rg27,
Thanks for the super pics.
From my experience, your High beam & Low beam pattern is really perfect!
For your doubt about high beam, we need to study how human brain reacts to light.
Cree H4 lamp uses 2 LEDs for low beam, and adds one more for high beam. The High beam LED adds some Height to the beam pattern as well as distance which can be clearly seen from your image.
Now, as your brain is seeing really bright, Awesome, super-duper low beam spread close by, it feels that the light at the distance is somewhat weaker than expected. Thats the reason High end vehicles use Foreground limiters in their HID projector setups! Your high beam is really fine.
Other difference is how Traditional H4 Bulbs work. When you Engage high beam, the low beam Filament is TURNED OFF. So your brain can only focus at the distance. The Shilan Cree Bulb is designed to keep Low+High LEDs ON at the same time
. I really appreciate this effect on indian roads to spot potholes, Dividers etc.
Else, don't let the driver dangle around somewhere. Tie it up with a zip tie. or atleast tape it. The Banging driver will destroy itself on bad roads.
headlight indicator may not work as the current drawn by LED bulb is quite less. Its not enough to signal the indicator.
manish12345,
The LED you selected is not good. LED chip is too wide and Brand (chip) is definitely not cree. Better to stick with Proper HID Kit. I have used h8 HID for my XUV here-
http://www.theautomotiveindia.com/f...-hid-kit-technical-review-install-w-pics.html
if you want LED, try this-
https://www.aliexpress.com/item/2xH..._6&btsid=c25a5660-914c-4a04-9383-27bf7ff9ab28
