Thank you sir,
Regarding the voltage, I'll soon upgrade my alty. And I'll not use all the lights together.
Now regarding your fog lights. (sorry for the late reply)
First of all these thing would be required
I saw a spark bumper, there are 3 mounting holes to attach the lights using screws. As you can see in the image the lamps have 3 mounting brackets which are fixed to the bumper.
As you can see in the above pics. The local make fog lights can be easily opened by unscrewing the nut
(as pointed by arrow). When you will open the lamp you will find a H3 bulb, a lens and a reflector. You will have to check for the mounting holes in the bumper and according to it drill holes in the lamp's outer cover.
You will have to fabricate few clamps to hold the lights to the bumper.
This is the wiring diagram for fog lights
White driving lights are better than yellow ones if using the local made ones. (As local made lamps do not use good yellow lenses)
Estimated cost for this DIY:
Fog lamp pair 150/-
Clamp(fabricated) 100/-
Relay 100/-
Wires 100/-
Switch 20/-
20amp fuse 20/-
metal clips 10/-
total 500/-
