Maruti Suzuki Swift: Technical Issues & Solutions
Vishnu,
It depends on how you drive. In lots of stop-go traffic in the city, mine give 11kmpl. A small highway run bumps that to 13. Purely highway running returns upto 21 on my vxi
With regards to filter cleaning, the MASS will check & do it if its required
Ameyam
Thread Starter #216
palwal
when going to agra i got 24.9 and on way back to home got 19.6
Is that the MID values or the values you got from tank to tank fill calculation?
it was mid value but its not accurate tank to tank is accurate and before going to agra i filled full tank and it has clocked like 360kms. fuel indicator is still more than half lets see how many more kms. does it clock untill fuel reserve light comes up
Trivandrum , Sydney
Recently did a 120 km trip , with gear shifts in rpm range- 2-4,and speed at 100-120 and dropping while camera approaches to 60.
Got mileage in MID as 13.8.
Today drove another 120 with shifts in rpm- 2-3,top speed 80,cruising speeds mostly,mileage as per MID-16.9.
Vishnu,
The more you cruise in 5th, the better the mileage you will get. The real fun in that car is how quickly you get to 5th
Ameyam
Trivandrum , Sydney
Yes Mr.Ameyam
I wanted to test its power as road was not that great i could go a max of 100-120.In kerala,the roads are narrower in highways.
I will see its real action only when i take my beast to Chennai .Last time in my cousin's Scala i had taken it upto 140 kmph,after that vehicle was vibrating.(steering feedback uninspiring from 70 kmph)
In my beast even in >100 kmph,i had confidence with its steering feedback,only problem was with ABS-Not upto mark,better than normal Maruti brakes,not like Renault,Ford or hyundai's.
Vishnu,
Cruising in 5th is 60kmph+ with constant pressure on accelerator. Try it. All vibrations will disappear & it will drive very softly. Drivivg beyond 100 is possible but quite dangerous if not on the expressways. These cars are optimised for max efficiency between 70 & 100
Ameyam
Thread Starter #221
palwal
Yes Mr.Ameyam
i would not push my baby that hard
Trivandrum , Sydney
Subjecting to higher rpm's after first service will don't harm the car Mr.Tushar.
I have tuned most of my relatives rides the same way,and all are running smooth.
No issues till now in any of them.[:)]
Trivandrum , Sydney
How to check engine oil level in new swift with dipstick?
I will try posting photos within a few days.Normally dipsticks have a rod portion and a flat end,within which max and min are provided.
In new swift its not like that,its completely flat thing.
