Got Wet in the Rain of Fluidics - Hyundai Verna Ownership Review
Thread Starter #316
MH 01 / MH 43
i haven't seemed to understand the thing about the mid as yet. I fill up on palm beach bpcl. When i drive either to vashi or my place it skyrockets up to 16/17 but then when i come to the croma signal it crashes down to 9km/l finally settles out at 12 or something. But after filling the tank it changes fast either goes up or down but after some km it stays at one point and takes time to go up or fall.
Now a days I have started using that instant fe display which shows the amount of fuel used while accelerating. After that there are serious changes in my driving style. The mid is cnstantly showing fe between 15-15.3. I am expecting atleast a km rise in my overall fe, fingers crossed.
Mumbai MH01/MH46
Re: Got Wet in the Rain of Fluidics!!!
its not possible to paste your eyes on that display. mine drops to 0 when accelerating gently or hard and stays at 12 while steady
Nick - I guess this should be because the avg FE is calculated as (distance travelled)/(fuel consumed). During the first few kms after the fill, the numerator is pretty less - so whatever fuel that is consumed will cause the avg to change drastically. Once a few kms is done after the fill, the numerator and denominator settles down with bigger numbers. So that is when we get the actual Avg FE.
Thread Starter #319
MH 01 / MH 43
Had gone to MODI Hyundai Chunabhatti leat week to get the extended warranty for the car. Since they were newly opened; and I was the first one to get the extended warranty; they didnt had the documents ready for the same. They asked for a couple of days time so that they can get the documents and the booklet from their head office.
Nwayz in the mean time came across this link regarding the extended waranty of Fluidic Verna Diesel.
:: Hyundai Motor Company ::
Extended Warranty
Hyundai Motor India Limited hereinafter called "HMIL" warrants that under the Extended Warranty Scheme, HMIL undertakes to carry out the necessary remedial work necessitated by any mechanical and / or electrical break down, under normal use and maintenance, subject to the following terms and conditions.
Note
* This extended warranty is transferable to subsequent owner for the remaining warranty period.
* This extended warranty scheme has no surrender value, no refund of warranty premium is available and it cannot be transferred to another vehicle.
What is Covered?
Except as provided under What is not Covered hereof, if any defect confirmed by HMIL as Mechanical and/or Electrical break down as defined in this warranty, is found in the vehicle within the stipulated terms and conditions, HMIL dealer shall repair or if required, replace any part found to be defective with a new part or an equivalent at no cost to the owner for parts or labor.
What is not covered?
This warranty shall not apply to:
* Normal maintenance services including without limitation, cleaning & polishing, injector cleaning, engine decarburizing, engine tuning, oil/fluid changes, filters replenishment, fastener retightening, adjustments of doors, brake and clutch, wheel balancing, wheel alignment, tyre rotation, head lamp alignment.
* Replacement of parts as a result of normal wear and tear, such as spark plugs, belts, brake pads and brake shoes, brake discs, clutch disc/pressure plate, filters, wiper blades, bulbs, fuses, brushes, hoses, tyre / tube, battery, audio system, catalytic converter, silencer / exhaust pipe.
* Tie Rod ends, Steering Ball Joints, Rear Shockers, Front Struts, Dicky lifters,Front & Rear Wheel Bearings/wheel hubs are not covered beyond 60,000 kms of operation
* Rubber parts like Wheel Cylinder kit,all doors weather-strips/beadings & A/C "O " rings.
* Clutch cable, Accelator cable, Speedometer cable & Dicky Opener cable.
* If model equipped with Hyundai Genuine LPG Kit,following parts Rubber pad, Hose adaptor ( Inlet & Outlet), Gasket, Tube, Band cable, Holder tube, Vaporizer to mixer hose(fuel), Vaporizer Cover hose(air), Strap, Water Hose Assy(In & Out) , First diaphragm assy, relief diaphragm, first valve assy, O-rings set will not be covered.
* Vehicles fitted with non-genuine LPG/CNG kits are not applicable for extended warranty.
* Leakage of A/C refrigerant.
* Normal aging, deterioration or rusting of plated parts, paint coat, rubber parts, upholstery and soft trim, etc.
* Body, paint, glass, interior / exterior trim, exhaust systems and normal wear and tear of any other component.
* Damage or failure resulting from:
o Negligence in getting the vehicle serviced within the stipulated kilometers and time period as recommended in Owner's Manual and Service Booklet.
o Misuse, abuse (such as racing, overloading, riding over the clutch), accident or collision, theft, flooding or fire.
o Use of improper, adulterated or insufficient fuel, fluids or lubricants.
o Use of parts other than Hyundai Genuine Parts.
o Any device and/or accessories not supplied or not approved by HMIL.
o Modifications, alterations, tampering or improper repair.
o Parts used in applications for which they were not designed or not approved by HMIL.
o Any repair carried out other than by Hyundai Authorized Dealer / Service Centre.
o Slight irregularities not recognized as affecting quality or function of the vehicle or parts, such as slight noise or vibrations, or items considered characteristic of the vehicle.
o Airborne fallout, Industrial fallout, acid rain, hail and wind storms, or other Acts of God.
o Paint scratches, dents or similar paint or body damage.
o Revolution or Mutiny, any intentional or malafide act of owner or a driver, abuse of the vehicle, negligence
o Action of road elements (sand, gravel, dust or road debris) which results in stone chipping of paint / glass or damage to any other part.
* The vehicle which has been used for any sort of competition, sport and rally, transport for hire of persons or goods, Taxi service or short or long term self drive hire or driving school or any commercial use.
* Any vehicle purchased as a taxi under the special excise concessions or/and registered as a Tourist taxi with the Transport authorities.
* The vehicle in which the odometer has been tampered with, changed or been disconnected.
* Incidental or consequential damages, including without limitation, loss of time, inconvenience, loss of use of vehicle or commercial loss.
* No liability will be accepted for any losses covered under an accidental damage or road risk policy or for any road hazard/fire or accident damage, no liability of any kind exists in respect of third party.
* No liability will be accepted for damage caused by neglect, intrusion of foreign or harmful or injurious matter, lack of servicing, over heating, freezing or abuse to the continued use of the vehicle after a fault has become evident or for consequential loss on the failure of parts not covered by this Extended Warranty.
This warranty is the entire warranty given by HMIL and no dealer or its or his agent or employee is authorized to extend or enlarge this warranty and no dealer or its or his agent or employee is authorized to make any oral warranty on HMIL's behalf.
HMIL reserves the right to make any change in design or make any improvement on the vehicle at any time without any obligation to make the same change on vehicles previously sold.
Warranty service shall be provided only by HMIL's authorized dealers and Dealer Service Branch.
HMIL's decision is final and binding on the Owner of the vehicle in all warranty matters. HMIL reserves the right for the final decision on all warranty matters.
So what exactly is left in the Extended warranty period?[lol]
Mumbai MH01/MH46
thats what i was saying, lots of stuff not included.
the catalytic convert has 3 years warranty i suppose wonder why their not including it here.
Suspensions are only covered for 60k km? or the whole 2 years unlimited km? I'm confused.
the only thing i guess which is covered is alternator, ac compressor, engine, radiator fan motor, abs, air bags, transmission, starter motor. Seems worth the cost?
Thread Starter #321
MH 01 / MH 43
Will be opting this in a week's time.
Nways heres the latest odo click.[:D]
And the FE is the same 12.5-13kmpl![frustration]
diesel guys are getting just 12-13 , so how can i expect petrol verna to give 12 [sad]
anyways i'm out of delhi , away from the car. so it will be parked for more then 10 days. hope there is no scratch on return.
Thread Starter #323
MH 01 / MH 43
Yeah; 12-13kmpl is the actual fe i am getting from the tank full to tankfull method, though the obd shows between 14-15 and sometimes it crosses 17 too. People say the fe will increase by a couple of kms after the 10k km service which inludes the oil change and all.
Nwayz I hope you have covered the car before leaving it unless there is someone else as maniac as us who will be taking care of her.
Mumbai MH01/MH46
my cars past 10k km theres no difference though.
The only increase in fe i got was when i changed the oil at 5000km.
it was around 3-4km/l increase.
However i feel with the verna my driving style has improved in the fuel economy department. Due to the fe indicator I've been constaly working on that finding the right efficient rpm range.
Thread Starter #325
MH 01 / MH 43
Me too have started driving with that instant fe indicator; that horizontal brick game like indicator. I have reduced the use of accelerator and have now started keeping the car in the required gears. Earlier i use to shift gears soon because i thought higher the gears more the fe. But no its is not like that. That indicator changed my perception. Now it is like: less the accelerator more the fe i feel.
Mumbai MH01/MH46
yeah thats the thing you press it little more and the fe drops down. I only follow extreme economy driving during early morning and late nigh cruses otherwise i drive normally with moderate throttle
Mumbai MH01/MH46
gears i checked with him for the bridgestones he told me it should be around 8000-9000 per tire but prices keep changing, theres a bridgestone shop just ahead of palm beach galleria opposite indian oil, its owned by a sardarji he's pretty nice he was offering my the potenzas last year it was abit more then the yokohamas, this person as well told me the b250 are utter disgust many guys have torn their sidewalls. However he was telling me to go for 205/55/16.
Someone told me these potenzas last really long.
Thread Starter #328
MH 01 / MH 43
Thanks a lot bro. Atleast now I got a rough idea how much I will have to save.[glasses]
Nways the stock tyres are crap. You take the car over some water(the ones which is collected next to the footpath) and you will loose the control. Also I have started seeing cuts in the threads. I mean they are so cheap.
Also; I had Potenza GIII's in my DZire; (from 45k kms till car was sold at 76k kms)believe me even after 30k kms those were strong and the wear was not that much. Except few punctures. And they looked awesome.
BTW the car is nearing 5k kms. Should I do the tyre rotation or at 10k?
Mumbai MH01/MH46
my car doesnt loose control luckily, but the water splashes on the windscreen somehow. Do the rotation at 10k. I did a wheel alignment today after 2000km i posted details of it on my thread. Btw what do you mean cuts in the thread? can you post pictures? if the cuts are on the front then do a rotation, a few guys told me that on the verna the alignment keeps going out so tires can wear sooner, even the tires look tilted. ive had turanzas on my aveo they were silent and good but grip wasnt great. they lasted 45k then i changed to good year nct5 their to noisy, developed a bulge twice once bursted.
Thread Starter #330
MH 01 / MH 43
Yeah I read it in your thread.
Well the cut is in the front tyre on the thread. I think I ran over some glass (bottle) and it entered the thread tearing it; thankfully did not reached the tyre surface and did not puntured it. Will try to find out the cut again and post a pic if possible.[roll]
