Note for mods: What's wrong if we have a limit of 4 smileys per post? At least for longer posts it's needed
We DTS-i riders do suffer with a disease called awesomeness!!
Since you have already spent on the rims, so I won't ask you to spend much(you can do if you wish to). Enkei alloys are good and I'd recommend you to for for 195 section rubber but with a higher profile.
195/65 R15 will be good and please don't go for 195/60 R15 as in your case it will be a wider tire on a narrower rim. S**t!! What's the remedy then? Eh, simple - profile is the key to success(be it proposing a girl or putting the larger thing(tire) in a smaller place(rim)
). so what we need here is the tires with higher side profile.
Result: Tires with higher profile will be better(65 profile I mean).
Why so?? Lower the profile, more will be the effect on side walls.
Explanation: Naa, because I don't want to open Catia now and do some 3D designing to show it to you.
Because they are the best, but they come at a cost; which good thing do come at low cost BTW(Exception: Used Skoda Laura TSi
Sirji I beg to differ. Why? Let these pictures explain(only from official sites of BS(eh, that's bridgestone, not bullshit..err..then where is bullshit? Its what I am writing
) and Michelin India):
WHAT CODE SAYS: Catia was tougher but MS paint did it in 5 mins.. this is what code says(the case with rim narrower than the tire):
Wow. So young but full of knowledge and experience. I really appreciate you bro.
Thanks for your awesome guide. It helped me too. My car tyres life is coming to end and I need to change them soon. Stock tyres are Michelin Energy XM1 sized 175/65 R15 and wheels are Enkei alloys sized 15" X 5.5".
I have done research about new 3ST tyres from Michelin and found something special about it. I also expected that you'll recommend it and it did happen.
195/60 R15 is available in Michelin Primacy 3ST but not in Bridgestone Turanza ER300 so if DR. wants to opt Bridgestone Turanza ER300 then he has to get new set of wheels too (6" width). I agree about your 2cm explanation though.
