Maruti 800: Technical Issues & Solutions
delhi
Re: Maruti 800: Technical Issues and Solutions
No he said smell is not of petrol buy ac gas leakage . AC mechanic said gas was leaking due to overheating.
My car is quickly consuming brake fluid ever since the rear wheel cylinder was replaced. Is it normal. If not, what could be the issue?
May be its leaking some where.. check near the break booster too.
Are the breaks effective.?
Yes, the brakes are working fine. There was no leakage last time when I inspected. I shall check it again this evening.
Bhopal
HI good morning friends
I have maruti 800 1997 model AC.
but its AC's not working. I want to know how much cost would be come to start AC of my car and when I start my car some vibration sound comes from engine's a black round shape part ( i don't knw the actual name of that part) it seems like its loose or any bolt fall . i attached a picture of that. that part (like a round black plate)
That is called as air filter may its nut is not fitted properly.
For A/c failure there are many components, just check for electrical connections and then the A/C gas..
Bhopal
Thank you so much for the advise [:)]
1 more problem I am facing with my M-800. that is when I start my car... every time self's not starting properly. when I turn the key first it stuck than starts properly. some time starts normally but some time creates same problem.mechanic's garage is too far from my house so he's making excuses for not coming than I told him the problem on phone. he's not sure what's the actual problem? he said "you have to give it to car electrician for self servicing" now I am confuse what's the actual problem..problem with self or wiring.. my battery is NEW. will mechanic solve the problem or electrician. please tell me anything by which i can check the problem so after that I will call mechanic or electrician. [confused]
Bhopal
Dear old members. I am new here today I joined this. I have 1 opel astra 1.6 model too. the pictures is showing in my avatar. I need some technical help for that also. can you please tell me any link or any community from where I can get help.
Get the self motor serviced also check if the key set is worn out it might also cause the same problem.
Just start a new thread, http://www.theautomotiveindia.com/forums/newthread.php?do=newthread&f=14
