All
Taking my Grand (Petrol) for its second service on coming Monday. Have a few things to get sorted -
1. 'TAK' sound from clutch.
It's normal with all Grand i10 and xcent whether you notice or not, I verified with Garve Hyundai ,Pune and they confirmed.
2. A little thud noise from rear left suspension on rough patches.
Rear Suspension quite soft, you can't do much about it, this is also normal and common with Grand i10
3. Heavy steering wheel (Changed tyres from 165/65/R14 to 185/65/R14). Not very happy with the added weight on tight parking space and city driving conditions, though steering feels planted on high speed. Read somewhere that service center folks can do some belt adjustments to make it lighter/heavier? Experts - Please comment.
You can ask for adjustment, but it will be little to help with upgraded tyres, as you chose the highest possible size for Grand i10
4. Tyre rotation and alignment.
Must do, In Indian road condition it;s recommended every 5K KMs.
5. Intermittent 'Hissing' noise from engine. Has anyone faced it? Any solution?
Can you elaborate in detail, if that is while changing gears only, again I will say it;s common with all Grandi10, this car is very particular about the RPM on which gears should be shifted (1100 to downshift and 1900 to upshift), if you change below / above this range multiple sounds you will hear from front. it's nothing related to engine the drive train / gear box and clutch assembly requires perfect gear shift, it;s tedious although.
6. Steering vibrations when the engine fan is on.
should be cautiously examined
7. Engine Oil - I'm thinking to get my own synthetic oil and get it changed at HASS. Spoke with the SA and they don't have any issue with it. Experts - Which grade/temperature range/type etc..? Please advise.
I would suggest stick to semi-synthetic if at all you dislike mineral, Synthetic oil is more useful where temperature plays below 1 degree and exceeds 50 degree at times, Shift to semi synthetic and then 3rd servicing you may choose pure synthetic oil. prepare your engine to digest it happily.
Thanks in advance..
All the best!!
Thanks in advance..[/QUOTE]
All the best!!
