Tata Tiago XZ 1.2 (P) Sunburst Orange: 24K Kms & Counting
Re: My Fantastico: Tata Tiago XZ 1.2 (P) Sunburst Orange
Fuel Filler Pipe Updation @ 6790 kms - Prerana Kudlu Gate:
After the recent 2nd service, the fuel filler pipe assy was not in stock.
Incidentally after the recent cleaning during service the seat belt locking mechanism were not found to be seen at the rear seats.
Last Friday went for this updation programme, though the part was available since Monday (same week).
Reported the vehicle at 11:15 am got the vehicle post lunch at 2:30 pm.
Earlier version was made with plastic.
Complete Metallic (Now)
Neatly tucked in - joining the earlier plastic part neatly.
Something mysterious was reported by SA, though i had not mentioned about engine overheating or anything of that sort.
Seat belt thingy... Found a method where the rear seats can be easily detached.
Issue resolved.
My car is November manufactured and it already comes with the metallic fuel filler assy.
Thread Starter #62
Good to hear that.
Infact I had reported this issue to the design team of Tiago earlier in July.
To which they had acknowledged it through a regional CRM.
They are proactively working on the feedback. Good to see this.
My CRM told me that initial batches would get the latest updations that occurs on the latest batches.
I will again pass the feedback to them during monsoons, in case muck accumulates again.
Thread Starter #63
Update @ 8500 kms:
My Tiago completed 8500+ kms in 8.5 months.
The car is running fine for now, except for the one incident described below.
8000 kms
8500 kms
Issue Faced:
Some where in the mid January faced the strange issue of varying idling sound from the exhaust. As if engine was losing its breath. This happened when the car was not used for a day and when it was cold.
As soon as i cranked the car, engine would lose its breath.
Link:
https://youtu.be/mc20EG15YOI
Issue Faced:
Link:
I have noticed this too, when not driven for two or more days. Close to 11K on the ODO, May 2016 made.
Prabagar did this happen when the car was new or after sometime ?
Mukesh did you show this to tass? If yes what did they say ?
@ahc,
It started during winter. Car was delivered in June. I didn't even talk about this to TASC as it appeared to go away within few seconds.
@ahc,
Started mine after two days of idle time. You may need headphones to note the abnormal engine note from 00:25 onward:
https://www.youtube.com/watch?v=jl1D_UCPNAk
And this is my buddy's Tiago, delivered around same month as mine. You can clearly notice it from 00:30 at the exhaust tip:
https://www.youtube.com/watch?v=p2JOfRyIUAI
By the way, it took a solid 2 minutes to warm up and settle down at 850RPM when started after a week's time.
Thread Starter #68
I forwarded the video of issue to Dy-CRM of Prerana Motors.
He told me to rev hard so that ECU is cleared of errors.
He told me, if that issue recurrs again, then they can look into it. They also had to say, these errors are logged into the ECU.
It was a one off incident, as the car was not used for around 2 and half days.
@Prabhagar: I had faced the issue of car not able to maintain its idling. As soon as it was cranked, the engine was shutting off.
To this CRM told me to rev hard. Then in the evening when I turned on this varying idling sound started, as similar to your friends case.
Thread Starter #69
Hey guys just saw the push notification of TMSC for Summer Camp for Tiago.
Earlier this week completed 9000 kms and counting.
Thread Starter #71
Tata Summer Camp Update on 25th March 2017.
9250 kms - Checkup
This was a much required visit to the A.S.S.
I reached the dealership around 9.45 am. And reported my issues to the SA.
By the time they acknowledged it was 11 am.
I had listed few issues to be sorted out.
  • To check DTC for any errors.
  • Harman music (err Sistam) system software update.
  • AC cooling ineffective.
  • Clutch pedal hard in crawling traffic.
  • Vehicle was jerking (err Jarking) in the 1st gear with less pull, in crawling traffic. - They checked the spark plug adjustment.
  • Handbrake Tightening - As vehicle was moving even after 4 clicks.
  • Vehicle Pulling to the left.
SA listed the issues in his own language. [lol]
The mechanical works like clutch freeplay adjustment, Handbrake tightening was done.
Then the car was lying with the electrician for Software update and ECU DTC clearing.
They flashed the software. While the updates were carried out, i was near the vehicle.
Somehow i missed the Harman update.
The AC gas was then recharged and checked for leaks, there was a minor leak that was arrested by re-tightening the inlet valves.
There was a loss of 120 gms of R134a refrigerant out of the standard 600+/- 20 gms limit.
This was done.
And then the real waiting starts to get my car into the wheel alignment bay.
I was standing in the workshop floor, asking my SA to get my car on the alignment bay. The guy took the car to the alignment bay, without even connecting the required equipments, he manually checked camber, caster toe settings.
Within 2-3 mins he reversed my car and said alignment was done.
I was pretty sure that it would not solve my issue.
The SA was adamant that he would verify during TD.
This is the only issue left now.
Will be visiting a Tyre Professional outlet this weekend, to get the 3D alignment and rotation. Car is nearing 94xx kms.
By the time the car was cleaned it was around 5.45 pm.
AC gas topup for the third time
Recovery of gas
Recharging with 600 gms ideal condition. There was a loss of 120 gms of R134a refrigerant.
Clearing DTC errors from the ECU.
Other day had reported engine dying, as soon as it was cranked. And later that evening there was variable exhaust note as if a diesel engine clatter.
They re-adjusted the spark plug gap.
Finally in the washing bay around 4.30 pm
The washing boys speed up the work, if the owners are waiting near washing area.
Other Tiagos in the bay waiting for bath[lol]
XZ with Bridgestone Tyres in the latest variants.
Tiago flexing it's muscles
The cleaning guys deserve a pat on their back. They did an awsome job.
Absolutely nothing to complain about.
At 6 PM i was out from the dealership.
Overal Rating of this visit:
9/10 - One less as the alignment issue was not solved.
Thread Starter #72
10,000 kms Update:
Hey guys my Tiago completed the 10,000 kms (yesterday) in 10 months.
Last month got the wheel alignment done at Tyre Professionals, as the vehicle was pulling to left.
2 Months ago a tyre had 2 nails lodged into it. So swapped it with the Stepney tyre, and now all the 5 tyres have been rotated at 9500 kms. The old tyre was removed and new tyre was re-fitted to alloy.
So i have a new left rear tyre.
Alignment, Balancing, and Tyre rotation (With Sticker weights and Nitrogen) costed me - 1121/-
A few concerns i noted in the last few weeks.
  • The wiper sprayer both front and rear are not throwing enough water on windshield.
    Noticed this in the recent rains in summer, the throw of water spray was missing.
    The motor works but less throw.
  • Recently did a trip on highway, the disc brakes kind of gives a jarring feeling.
    When on a third gear and approaching a hump. That can be felt by the co-driver too.
  • At times on a gradient, the car makes a juddering when clutch is released. Temporarily feels like there is no power on slopes.
  • iPhone SE disconnects and connects frequently from Harman System. Not sure if its an issue with recent iOS 10.3 update or Harman update.
To be contd..
10k kms in 10 month is a pretty good usage. I am disappointed to see that tata service centers are still the same haven't changed a bit. Mud in fuel filler area & irregular idling are things no one expects from new car. I see from your posts that you do stay with ur car at service, probably that's the best thing to do. As they have already shown during the oil change (extra .5 ltrs) how careful they are with customers new cars.
Congrats on reaching 5 digits on the ODO. [thumbsup]
[*]The wiper sprayer both front and rear are not throwing enough water on windshield.
Tried adjusting the spray throw nozzle? I raised the throw level this morning and set it to a comfortable level now.
Before:
https://www.youtube.com/watch?v=_ONHc71LSw0
After:
https://www.youtube.com/watch?v=b_uNHDHecrA
Thread Starter #75
Contd... From the other day.
Tyre Rotation @ Tyre Professionals
Got the 5 tyre rotation along with the 3D wheel alignment from Hunter.
As one tyre was facing frequent puncture and on one instance found a single tyre had two nails lodged into it.
Since the vehicle was pulling to left thought it to be a right occasion for tyre swap with Stepney.
My Advice: If you love your car tyres get the alignment done outside, at a reputed Wheel alignment center.
So till now the Tiago's tyre have been rotated twice.
Tiago Suspended on air
Stepney New Tyre swapped with Alloy.
Old tyre swapped with Steel wheel
Breakup of Wheel Alignment and Rotation
The rubber giving away on the brake pedal displaying the metal beneath. Quality of rubber[thumbsdown]
Since all the issues were resolved, i wanted to do a short trip.
It was time to hit highway.
Visited a temple on Mysore highway.
