Land Rover recalls Range Rovers over Suspension dangers
Nearly 17,000 Land Rover Range Rovers are recalled because the front suspension upper knuckle joints may crack and cause the suspension arms to detach. The recalled 2014-2016 Range Rovers can suffer steering and stability problems if the suspension arms detach.
A problem occurred in 2019 when a Range Rover suffered from a front suspension knuckle failure at low speed. More incidents occurred and Transport Canada contacted Land Rover because of similar reports in Canada.Engineers determined the use of road salt significantly contributes to knuckle failures.
Land Rover is aware of 12 claims in the past nine years, but no reports of crashes or injuries. Land Rover dealers will inspect the front suspension knuckles and install retaining brackets, or possibly replace the knuckles.
Owner recall letters are expected to be mailed January 3, 2025, but Range Rover owners with questions may call 800-637-6837. Land Rover's number for this recall is N759.
Carcomplaints
200,000 Honda Pilot and Passport SUVs recalled for fuel leak issue
In documents filed with the National Highway Traffic Safety Administration (NHTSA), Honda has announced it's recalling 205,760 of its Pilot and Passport SUVs to fix a problem that could cause fuel leakage. The problem, which Honda describes as lack of "fuel system integrity," affects vehicles built between February 14, 2023, and May 8, 2024.
The recall report explains that the SUVs manufactured during that time may have an incomplete connection between the fuel filler pipe and neck tube, meaning they could separate in the event of a crash and potentially leak fuel. Honda blames "an out-of-sequence process" during the assembly's installation process, which has since been corrected, and says only about 1 percent of the recalled vehicles are expected to have the problem.
Honda said it has received only one warranty claim and no reports of injuries as a result of the problem. Recall notices will be mailed to owners on January 6, 2025, and the issue will be repaired free of charge. In the meantime, owners who want to find out if their vehicle is affected can check the NHTSA recalls site or Honda's own recalls website.
Caranddriver
Ram recalls 317,000 HD Pickups for ABS failure amid surge of Brake problems
A Ram hydraulic control unit (HCU) recall involves more than 317,000 trucks with anti-lock brake systems (ABS), electronic stability control (ESC) systems and traction control systems that may fail.
The Ram HCU recall includes these trucks:
  • 2017-2018 Ram 2500 Pickup
  • 2017-2018 Ram 3500 Pickup
  • 2017-2018 Ram 3500 Chassis Cab
  • 2017-2018 Ram 4500
  • 2017-2018 Ram 5500 Chassis Cab
The National Highway Traffic Safety Administration opened a federal Ram truck braking investigation in November 2022 following problems with the hydraulic control units and anti-lock brake systems. Chrysler was asked to provide information about 2017-2018 Ram 2500 and 3500 trucks.
Then in October 2024, Fiat Chrysler opened its own investigation into 2017-2018 Ram 2500, 3500, 4500 and 5500 trucks built with hydraulic control unit anti-lock brake systems that were failing.
"As of November 18, 2024, FCA US is aware of 4,622 customer assistance records, 53,448 warranty claims, and 1,460 field reports potentially relating to this issue for all markets with dates of receipt ranging from November 1, 2016, to March 5, 2024." — FCA
A Ram driver will see a warning light if the ABS motor fails.
FCA will mail Ram HCU recall letters January 9, 2025, and dealers will replace the brake hydraulic control units.
Ram truck owners may contact FCA at 800-853-1403 and ask about Ram HCU recall number C4B.
carcomplaints
Tire company recalling more than half a million tires for lacking snow traction
A global tire company that sells replacement winter tires is recalling more than 541,000 of them in the U.S. because they don't have enough snow traction to meet North American standards.
Prinx Chengshan Tire North America, a subsidiary of the international Chengshan Group Co., Ltd., is recalling more than 100 sizes of Fortune Tormenta and Prinx Hicountry tires. The tires have three-peak mountain snowflake symbols on the sidewalls, according to the National Highway Traffic Safety Administration (NHTSA).
The company says in documents posted Tuesday by the NHTSA that the tires passed European tests but likely would not meet traction standards in North America.
The safety agency says tires without sufficient snow traction can increase the risk of a crash.
Prinx Chengshan is working on a way to fix the problem. Owners will be notified by letter starting Feb. 1. Those with questions can call the company at 310-205-8355, extension 109.
nbclosangeles
Tesla recalls nearly 700,000 vehicles over tire pressure light issue
Tesla has issued a recall for nearly 700,000 vehicles due to a tire pressure light issue.
The electric car company is recalling certain 2024 Cybertruck, 2017-2025 Model 3 and 2020-2025 Model Y vehicles because the tire pressure monitoring system warning light “may not remain illuminated between drive cycles, failing to warn the driver of low tire pressure,” the National Highway Traffic Safety Administration said Thursday.
The NHTSA released its safety recall report Tuesday, noting that “driving with improperly inflated tires increases the risk of a crash.”
The recall affects around 694,000 vehicles.
Tesla said as a remedy it released an over-the-air software update for free. Owner notification letters are expected be mailed on Feb. 15, 2025.
nbcnews
Jeep recalling 79,000 2024 Jeep Grand Cherokees and Wagoneers for Rearview Camera problems
A Jeep backup camera recall affects more than 86,000 model year 2024 Jeep Wagoneer, Jeep Grand Wagoneer, Jeep Grand Cherokee and Jeep Grand Cherokee L vehicles.
Like so many recalls in 2024, this one is caused by software problems, specifically in the Jeep backup camera modules. The problem causes rearview camera image failures.
In July, engineers noticed rearview camera failures on the Jeep vehicles. In addition to making backing up a bit more difficult for a driver, the camera failures violate federal safety standards. More than 7,000 of the Jeeps are recalled in Canada.
FCA dealers will update the backup camera module software after Jeep recall letters are mailed January 21, 2025. Jeep owners may call Chrysler at 800-853-1403 and ask about backup camera recall number D5B.
Separately, Fiat Chrysler is recalling about 300 Mopar rearview camera modules with part numbers 68598674AF, 68617886AD and 68617887AD.
Dealers will update the rearview camera module software, but cameras that have not been installed on vehicles will be repurchased.
carcomplaints
Ford recalls F-150 Lightning after steering defect causes crash
Ford F-150 Lightning problems have caused a recall of nearly 12,000 battery electric vehicles (BEVs) at risk of serious control and steering problems. The recall of 2023-2024 Ford F-150 Lightning trucks is necessary because the front upper control arm ball joint nuts may not have been tightened properly.
This can allow the front upper control arm to detach from the knuckle assembly. Ford is aware of one crash caused by the problem.
According to Ford, an F-150 Lightning owner "reported that at 639 miles they experienced intermittent vibration while driving at highway speed before the vehicle suddenly made an uncommanded left turn into a side rail. Upon inspection, the dealer technician discovered the upper control arm nut was missing and the joint had separated from the knuckle."
A Ford F-150 Lightning driver will experience a partial loss of directional control if the front upper control arm separates from the knuckle assembly. A truck driver may notice the F-150 Lightning vibrating or hear a clunk or rattle noise if the ball joint nut is loose or missing.
Ford dealers will inspect the torque of the left and right upper control arm ball joint nuts. Dealers will replace the nuts if the torque inspection passes. Dealerships will replace the control arm ball joint nuts and knuckles if the torque inspection fails.
Ford F-150 Lightning recall letters are expected to be mailed February 3, 2025.
carcomplaints
Kia EV9 recall issued for missing Seat Bolts
More than 22,000 Kia EV9 SUVs are recalled because of second-row and third-row seat problems. The recalled 2024-2025 EV9 seat mounting bolts may be missing, something that could cause real problems in a collision.
It's likely an assembly plant worker got a talking-to because it was an employee who made the mistake. Kia received a report in September about a 2024 Kia EV9 that had missing third-row seat mounting bolts.
A second report came in about another 2024 EV9 with missing bolts, so Kia inspected dozens of vehicles but found no problems. But a third report was received regarding a dealer warranty claim. At this time, the problem was traced to a worker error.
Kia is unaware of any crashes or injuries, but customers should pay attention to any loose seats or rattle noise. Kia dealers will install any missing seat mounting bolts once EV9 recall notices are mailed in January 2025.
Kia EV9 owners with questions may call 800-333-4542 and ask about seat mounting bolt recall number SC329.
carcomplaints
Ford recalling 20,000 Escape, Lincoln Corsair SUVs for Battery issue
Ford has announced it will recall 16,480 Escape and 4004 Lincoln Corsair plug-in-hybrid SUVs over a battery problem. In documents filed with the National Highway Traffic Safety Administration (NHTSA), the automaker said the problem occurred in manufacturing, and resulting "microdefects and local stresses" could cause the high-voltage battery cell's separator layer to become damaged, leading to a short circuit and potentially, a fire.
A "Stop Safely Now" message will appear on the instrument cluster if the problem occurs, Ford said. The recall documents state that there have been four total reports of "thermal venting" as a result of the issue, but no accidents or injuries have been reported.
Affected vehicles are plug-in-hybrid models with a 2.5-liter four-cylinder engine and were assembled between July 10, 2019, and April 17, 2024. Ford will notify owners beginning on January 20. Dealers will update the affected vehicles' Battery Energy Control Module software so it can detect the problem, and if it is found, they will replace the high-voltage battery pack at no charge.
Owners of potentially affected Escape and Corsair SUVs can check the NHTSA recalls site or contact Ford customer service at 866–436–7332.
caranddriver
Ford recalls Fiesta, Flex, and Lincoln MKT for rearview Camera issues
Ford backup camera problems have caused a recall of more than 30,000 model year 2019 Ford Flex, 2019 Ford Fiesta and 2019 Lincoln MKT vehicles. Ford discovered the rearview camera images were appearing distorted, upside down or the display screens were blank. Ford's engineers haven't determined the exact root cause of the problem but believe it may be in the cameras.
The National Highway Traffic Safety Administration contacted Ford in August 2024 regarding 24 complaints about 2019 Ford Flex backup camera problems.
Flex owners reported no backup camera images, black or blue screens, fuzzy, flashing and inverted images.
A search of camera-related information showed increased warranty claims for Flex vehicles built after May 2019. Ford also saw camera problems in 2019 Fiesta and 2019 Lincoln MKT vehicles built after June 2019.
Ford backup camera recall letters are expected to be mailed February 2025, but how the vehicles will be repaired is currently unknown. Ford owners with questions about the backup camera recall should call 866-436-7332. Ford's backup camera recall number is 24S75.
carcomplaints
Land Rover recalls Range Rovers over faulty Cameras
A Land Rover Range Rover backup camera recall affects about 12,600 vehicles that may display blank or distorted rearview camera images.
The recalled 2022-2023 Range Rover backup cameras are mounted on the rear bumpers, but water can enter the cameras and cause problems with the rearview images. Land Rover opened an investigation in September 2024 after complaints about backup camera image failures.
According to Land Rover, engineers determined water could cause delamination of the pressure compensation element and cause the image display to appear distorted or blank. There have been no reported crashes or injuries as a result of this problem. But Land Rover has received 244 claims and field reports in the U.S.
More than 600 vehicles are recalled in Canada.
Land Rover is working on how the backup camera problems will be corrected, but Range Rover owners should watch for recall letters around the middle of February 2025.
carcomplaints
Tesla rearview camera failures cause recall of 240,000 vehicles
About 240,000 Tesla vehicles are recalled because the rearview camera images may fail to display on the screens. The rearview camera recall involves these vehicles equipped with computer circuit boards that may short-circuit.
  • 2024-2025 Tesla Model 3
  • 2024-2025 Tesla Model S
  • 2023-2025 Tesla Model X
  • 2023-2025 Tesla Model Y
People may have forgotten the old ways, but Tesla says a customer can perform a shoulder check and use the mirrors if the rearview camera image fails.
Tesla noticed the camera image problem in November 2024 when engineers saw an increase of vehicle computer replacements. As of December 30, 2024, Tesla was aware of 887 warranty claims and 68 field reports, but no crash or injury reports have been received. The vehicles began receiving over-the-air software updates in the middle of December 2024. The update changes the vehicle power up sequence to prevent short circuits.
Tesla says no further action is necessary for vehicles equipped with software release 2024.44.25.3, 2024.45.25.6 or a later release if an affected vehicle has not experienced the shorting failure condition or stress that may lead to the shorting failure condition. Tesla is working to identify which recalled vehicles, if any, experienced stress that may lead to the short circuits.
Tesla will replace the vehicle’s computer for free if a recalled vehicle experienced short circuits or stress that may lead to the shorting failure condition prior to installing software release 2024.44.25.3, 2024.45.25.6 or a later release.
Tesla rearview camera recall letters will be mailed March 7, 2025, but owners with questions should call 877-798-3752. Tesla's rearview camera recall number is SB-25-00-001.
carcomplaints
74,000 Kia Sorento models recalled for Headlight, Taillight failure
Kia is issuing a recall of 74,469 Sorento models over an issue related to the headlights and taillights. According to documents filed with the National Highway Traffic Safety Administration (NHTSA), the automaker said the problem stems from a software-logic issue in the Body Domain Control Unit (BDC) that has the potential to cause momentary loss of power to the headlights and taillights.
The vast majority of the SUVs involved in the recall population are the nonhybrid Sorento, which makes up 63,782 of the roughly 74,000 total. The standard hybrid makes up a further 8937 models, and the PHEV version accounts for the final 1750 cars.
To remedy the issue, dealers will install updated software to the BDC, which the recall documents state has been improved to prevent the issue in the future. According to the NHTSA documents, Sorentos produced on or after September 19, 2024, Sorento Hybrids produced beginning on July 19, 2024, and Sorento PHEV models produced starting on June 20, 2024, are equipped with updated BDC software from the factory.
caranddriver
More than 63,000 Jeep Cherokees recalled over sudden loss of power and brake function
Stellantis, the parent company of Chrysler, is recalling more than 63,000 Jeep Cherokees because of a defect that causes the vehicles to lose power and impede parking, increasing the risk of a crash, according to a recall notice posted Wednesday by the National Highway Traffic Safety Administration.
As a result of a poorly seated input shaft ring, the vehicles' "power transfer unit (PTU) may become damaged and disengage the transmission and differential, resulting in a loss of drive power and/or loss of park function," the recall documents state. "A loss of drive power can increase the risk of a crash. A loss of park function can cause an unintended vehicle rollaway, which can increase the risk of a crash or injury."
Though drivers may experience "a Service 4WD message, noise, vibration or change in drive quality," the manufacturer cautions that "a loss of motive power can cause a vehicle crash without prior warning."
The recall documents do not state whether Stellantis is aware of any crashes or injuries related to this issue.
The recall affects certain 2017-2019 Jeep Cherokee vehicles. Chrysler has not yet specified how it will fix the problem but said notification letters will be mailed to owners on Feb. 13. Drivers can contact Chrysler FCA customer service at 1-800-853-1403 for more information; FCA's number for the recall is 01C.
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153) or go to nhtsa.gov. NHTSA's number for the recall is 25V011000.
cbsnews
Xiaomi recalls over 30,000 SU7 sedans due to faulty smart parking system
Xiaomi filed for a recall plan for 30,931 SU7 electric sedans due to a faulty autonomous parking system. Owners of those vehicles will receive a free OTA update to improve software without having to visit a Xiaomi-authorized after-sales service center.
On November 14, an owner of a Xiaomi SU7 Standard version reported that his vehicle caused an incident during the autonomous parking process. The car’s detection system was affected, resulting in scratches and collisions during the intelligent parking.
On January 24, Xiaomi reported it recalls 30,931 units of the SU7 Standard variant manufactured between February 6, 2024, and November 26, 2024. The recall affects models with internal numbers BJ7000MBEVR2, XMA7000MBEVR2, and XMA7000MBEVR5.
Xiaomi officials explained that the autonomous parking function of some SU7 sedans suffered from an occasional failure of the cloud service’s timing synchronization. The automaker reported that it implemented effective preventive measures through the cloud service and then added more redundant protection strategy measures to the smart parking assistance, confirming that the risk is eliminated.
After two months of testing and verification, Xiaomi confirmed their solution is safe and reliable. So, the company announced an OTA software upgrade recall. It means Xiaomi SU7 owners will be able to update the software of their vehicles without having to visit official service centers.
carnewschina
