Finally found right length (80 cm) for just Rs 250 in Karol Bagh. Went there to grab a fork rod T and oil seal driver. On the way back, I saw a superbike mod shop and thought, let’s ask one last time. And the guy straightaway told me not to ask anyone else and pointed me to an unnamed shop in a narrow busy street. To my surprise, that little shop had all kinds of hoses.
Most of the hoses they had were DOT certified, but I’m not sure if that’s the real deal or just for the name.
Thread Starter #649
deville_56
2023 August - Fork Oil Leak
LH fork starts leaking.
Went to Muthoot Yamaha for parts. Their labour ₹ 280 x 2 + tax. Turnaround time a day or two depending on the rush.
Bought the stuff.
Fork Oil - Yamalube - 90793-AD803 - ₹ 188.00 x 2
Recommended 10W. 500 ml bottles. Each fork needs 459 ml.
Fork Dust Seal - 4EB-23144-00 - ₹ 299.00
Bought only one. Only one was damaged, other side replaced not so back.
Like always, Ars-HTA brand. Would be some ₹60-70 in their packing.
Model 7794.
Fork Oil Seal - 2GS-F3145-00 - ₹ 356.00 x 2
Again Ars-HTA.
Model 7705. Only ₹65 in their packing. Yamaha charging 5.5 times the original rate (so do RE).
Special Washer - 20P-F3418-00 - ₹ 11.00
For steering. Damaged by the previous guy.
Race Bearing O-Ring - 90202-26142 - ₹ 2.00
Which the previous guy didn't install despite providing new one.
Took to KR Motors for fork seal replacement. Didn't have the tools, should get them soon. Youtube mechanics showing crude ways without proper tool, which I never would wanna try.
Job done.
This is what he is famous for.
Perfect job.
His best stance.
Thread Starter #650
deville_56
August 2023 - Misc Updates
Grabrail paint gone the Nth time. Needs rust conversion.
Stripped the paint.
And redid.
Ready to install.
Oil level alarmingly low. Something is no right. This was after 1.7k km since last oil change.
Topped up with Yamalube FS. Took 450 ml to the top of the dipstick.
No fouling of the plugs.
Not much blowby in the filter box.
Atrocities of the old school mech. Replaced the caliper bolts with wrong sized ones with a couple of washers.
And abundance of grease everywhere.
Bought a pair of bolts from Yamaha.
Flange Bolt - 90105-10319 - ₹ 40.00 x 2
Original size vs what he had used.
New bolts in.
Chain nearing its end.
Thread Starter #651
deville_56
October 2024 - Throttle Cable Replaced
Throttle was hard and getting stuck. Since there are umpteen iterations of cables, have to note down the part number for the correct part.
Accelerator Cable - 21C-F6311-10 - ₹ 230.00
The ends.
Suprajit make.
The culprit.
Old vs new.
Done.
Thread Starter #652
deville_56
November 2023 - Insurance Renewal
Renewed with Acko
Basic Third Party Premium - ₹ 714.00
Own-Damage Premium - ₹ 300.00 (₹ 150.00)
NCB - 50%
Total Premium including GST (18%) - ₹ 1020.00
Thread Starter #653
deville_56
November 2023 - (Finally) Engine Rebuild
Something wasn't right ever since the drive axle job (aka the messup) by Royal Yamaha. Tried two places to get things right, but some issue remained. Main issue was, in case of a shut down during cold start idle, bike won't start, needs choke and sometime pushing to get it through. Then, this oil depletion. No burning or leak or blowby, but it's disappearing. Found a new garage, Jixie. An "over educated" enthusiastic guy. He did the rebuild, but wasn't satisfied himself and tore down again to find the root cause. It was a bent decompression cam causing the trouble. New one wasn't available at Yamaha. He sourced a used one. Did the job again. Outcome was great. Normally, FZ would take a good 7-10 feet in 2nd gear for a push start. He demonstrated a jerk start in 1st gear. Settings were that perfect. Gave a demo on the run-in process. Also repaired the starter motor, which was overlooked by many over these years. He used modified Pulsar brushes.
Engine on his bench.
He works a single bike a day (or a stretch).
Jixie.
New cylinder kit.
Parts:
Cylinder Kit - ₹ 2,788.00
Timing Chain - ₹ 364.00
Decompression Lever - ₹ 200.00
Exhaust Valve - ₹ 260.00
Gasket Set - ₹ 160.00 x 2
Head O-ring - ₹ 74.00
Valve Stem Seal - ₹ 88.00
Air Filter (Varroc) - ₹ 230.00
Spark Plug (Bosch) - ₹ 130.00
Rocker Arm - ₹ 340.00 x 2
Consumables - ₹ 200.00
Diesel and Petrol (Cleaning) - ₹ 200.00
Petrol - ₹ 200.00
Starter Motor Brush - ₹ 114.00
Sprocket - ₹ 78.00
Labour:
Valve Setting - ₹ 500.00
Engine Parts Water Service - ₹ 100.00
Labour - ₹ 3,000.00
Total - ₹ 9526.00
Thread Starter #654
deville_56
December 2023 - Misc Updates
When you take alternate routes when you can reach home otherwise in 10 minutes [lol]
Visited the spare shop for some Karizma parts and he was sorting FZ parts and saw the wheel hugger. Price was dirt cheap than anticipated. Got one right away. Old one had fading and had striae.
Rear Fender Comp. - 21C-F1650-00 - ₹ 150.00
Needed cleanup before install.
More than anticipated.
Took to the nearby wash.
Cleaning was thorough,
but they missed out the greasy bit. They don't use diesel.
New vs old.
After installation.
Spark plug installed by him. Bosch R6. Not a fan of Bosch plugs. The itch starts for the NGK plug.
Model UR3DC.
Old ebay.in cover used for tool kit.
Night at work.
Thread Starter #655
deville_56
December 2023 - Running In Complete
Took back to Jixie for valve clearance readjustment after break-in.
Oil Change + Valve Clearance Setting - ₹ 500.00
Oil + Filter - ₹ 400.00
Total - ₹ 900.00
Oil was Castrol 20W50 mineral oil. Valvoline 4T Champ 20W40 mineral oil was used during the rebuild.
Thread Starter #656
deville_56
December 2023 - Chain Sprocket Set Replacement (and the associated chain of replacements)
The current chain sprocket set had clocked almost 40k km and started making noise. Always ran on Rolon sets (OE and non-OE). Spent a premium and got the Brass Kit.
Rolon Brass BPR Kit - NXRC 231 - ₹ 1,916.64 (MRP ₹ 2178.00) + ₹ 175.00 Shipping.
Got from SAP Motors, Indore as the kit for FZ-16 version was unavailable with most sellers at that time. Ordered just relying on their Google reviews. They sent it promptly.
The rear sprocket is finished in black and the front is zinc and the highlight of the kit being the brass chain. The inner sprocket is fine blanked and the rear is induction hardened (their own wordings).
Started off. Chain sprocket replacement needs a lot of cleanup and on inspection might end up replacing parts like the swingarm bush and wheel bearings. Most garages would simply ignore even the cleanup part and just go ahead with the kit replacement alone.
Condition of the chain slider rubber. Dirtiest bit.
Damper Clutch aka Cush Rubber - Steelbird RX03 - ₹ 107.00
Rolon Chain Lube - ₹ 160.00
Just to keep the chain clean till the freshness is gone.
The air pressure sticker fell off.
Cleaned up the swingarm.
Swingarm bush and bearing removed.
Rusty, but intact. Initially thought of cleaning and reusing, but my brain won at the spare shop.
Bush stressed on one side.
The oil seal wasn't replaced in over 10 years due to nonavailability. Ars-HTA 7250
Swingarm Bush - 21C-F2184-00 - ₹ 50.00 x 2
Swingarm Bearing - 93317-318Y5 - ₹ 253.00 x 2
NRB DB182416P. Only ₹60 in NRB packing.
Finally got the swingarm oil seal.
Swingarm Oil Seal - 93109-18803 - ₹ 20.00
All swingarm parts together.
Installed the bearing and seal with some anti-seize.
Bush slides in.
Removed the monoshock collar and lubed and reinstalled. Most of the bikes have them seized into the shock absorber due to ignorance.
(To be continued)
Thread Starter #657
deville_56
(continued)
Bought a new chain slider as it was so cheap. They call it the Guard Seal.
Guard Seal - 21C-F2151-00 - ₹ 95.00
Old vs new.
Thrust cover for the swingarm oil seal.
Cleaned it up with TB cleaner.
Installed slider and the cover and completed the swingarm bush part of the job.
Tightened the monoshock.
Back to the original job. Rear sprocket hub.
Replaced the damper clutch.
Wheel bearings. It would be better if replaced with the chain set. One of the root causes for the horrible mileage of FZ's (and others). Due to the heavy wheel, it tends to get damaged and prevents free rotation of the wheel. There won't be any play. It may sometimes sound like a jammed brake, but won't much affect the free rotation of the wheel. So, it will remain unnoticed and everybody complain about the mileage issue.
Collar inside the wheel.
Total of three bearings in total, one for the sprocket hub and two wheel bearings.
Sprocket bearing and its seal.
Just got the sprocket bearing as there was confusion in the model number for the wheel bearing. This time Yamaha OE part will be cheaper.
Sprocket Bearing - SKF 6004-2RS1 - ₹ 230.00 (MRP 315.00)
Old vs new.
Sprocket bearing seal. Didn't get this one also.
Condition of old bearing.
New one.
Without bearing. It can be simply removed by tapping with a socket from behind.
Ready for the sprocket.
Old vs new. The original normal Rolon sprocket is silver-coloured.
Installed.
Cleaned the front sprocket area. Always check for the wear of the sprocket shaft.
Dismantled, cleaned and lubed the rear brake parts.
And reassembled.
Sprocket lock. Forgot to buy one. So reused.
Inner sprocket installed.
Finally, the chain was installed.
Bike with a golden chain.
Bolt for brake pedal (same for gear lever)
Shaft - 21C-F7261-00 - ₹ 120.00
Old vs new.
Brake pedal.
Installed.
All set.
Loving it.
Thread Starter #658
deville_56
December 2023 - Update
Jixie lent his bike temporarily during my rebuild. That time I noticed his rear brake feel was harder and on checking there was a return spring, which was missing in mine. Is it lost or did I forget to install it back, I can't recall.
Tension Spring (Brake Pedal) - 90506-26807 - ₹ 18.00
It's got good tension and was a bit hard to install.
Installed. The hole under my pedal is elongated. So, I assume it fell off.
Thread Starter #659
deville_56
December 2023 - New Brake Caliper
I was about to overhaul my caliper and had the idea of painting it bronze/titanium finish. Then had rethought. It's been almost 15 years and over 1.6L km and why not replace it. Called up Muthoot Yamaha and they had ready stock, both black and gold.
Muthoot Yamaha, the best place for sourcing Yamaha OE parts in Trivandrum (but their service is a gamble, but the better one of all).
Caliper Assembly Gold/Yellow - 5US-F580U-00 - ₹ 1,675.00
Expected it to be a premium gold like the Nissin unit, but it turned out to be **** gold.
Drained the brake fluid for the swap.
Tweaked a bit. Sanded off the Bybre. Looks better now.
Gold vs black. The old caliper was in good condition, except the visual part. Had bought all the parts for repair including the pads. Sold it off in Olx.
Came with pads as to be expected.
This was how the retaining spring was supposed to fit. I have been installing them the wrong way (as did most mechanics I met).
The expensive Yamaha Brake Fluid. I always tell myself not to buy this one, but end up doing so. DOT4 and made in Japan and you can get half a litre from other brands for this price.
Brake Fluid - Yamalube BF-4 (100 ml) - ₹ 200.00
Cleaned the MC. Plugged the hose and bled. All done in a go, thanks to the steel braided hose.
Now, The bike with a golden chain and a golden caliper.
Thread Starter #660
deville_56
February 2024 - Clutch Push Lever Oil Leak
Oil was seeping through the push lever. The oil seal was blown. Initially, I thought it was some lubrication done by him during the rebuild, but then it was flooding all over.
Push Lever Oil Seal - 93102-12877 - ₹ 12.00
The part itself was very cheap. He shouldn't have overlooked it during the rebuild.
Again, HTA make.
Bought the push lever also. It came as a kit bundled with the return spring. Anyways have to remove it to fix the seal and the existing one is already rusted/showing age.
Push Lever Assembly Kit - 21C-WE630-00₹ - 143.00
Return Spring - 45P-16345-00
Made in Japan.
Clutch case gasket.
From the kit I had in my parts bin.
Bought Motul 5100 15W50 SS from Amazon as it was listed dirt cheap, selling price of ₹ 372.00 as opposed to MRP of ₹ 645.00.
Plus ₹30 cash back, instantly credited to the account.
Oil Filter from the parts bin. Last piece of OE filter I'm gonna be using. Available in OEM packing at half the price.
Oil Filter - 21C-E3440-01 - ₹80
Trialed Ronin mirrors bought for PowerPig! Looks good. Bucket listed.
Sunday morning at Jixie, waiting for him to turn up. He works on Sundays and late nights on request. One of the reasons why I'm preferring him despite the remote location and the distance.
The clutch needs to be released to free up the lever. Doesn't pop up like KTM/Bajaj.
Lever and seal out.
I pulled out the oil strainer while he was working on this side. Shocked to see it has never been cleaned by anyone who worked on the bike to date and it was shut closed with concrete-like sludge. Couldn't click the strainer as he was already working on it to clean the mess. It took some effort to clean it up. Yamaha recommends cleaning it every 16k km.
Installed everything back. The spring and lever designs have changed, so it won't fit in the old slot.
Foam washed on the way back.
A polythene cover came flying on the way back and melted on to the exhaust pipe [clown]
Back home.
Cleaned the burnt cover.
With Skids.
Signs of worn dust seal. Water was getting inside the fork. The clip was all rusted.
Muck inside the fuel tap bowl.
