Maruti Suzuki Swift: Technical Issues & Solutions
There is (atleast one) counter there that gives you instantaneous FE. It has no real relevance
Wet or cold, no microfiber for dusting of external surface dust. You will just grind it into the paint if you map it. The correct technique is to pat the surface with the cloth so that the cloth picks up the dust particles and there is no relative movement between the two. Obviously no one will take that much pains to do it. Simply use a static brush- it will pick up most of the dust- sufficient for day to day driving
Ameyam
Thread Starter #197
palwal
i drive my car once in 4days.now the thing is i see a new scatch line on my front windshield everytime.really frustating
Wierd. You do often get scratches on the body work but not usually on the windscreen. Are you parking under a tree or something?. If so, invest in a good car cover
Ameyam
Thread Starter #200
palwal
it is common to those who park there car out side of there house [cry] like me
Ameyam
but it seems these lines are user-created atleast think so but do not know
Query- my car has the MGA cabin filter but I do see some surface dust a lot of the time. Checked the filter slot and it fi5s loosely.Read somewhere that the Bosch cabin filter is better. Is this the case and where can I get it.
Ameyam
Thread Starter #203
palwal
Ameyam
i do have fitted on first service but if i run the blower to max it emits dust i dd not know why
Thread Starter #204
palwal
the slot is seperate from the hu i charged my phone and worked but does it damage my phone?
Hi Stingray,
it will charge but at a very slow rate. I have done it too. Also I don't know how it affects the HU.
Getting a fast charger that plugs into the 12V power socket is better
Ameyam
