Re: Fuel Efficiency Figures of Your Cars
My daily run varies from 40-60kms and i am sticking to mineral oil as you have suggested
Thanks Jarpickle.
Also I have checked air pressure on all four tires now. Maruthi says to fill front tires with 36 psi and rears with 33 psi. Stick to manufacturer recommendations as i didn't do initially and it affected the FE and ride. Now everything is fine
Sankar
If you want the exact run in period you should contact the manufacturer.Most cars, diesel and petrol alike need to be run in for 1000-2000kms.
Why do you want to go for synthetic?Do you do 100kms per day?If yes, then switch to synthetic.
If not stay with mineral oil.Change every 5000kms.
Thanks Jarpickle.
Sankar
