Hi buddy, I'm sorry if you felt bad.
In my last post I have clearly mentioned that, if you really care about the initial micro dust particles of a brand you car, then you should follow a 50kms and 1000kms oil change(It was not a joke). Since the first few hours of the working has the greatest wear and tear.
I will choose the second car because of the reason that I heard about, "Oil Volatility". (Yet to confirm, still learning about it)
Oil volatility is at its greatest in the first 3000km after an oil change. After that the volatility reduces and the oil stabilises. Volatility of mineral oil is higher compared to semi synthetic and synthetic oils. These vapors exit though the PVC value and enters to the inlet manifold where it can coat the inlet valves and combustion chambers in gunk. Those vapors can also reduce the life of the cat.
Reason as said above.
My questions are
* How did you get this 5k limit in against to the 10k ? Why not 2.5k or 3k for the oil change interval?
* Suppose your car is recommended to change its oil by 5k kms by the manufacturer. In this case, at what kms will you change your oil? Is it 2.5k? Asking you since, most of the old technology engines had 5k kms as the oil change interval.
Even I will recommend to change at 5k or even less in against to 10k kms, if and only if the owner abuses his engine well.
If the purpose of being enthusiastic is to give more life to the engine, then instead of going for the frequent oil changes its much better to go for even more thicker oil.
*Frequent oil changes reduces the dust particles inside the engine.
*Where as thicker grade engine oil reduces the wear and tear.
So being an enthusiast, which one is good for your engine's life, 0w-20 or 0w-40 and why you are still using 0w-20?
Does that mean Innova which follows 10k kms of oil change will not last this much? I have seen lots of innova taxis over here which has completed more than 2 and 3lac kms, and they are still healthy without having any drop in performances or mileage.
Lets do some calc
According to this 5k rule, this owner did a total of 90 times of oil changes(450000/5000). If it was done @ 10,000kms it will be just 45 oil changes. So here they did an extra of 45 oil changes..
Oil and oil filter will roughly cost approx Rs.2250/-
Ie Rs.2250 x 45 = Rs.1,01,250/-
What did they actually save?
IMO, If they have invested this each Rs2250/- in bank, then after few years it would have became even more better figure. Which will be very much helpful for an enthusiast to do the required engine overhaul(If needed) and to do all kinds of silly modifications and accessories that he likes to do in his car.![Clap [clap] [clap]](https://www.theautomotiveindia.com/forums/images/smilies/Clap.gif)
Any day, an overhauled engine is much better than an untouched engine which had done more than 4.5 lac kms. Am I right?![Evil [evil] [evil]](https://www.theautomotiveindia.com/forums/images/smilies/Evil.gif)
Dont consider it as an argument, we are here just to share our ideas and experience which will be helpful for us and for the readers. ;)
Regards.,
You have a point here
Let me give a scenario here.
Consider two identical cars driven identically and used identically.
One car follows manufacturer recommended service.
Another car
Changes mineral oil and filter every 5k kms ,
Ie insted of spending 3500 for semi synthetic every 10k , spending 1050 every 5k.
And second car follows all same service schedule as per manufacture recommended.
Which car do you think last longer? Ie after 1.5~2l kms ?
Another car
Its our car, we are auto enthusiastic guys, we care our cars, why do we hesitate to oil change oil every 5k kms? .
My questions are
I have seen a innova run 4.5l kms ,stilll running in good condition, they say they change oil and filter blindly every 5k kms.
Lets do some calc
![Surprise [surprise] [surprise]](https://www.theautomotiveindia.com/forums/images/smilies/Surprise.gif)
I am not blindly saying this concept, after seeing many cars i came to this concept.
Anyway i have nothing to prove here,bro
Lets hope for the best
Regards.,
