Hi there,
I have got your PM, so sorry to hear that you are in trouble again with your Aria.
1.) For Tyre and Pulling of the Vehicle: Get your Car Aligned and Tyres should be balanced at a well known and reputed place to check the castor, camber, toe and wheel balancing. If the problem persist than shift to OEM Steel Rims.
In this case they cannot deny warranty as the alloys were used are OEM supplier alloys and they come under warranty and all the alignments and balancing were done at TASS. So kindly check the quality of Alloys too.
One more thing, did your front shock absorbers were replaced under warranty ? If yes than they need to reset the alignment and balancing of the car. Same happened to my car as front shock were upgraded and they forget to do the alignment and balancing thus eated my front two tyres partially, I changed one from outside (due to aftermarket alloy, no warranty).
Note: Yes, uneven wear of tyres might gives you unbalanced ride quality, kindly keep the tyre pressure at 32PSI only.
Now wobbling issue is somewhat gone from my car, lets see when it will crop up. My Car has done 33500 kms and tyres has a lot of thread in it like may be another 33000 kms or so.
Kindly ask for replacement in warranty.
I always keep 32PSI only in my city as most time me, my wife and 2 small kids alone. When i go for long drive with luggage i'll keep 33PSI. If i have more person with luggage for long drive, i used to fill 34PSI.
2.) Rattles in Door: Kindly ask them to adjust the latch and open the door cladding and tight all nuts and bolts.
3.) Driver Seat Rattle: Shoot a video and ask the warranty person to get it replaced under warranty, Quote my example. I have also changed my seat under warranty.
5.) Clutch: Ask them to bleed the clutch and if the problem persist then ask them to replace the clutch assembly (means pressure plates, bearing etc. under warranty)
6.) Jumping of Vehicle: Don't know what do you mean by this? sorry
They stopped it. I dont know how they fixed it. They told me tht thy tighten some screws.
7.) Steering: Kindly ask them to open the steering assembly and check for any wear and tear happen due to shaking, check the bushes and all, greese them.
9.) Just ask whether PTL bolt (peak torque limiter) is changed in your car or not or whether your car has new PTL or old design PTL. Mine had old PTL and they have changed that.
And at present My ARIA has no problems at all, I have gone for a long trip in snow and it performed very well.
Kindly clear few of my doubts. The alignment issue was there from the beginning. They installed new OEM safari alloys at 3000kms. Inner side of both front tires were gone flat at 6000kms. I complained about the alignment issue inbetween and thy check alignment and balancing. At 6000kms they rotate the front tires, but left pulling continues. at 10500kms innerside intact, but the outer side went pure flat (The same inner side before). They interchange front and back tires. Now its 13800kms, tires has no issue, but the left pulling and steering vibration continues. Now the tata peoples and dealership peoples told me that all the issues due to alloys. But i feel tht the reasons are baseless based on the above facts. And they telling that the tires are not claimable as the alloys are not come with the vehicle.
@ justin,
1. Get the alignment checked at tyre centers. The TASS or any service center dont have qualified (enough) people to do that. Also get the balancing done on all 4 wheels. Usually they do it only on the front tyres. AND do this balancing and Alignment every 5000 kms. AND also frequently if you notice this pulling and wobbling thing. If you travel through rough roads, then this will be more frequent. Wheel alignment is a delicate thing. If you crash into a small speedbreaker it will be off.
2. Again BALANCING. If the balancing is not done correctly, then the chances are steering column vibrates at speeds. Try some tyre center for balancing. Try some authorised Bridgestone outlets.
3. Some times faulty alignment can lead to unsettled suspension. But cant be sure about this.
4. Balancing and alignment.
5. If this is coming from outside the cabin, then probably it is due to worn out tie rods.
Check for power steering fluid level, If it has gone down, then check the underbody and steering rack area for oil leaks, if there is a leak then chances are that the steering rack is damaged. If the steering rack is damaged, then change under warranty.
6. If this noise is only when you start the engine and shut it off, then ignore it. This sound is due to clutch system activation. This engine uses hydraulic clutch activation system. When the engine is off, effectively the system is off. BUt if the sound is persisting then I cant be sure about it.
7. Has to be hinges or latch. Get it aligned and tightened. This can be done by local mechs also. ASS guys usually miss on these things as they are minor. Though it is irritating for us.
14. If you keep your mouth shut on these issues, they will certainly take advantage of you. Just bash them for doing such things. Come on, why should they ever fiddle with the seat belt lock mechanism.
15. hahaha, your car is haunted man. You need a tantric. Well on a serious note, are you sure there are no rodents in your car.
16. Is it a rattling sound?
17. Why dont you do it yourself. Wipers are not covered under warranty. Only wiper motor is. They think promises can keep a customer happy IDIOTS.
18. Is the rpm itself ids going up and down or is it only the Rpm meter needle. I think you should check your throttle pedal assy. checked.
19. My guess is that this sound is from the intake. Like a hush is it.
20. Check for the power steering fluid level. Steering will get harder if the fluid is low. And a damaged oilseal in the steering rack can lead to reduction in steering fluid.
21. Change the censors
23. Is the air pressure correct. TATA says 30psi. Ideally 30 or 32 psi should be good enough for any condition. Low pressure in any tyre will lead to boatiness.
Our regional CRM told me that they will replace both the tyres under warranty as all aria tyres are claimable, if the tyre can't server atleast 30k kms. But now he is changing his voice. He can't change it under warranty as i'm not using the stack wheels. But my dealership gave me OEM safari alloy as a offer pack with the car. I need to fight with them each day.
Tyres are covered under warranty for manufacturing defect only. Uneven wear and tear is not a manufacturing fault. Hence even if CRM has promised or told you any thing its a lie. How do I know this? Well, I am a person who sells 2 wheeler tyres.
My car just crossed only 13,500kms.
It gives me around 17.6kmpl at the speed between 80 to 100km in highways.
Thats one healthy engine man. Then what engine problem you are having? My Grande gives me only 12 on highway at speeds upto 130kmph. And only 14 kmpl between 80-100.
I've given you a few pointers, hope it helps. But without seeing the thing in person cant be sure of any thing.
"Suddenly the A/C is cutting off. But the air flow do continue its job with 1/4th the regular speed on fan mode (some times it look alike heater). At the same time my vehicle pulling is nothing as “0”. My vehicle not responding after some speed limit per gear. As 10kms speed for 1st gear, 20kms for 2nd gear and 40kms for 3rd gear. If I try to pull in 3rd gear from 20kms speed limit, it’ll reach to 40kms speed without any pulling issue. But after that speed, the vehicle not even responding above that speed. Not even revving. If I want to move further I need to change the gear and go up. This issue happening when the A/C making issues. The instrument cluster giving NO signal of check-engine, over heat etc. I checked my engine oil and coolant."
But the above said issue was resolved. I faced issues in all parts of my car. I feel the list will grow.
-justin
