no you again got me on the wrong side.
No actually I dint , but if you felt so iam sorry .
what i was mentioning is.
XUV was perceived to be vehicle filled with so called "chinese" items in it.
I don't think the xuv has Chinese items in it per say , but since cheap Chinese items are related with unreliabilty and flashy things people used their imagination and perceived it so .
hence they could pack in those many features at that cost compromising in its reliability. some even called it an undercooked/untested vehicle.
True and I think mahindra themselves believe too , or else their was no point in saying " now our car comes with zero defect "
http://www.hindustantimes.com/Autos...ahindra-XUV500-improved/Article1-1110708.aspx
The braking system, for example, has been completely re-engineered to essentially counter the complaint about noisy brakes. M&M has upgraded the whole brake system with better quality brake pads that improve feel and don't groan when used constantly.
M&M has also worked with clutch supplier Valeo to improve the reliability of the oil seals and improve clutch operation. However, this is one area where M&M still needs to work on as clutch operation is still not as progressive as we would have liked and you have to concentrate to engage the clutch smoothly. Also, the gearshift still feels notchy especially when selecting second gear. Plus, there’s still a fair amount of torque steer under hard acceleration which tugs at the steering wheel. This is hard to eradicate thanks to the unduly high half shaft angles
so when the same problems arises with the premium brands in that case range rover. can then the range rover be called an undercooked/unreliable vehicle filled with "chinese " items?
What do you think and believe ? Does range rover comes with Chinese items in it and is half cooked vehicle just because salman khans range rover had a break down ?
You are talking about one isolated example of a range rover and comparing it to a car which had niggles from day one in most of the cars sold in initial batches .
But Now answer this question we have issues sometimes with tata manza or a vista or a safari right ? why we have issues ? General complaint is maybe tata uses inferior components and even bad engineering of the car .
Now read this -->
Queen goes for a stroll after her Bentley breaks down | UK | News | Daily Express
Seconds later, the Queen climbed into the back of her police back-up Range Rover and sped onto her final engagement at Tower Bridge.
"It's clearly unfortunate but these things happen, even to Bentleys," a Buckingham Palace spokesman said. "We're not sure what went wrong with it. We'll get it back to the garage and let the mechanics have a look at it.
What do you think is Bentley also using cheap components in their cars or is Bentley also making cars which are badly engineered ?
One Range Rover having brake problem,can not be equated with plethora of XUVs having brake problem.
+100.
