Over 40,000 BMW X3s recalled due to door lock issue
The recall includes 2022-2024 BMW X3 sDrive30i (rear-wheel drive) and xDrive30i (all-wheel drive models). The rear door-lock mechanisms in these vehicles could both unlock and unlatch the doors with one motion, rather than separately as stipulated by Federal Motor Vehicle Safety Standard (FMVSS) number 206, according to the NHTSA.
The relevant standard calls for doors to unlock via a dedicated mechanism, and unlatch when the occupant pulls the door handle. If both actions occur simply by unlocking the door, it could open inadvertently, presenting an increased safety risk to rear-seat occupants.
BMW told the NHTSA that this problem was discovered during internal testing, and that it isn't aware of any related warranty claims, accidents, or injuries.
Dealers will replace the rear door lock modules on affected vehicles free of charge. Any related work conducted prior to the recall would still be covered by warranty, so BMW does not anticipate having to reimburse customers for out of pocket expenses in this case.
TheCarconnection
Ineos recalls 7K Grenadiers because the Doors could randomly open
Ineos is recalling 7022 Grenadier models because a faulty button mechanism in the door handle could result in the doors randomly swinging open. According to recall documents submitted to the National Highway Traffic Safety Administration (NHTSA), the issue traces back to the affected models' production, where the door-button mechanism was built using an insufficient amount of grease.
The lack of grease on the mechanism means that the exterior door buttons may remain in the depressed position, keeping them from fully latching and leading to the doors opening accidentally. The recall documents explain that the driver and passengers will receive multiple warnings if the doors are not fully latched. For starters, NHTSA says the sound of the door closing will be different. The depressed latch will also be visible. Lastly, if the car moves while the doors are unlatched, a visual warning will appear on the dash and be followed by audible alerts.
Documents associated with the recall show that Ineos will replace the complete door-button assemblies of affected vehicles for free. The updated components reportedly use improved guidance mechanisms and a revised grease application process.
Dealers have already been notified of the recall, and Ineos plans to mail owner-notification letters between March 31 and May 4. Owners concerned their Grenadier may be included in the recall can find out on the NHTSA site.
caranddriver
90,000 Camaros and Cadillacs have front wheels that might Lock-Up
A General Motors 10-speed transmission recall involves more than 90,000 of these vehicles because the front wheels can lockup while driving.
  • 2019-2020 Cadillac CT6
  • 2020-2021 Cadillac CT4
  • 2020-2021 Cadillac CT5
  • 2020-2022 Chevrolet Camaro
GM says the 10-speed transmission control valve may suffer from excess wear over time and cause a loss of pressure within the valve. The result is harsh shifting, and in "rare cases" the front wheels can experience a "momentary" lockup which occurs in a downshift from eighth gear.
GM dealers will install new transmission control module software that will monitor transmission valve performance and detect excess wear about 10,000 miles before a wheel lockup could occur.
If a problem occurs, the transmission will be limited to fifth gear which will prevent the possibility of a wheel lockup. Additionally, a driver will see a service engine light and reduced propulsion message in the instrument panel
GM 10-speed transmission recall letters are expected to be mailed April 21, 2025. Cadillac owners may call 800-333-4223 and Chevrolet customers can call 800-222-1020. GM's 10-speed transmission recall number is N242480630.
carcomplaints
Land Rover Range Rovers recalled for seat belt Buckles
Land Rover has recalled its 2025 Range Rover and Range Rover Sport vehicles because of problems with the seat belt buckles. More than 7,200 Land Rovers need their center seat belt buckles and buckle retaining bolts replaced.
The Range Rovers and Range Rover Sports are currently equipped with second-row center seat belt buckles that may not latch correctly. This can leave an occupant unprotected in a crash.
Engineers determined the second-row center seat belt buckles may have been manufactured out of specification because one of the jigs used at the buckle supplier did not secure the buckle’s internal cable in the correct location during a riveting process.
Land Rover is not aware of any crash or injury reports relating to the seat belt buckle problems. Land Rover seat belt buckle recall letters should be mailed May 2, 2025, then dealerships will replace the components.
Land Rover Range Rover and Range Rover Sport owners may contact Land Rover at 800-637-6837 and ask about seat belt buckle recall number N989.
carcomplaints
GM recalls 90K Chevy Camaros, Cadillac Sedans over faulty transmissions
General Motors has recalled 90,081 examples of the Chevrolet Camaro and the Cadillac CT4, CT5, and CT6 sedans equipped with the 10-speed automatic transmission. Documents associated with the recall explain that models with other transmissions are not included in the recall population. The recall documents show that the recall extends to the 2020–2021 CT4 and CT5 models, the 2019–2020 CT6, and the 2020–2022 Camaro lineup.
Documents submitted to NHTSA explain that a transmission control valve is to blame for the defect. The documents also state that the valve is liable to excess wear over time, resulting in a fluid leak, a drop in pressure, and subsequently harsh shifting. In one instance, the recall notes that an all-wheel-drive 2021 Cadillac CT5 experienced a momentary front-wheel lockup. A GM spokesperson told Car and Driver that the rear wheels can also lock up on affected models.
Dealers have already been notified of the issue and the fix, with GM planning to alert owners in mid-April. Anyone concerned their car might be part of the recall population can check using their vehicle's VIN on the NHTSA website.
carandriver
Ford re-recalls over 50,000 vehicles including Explorer, Lincoln, Edge models and more
Ford Motor Company is re-recalling more than 50,000 vehicles for camera, battery and window issues that were incorrectly repaired as part of prior recalls, according to multiple National Highway Traffic Safety Administration (NHTSA) notices.
Four separate recall notices reported to the NHTSA on March 13 include 64,531 cars across seven models and four model years, including Explorer, Edge, Lincoln, Bronco Maverick, F-250 and F-350 vehicles.
In two cases, failure of the vehicles' rearview cameras may cause blank or distorted images to appear, limiting the ability of drivers to utilize the backup feature and increasing crash risk.
In another, a failing module may neglect to inform drivers of a low battery, increasing the risk of a sudden loss of power. In the fourth and smallest recall, which concerns only nine cars, the front driver and passenger windows may fail to automatically retract when they encounter an obstacle (such as a finger or hand), increasing the risk of injury.
Usatoday
Tesla Cybertruck's latest recall involves Body part that could fly off
The Tesla Cybertruck is an unmistakable stainless-steel-bodied electric pickup truck, but one of those stainless-steel body parts is susceptible to flying off, based on a recent recall. As a result, Tesla is recalling roughly 46K—or virtually all—Cybetrucks from the 2024 and 2025 model years.
The recall involves an exterior trim piece called the cant rail, which is joined together with the truck's steel structure with an adhesive that's prone to "environmental embrittlement," according to a recall report that Tesla submitted to NHTSA earlier this week. The report goes on to say that the Cybertruck's stainless-steel body panel can delaminate and separate from the rest of the vehicle, possibly landing on the road and creating a hazard for other drivers.
The affected Cybertrucks were built between November 13, 2023, and February 27, 2025. Owners should be able to notice a delaminated cant rail because it'll either be obviously coming loose from the truck's body or it can create a noise while inside the truck.
Tesla says it will replace the cant rail for free under warranty. The new body part will not only use a different adhesive that Tesla says isn't susceptible to the same embrittlement issues, but it will also be secured with a stud welded to the structure and a nut to clamp the stainless-steel trim piece. The company says the procedure will also apply to Cybertrucks built around March 21, 2025, as well as retrofitted to models still in its possession before they're delivered to customers.
According to the NHTSA report, Tesla first learned about the issue back in January, which led to inspections and pull tests that the company said revealed no signs of separation. However, in February, NHTSA notified Tesla that owners had made claims about detached cant rails, which were further identified through service records and posts on social media.
caranddriver
Hyundai recalls Ioniq 5 N due to faulty Left-Foot braking feature
The Hyundai Ioniq 5 N is a performance-focused EV SUV with a bag of tricks that includes simulated engine noises and fake gearshifts. However, one of its unique settings is now causing problems. As a result, Hyundai is recalling 1508 examples of the 2025 Ioniq 5 N due to a software issue related to its Left-Foot Braking (LFB) feature, which can negatively affect its stopping ability, according to a recall report Hyundai submitted earlier this month to NHTSA.
The recall covers Ioniq 5 Ns built between December 18, 2023, and December 10, 2024. The Ioniq 5 N's LFB feature allows the driver to simultaneously use the accelerator and brake pedal for track driving, a function derived from motorsports. However, according to the NHTSA documents, when LFB is engaged, certain driving situations can cause the Integrated Electronic Brake (IEB) control software to trigger the depressurization of the anti-lock brakes. This can cause reduced braking performance and lead to longer stopping distances.
Hyundai first became aware of this problem when a corporate fleet vehicle crashed in June 2024 while practicing for a race event with LFB engaged, per another NHTSA document. Hyundai recreated the issue in testing and discovered the software failure by early November. The documents state that only one crash has been associated with the issue and no fires or fatalities have been reported.
Hyundai says owners should refrain from using the Left-Foot Braking feature until the recall has been completed. The company has revised the IEB and vehicle control unit software logic to limit the risk of ABS depressurization while using LFB, and owners of affected vehicles will need to bring their Ioniq 5 N to a Hyundai dealership to receive the software update free of charge. Owners will be notified if their vehicle is affected by April 7, 2025. The reworked software was implemented into the production line on January 15, 2025.
caranddriver
Volvo 48-Volt battery recall issued over Fire risk
Volvo 48-volt battery fires could occur in about 8,000 of these recalled plug-in hybrid vehicles that should not be charged until repaired.
  • 2020-2021 Volvo S90
  • 2020-2022 Volvo S60
  • 2020-2022 Volvo V60
  • 2020-2022 Volvo XC60
  • 2020-2022 Volvo XC90
  • 2022 Volvo V90
It seems automakers cannot build hybrid or electric vehicles without high voltage batteries that catch fire. And as in battery recalls from other manufacturers, Volvo says the 48V battery can suffer a thermal event when the battery is fully charged and the vehicle parked.
Volvo received the first LG 48-volt battery "thermal event" report February 6, but Volvo has no reports of overheated 48V batteries while driving, and is unaware of any crash or injury reports.
The faulty LG high voltage batteries were produced between June 3, 2019, to November 30, 2021. Volvo expects to mail 48-volt battery recall letters May 15, 2025, and dealers will replace the high voltage battery modules if necessary. Dealers will also update diagnostic software to monitor the batteries.
With questions or concerns about the Volvo battery recall, call 800-458-1552. Volvo's battery recall number is R10312.
carcomplaints
Ford cracked Fuel Injector recall issued for third time
A Ford cracked fuel injector recall has been issued for the third time for Ford Escapes and Ford Bronco Sports.
As in the previous recalls, a fuel injector can crack and leak fuel inside the engine compartment and cause a fire, this time in more than 40,000 recalled vehicles.
The recalled 2020-2022 Ford Escape and 2021-2023 Ford Bronco Sport vehicles were not repaired correctly in the previous two recalls.
A Ford cracked fuel injector recall was announced in November 2022 for about 636,000 Bronco Sports and Escapes in the U.S. and Canada. This was followed by a Ford cracked fuel injector recall in April 2024 for 2022-2023 Ford Bronco Sport and 2022 Ford Escape SUVs equipped with 1.5L engines.
The fuel injectors can still crack and leak fuel, and fuel or even fuel vapor near an ignition source can cause a fire. Ford knows of four engine compartment fires in the recalled vehicles but engineers haven't confirmed cracked fuel injectors caused the fires.
Ford cracked fuel injector recall letters will be mailed April 24, 2025, and dealers will update the powertrain control module (PCM) software.
Ford Bronco Sport and Escape owners may call 866-436-7332 and ask about Ford cracked fuel injector recall number 25S21.
carcomplaints
Nissan Pathfinder Hood recall
A Nissan Pathfinder hood recall is finally beginning nearly three years after the recall was announced. The Pathfinder hood recall was first announced in June 2022 for nearly 360,000 model year 2013-2016 Nissan Pathfinders in the U.S. and Canada.
Nissan owners complain their Pathfinder hoods opened while driving, a problem blamed on dust and dirt contamination around the bell crank lever pivot joints.
The Pathfinder owner's manual instructs owners to inspect and maintain the secondary latch release lever, but the lack of maintenance combined with a buildup of dirt can cause the latch to remain in the open position after it has been disengaged.
Nissan also says contamination can scratch the protective anti-corrosion coating on the secondary latch, allowing corrosion of the bare metal in the pivot joint.
A Nissan Pathfinder driver may see the hood flutter or hear noise before it flies open. The hood recall involves 2013-2016 Nissan Pathfinders built from June 20, 2012, to July 27, 2016.
Pathfinder owners have been mailed interim recall letters since June 2022 reminding them about maintenance of the hood latch components and letting owners know they will be contacted when Nissan dealers are ready to repair the Pathfinder hoods.
It's taken nearly three years for Nissan to collect the necessary Pathfinder hood replacement parts, but dealerships are finally ready to make repairs. This recall supersedes all previous Nissan Pathfinder hood recall information.
Owners of 2013-2016 Nissan Pathfinders may call 800-867-7669 and ask about hood recall number R24C6.
carcomplaints
Nissan recalls certain 2025 Kicks vehicles over Technicality
A 2025 Nissan Kicks recall includes 37,000 SUVs at risk of being overloaded due to incorrect weight labels.
Nissan says the 2025 Kicks certification labels may have been printed with the wrong gross vehicle weight rating (GVWR) and gross axle weight rating (GAWR) values. Following the current label may cause a driver to overload the vehicle beyond the recommended weight ratings.
The problem was discovered in November 2024 when an engineer saw problems with the info on a 2025 Nissan Kicks weight certification label. An investigation showed the weight limit discrepancies were caused by human error.
Nissan investigated whether any other vehicles had been built with the inaccurate labels and found none, other than 46,514 model year 2025 Kicks SUVs that received the incorrect certification labels. Of these, 37,003 vehicles had been shipped to the U.S.
The SUVs were built from June 24, 2024, through January 10, 2025, at an assembly plant in Mexico.
Nissan Kicks owners will receive by mail replacement certification labels, or dealers can install the new labels if necessary. Owners of 2025 Nissan Kicks should watch for recall letters after May 12, 2025.
carcomplaints
Volkswagen recalls nearly 50,000 Audi cars due to Safety concerns
Volkswagen Group of America has issued a recall for 44,387 Audi models that were manufactured in 2021.
The recall is a result of a software error that occurred due to an aging flex-foil cable. This software error can cause display failure in the instrument panel. Without a properly functioning instrument panel, drivers may lose access to warning lights, speed and gear indicators, the speedometer, mileage, and more.
Per the report, Audi received 2,285 customer complaints regarding the issue as of March 24, 2025. However, no incidents, such as crashes or injuries, were reported.
The following Audi models are listed in the recall:
  • 2021 Audi A6
  • 2021 Audi A6 Allroad
  • 2021 Audi A7
  • 2021 Audi A8
  • 2021 Audi Q7
  • 2021 Audi Q8
  • 2021 Audi RS 6 Avant
  • 2021 Audi RS 7
  • 2021 Audi RS Q8
  • 2021 Audi S6
  • 2021 Audi S7
  • 2021 Audi S8
  • 2021 Audi SQ7
  • 2021 Audi SQ8
If you believe your car is affected by this recall, you can contact customer service at 1-800-253-2834. The recall number is 90VC.
AOL.com
