Happened to check creta yesterday.
For me, 180cm tall,on driver seat, the ingress is not easy, the steering wheel obstructs the thighs while getting in, especially if the steering wheel adjustment is low set. If the steering wheel is set at up level, it is not easy to use it as the right elbow can't be rested on the door elbow rest. Also, egress is difficult for same reasons.
So what you need to do for easy ingress & egress is that the seat is pushed all the way back, and the steering wheel is set at up position. But while beginning to drive, you need to extend the & stretch the leg too much so as to reach the pedals,and invariably you land up pulling the seat forward so as to be comfortable while riving.
But if the seat is pulled forward so as to make the legs reaching the pedals easy & steering wheel set low so as to make the right elbow comfortable for steering manuvours, at the end of drive when you get down the left thigh is obstructed by the steering wheel, and you can't get down unless the steering wheel is set at up level & seat pulled back completely.
Now changing the seat position & the steering wheel position every time you get in /get out & start driving , its a boring experience for a car which costs you a premium is lamentable.
Also rear seat underthigh support is pathetic, especially when the front seat is pulled back near fully, as you can't stretch the leg their by creating a huge gap between thigh and the front edge of the rear seat.
When the front seat is fully pushed forward, you get a chance to stretch the legs fully from the rear seat but then the width of the seating area seems too short.
