Maruti 800: Technical Issues & Solutions
Bhopal
Re: Maruti 800: Technical Issues and Solutions
and varun sir do you know something about HERO HONDA KARIZMA? or any technical zone for KARIZMA technical help?
May be its leaking some where.. check near the break booster too.
Are the breaks effective.?
Last time I checked, the brake fluid reservoir was almost empty. I’m checking it now almost regularly and it seems that the car is really consuming the brake fluid fast.
delhi
There was ac problem in my 4 yr old maruti AC.
it was never serviced earlier.
Driver got it repaired. Total damages - 3700 [cry]
1) Gas filled
2) service
3) Pipes changed where gas was leaking.
He has given warranty of this season in case anything goes wrong
Bhopal
Everybody know's that rainy season is coming. so if someday raining and in between a running car stops on the road. so what will be cause for the stopped car and what to check and without mechanic how can I Start my car? Car is maruti 800
Bhopal
Good morning members. My friends maruti 800 97 model. she's facing some problem with her car that is when she drives the car it runs nicely but when she push break so it starts wobbling badly. it happens only when she push breaks. me also drove that car it seems like both front wheels will come out from the car
Kandy, Sri Lanka
Maruti 800 Leaf Spring Rear Suspension
My Maruti 800 right rear suspension leaf spring had been replaced with a new one which seems different from the left one.
The old leaf spring has a varying thickness (Thicker at the middle) but the new one has constant thickness throughout.
Can someone post a picture / drawing of the correct leaf spring of Maruti 800????
Re: Maruti 800 Leaf Spring Rear Suspension
May you have got an after market leafs !! So how does the ride / handling feel now.
Has the car bent to one side (check when parked on a flat surface) ?
Kandy, Sri Lanka
Car is now out of balance.I feel the difference. One of the technician says the coil springs in front also not similar. I need replace both coil springs as well.
Re: My Modified Maruti 800.
i wonder how alto has same displacement engine 796cc as M 800 but has a better A/C
any ideas how to get same effect of A/C in an M 800
I love my M 800 but still unsure how to get A/c effective
I got a standard M 800 back in 2000 and got it fitted from outside
it worked ok in the evenings but negative in day heat of delhi
I have a CNG installed now as well so unsure if I should still get A/c serviced and use it
any modifications which can be done to get A/c effective in it
