Re: “Thunderbolt” Mahindra XUV5OO Detailed Review (4 Years Report)
Let me add my part in spoiling the party guys, and all of you can fire cannon balls at me, I have just put on my helmet.
Sir the XUV (FWD) was a revelation
It wasn't, farmers do more off roading in their Alto during harvesting of sugarcane or wheat. Any front wheel drive car which has enough GC, can do this much or even more off roading. Dare I say, I did more than this in a Tata Tiago diesel and it was fun too. Technique and momentum matters more than anything else. You may be knowing the Chilla road of Haridwar, I crossed around 1.5 feet deep water there (The surface under the water matters for even 600 mm depth), driven in sand and gravel, and have a pic of raised rear wheel too - like the one BHVM has shared with a pic highlighting it as 'wow'. All in a Tata Tiago with that puny 1.05l diesel engine.
Just to add, the river crossing was a walk in the park for the Pajero Sport Automatic which is a 2 wheel drive with lesser torque. Indeed, the capabilities of the Pajero Sport show it's Dakar lineage time and again.
That said, the surface was tractable, BHVM needed to dare it. If the surface under the water was having enough of the grip compromising ingredients, then Pajero Sport AT would have been doing it with a rope attached to a 4x4 outside. No offenses, but Dakar lineage has some standard, that doesn't come into play for such chindi tasks.
These days I am seeing off road experts
I have seen Bahubali part 2 yesterday, I guess I am turning into a warrior. You may have seen many roadside ads of doctors, they are mostly because of teenagers 'seeing' a lot and not trying the real thing.
Hence, get your planned 4x4 and go out to try it out.
Another advantage is ATs won't clip engine when using brake, you can focus on driving and stop fumbling with gears. It could be possible AT was a better choice for river crossing than MT.
MTs' also don't clip the engine, it's the driver who does. No matter it's the AT or MT, carrying right amount of momentum and right technique is the key.
The river crossing we did, was a matter of water wading depth and wheel articulation/GC rather than any issues with torque or traction. Even something like Safari/Sumo/Bolero 2WD would've done it the same way as Pajero 2WD.
This is the key statement.
Things like Safari/Pajero/ Scorpio will struggle with diagonal wheels in air (Or Gumbo Mud)
Drive something with a locker some day. Put XUV in AWD and a Pajero with a locker in 2H, then see which goes farther.
Where did AG mention anything about an AT Vs MT? All he said was a 2WD AT Pajero too was able to clear the crossing due to its attributes. What attributes? Read on.
What attributes? Surface under the water and a better water wading depth - no other attribute.
Since you mentioned it, let me say this. "Fumbling with the gears??" While the debate between an MT Vs an AT offroad is never ending, no experienced MT driver "fumbles" with gears. In fact an experienced AT driver would choose the gear the vehicle stays in while crossing any obstacle using the AT box. Lastly, the precision that the clutch-brake-gear-accelerator combo offers in offroad situations is something die-hard offroaders swear by.
He is absolutely right.
Which is always better in a full blown BOF SUV vs a crossover/softroader.
Articulation - depends on suspension setup, no hard and fast rule that only BOF will be better.
Water wading depth - let me give it to the snorkel
Had that been the case, Cos like ARB, Eaton and others whose mainstay is their diff lock offerings, would have run out of business. Look up the vehicles they install their diff locks on and you will know.OEMs like Toyota, Ford and Mistubishi would not have offered factory fitted diff locks if the mentioned gadgetry could have even come close to what diff locks and a low ratio can achieve.
Indeed, no matter what - a locker is a locker. Electronic diff lock!! And Electronics are never as reliable as solid and honest mechanicals.
AWD SUVs like the Endy, Range Rover and the LC would not have had a 4L mode apart from the usual electronics.
This picture shows a 1900 kilos D-Max V Cross with 3 on board pulling a Thar with 2 on board, in off road situation. First gear in 4L and no accelerator input. We cross inclines, ruts and what not. If it was an XUV AWD, I would have had to keep slipping the clutch for entire 0.4 kms until we hit the tarmac. And after this, the D-Max kept pulling Thar on the broken tarmac, over speed breakers, one flyover and a populous area too, all in 4L in second gear, without any clutch slipping and accelerator input too while passing over speed breakers etc. 4L mode is something that no electronics can ever compromise.
All other things equal nothing beats a low ratio gearbox offroad and that is a well established fact.
+100, give this man a medal.
The Paris Dakar is the World's toughest rally my friend, please do not demean it by comparing it to anything else, except prolly the Borneo/Camel.
Indeed, and the above said trail is absolutely nothing to write about the capabilities and durability of a Pajero.
