@shri,
I assume you are using the zeta / alpha petrol.
In the city you wont notice discernable pull. Also, you wont find the rear bouncy if you have 5 persons in. Tell us once you have driven the highway
Most of my bouncy feel is in the Zeta & Alpha. Delta will likely have a lesser issue due to the higher sidewall. To be fair, i need to take the car out onto the expressway again to check the improvement. My experience with bouncy rides was when the car had done under 300km and its currently at 1800km
Regarding the stalling, i didnt feel it till about a week into ownership. Also, if you are setting the aircon low i.e. less than 24 deg, you wont feel it as much. I tend to set a higher temperature & want more air flow so may be its particularly affecting me. Once it gets hotter outside, this should go away.
Still need to resolve why my car jerks a bit when releasing clutch in any gear. Somewhat like releasing into 2nd at 25. That is surely a clutch setting issue & i need to get that done properly
With aircon set the way i described (fan one notch higher) all my other problems including a lower pickup seem to be less evident.
Ameyam
Ameyam
Till now most of the time v had four passengers inside and on highway v were two where i noticed steering issue which I mentioned earlier.
Well I need to take it for long drive next weekend and will see the response.
