Re: Restoration of Maruti 800 1991 (Tonnes of Pics Uploaded)
Thanks Varun, I will place JCB work lamps pretty soon there.
A Major update:
The gearbox in my car is nearing its end of life, a loud humming noise (which always existed) has now turned into a vibrating grinding noise. Drive shafts are fine, gear oil topped up recently, clutch bearing although aged, the mechanic confirmed the gear rings are over stressed and only solution is to change the GB itself.
Thanks to Jarpickle, I got a mint condition speedo from a type 2 car. Yet to fix it as wiring is different for instrument cluster in 800 type1 and type 2.
Also the rotor inside the distributor was almost dead and missing in higher rpms hence changed that yesterday with a new rotor from TVS = 160/-
Change of rotor should partially solve the problem I had with the car (unable to cross 90kmph).
All future plans paused (except speedo) till I get the gb replaced. I have to look for a used one (preferaby from type 2/3car) from scrapyard and buy it. Only issue is no sure way of checking the age of a GB, I might end up getting another humming, whining GB. The car is surely a hummer now
![Cry [cry] [cry]](https://www.theautomotiveindia.com/forums/images/smilies/Cry.gif)
