Some New Gadgets Found
Xiaomi Smart Door Lock M20 with 7 unlocking options launched
The Xiaomi smart door lock M20 features an innovative full-board push-pull architecture. The smart door lock allows you to customize the holding direction to avoid an accidental pinch of the door. The unlocking options available with the Xiaomi Smart Door Lock M20 include fingerprint, smartphone, password, NFC password, Home kit, periodic, and one-time password. These unlocking options offer a variety of ways of authorizing entry into the house.
The Xiaomi Smart Door Lock M20 has a fully-automatic lock body that houses a power system. The mechanism for opening the door lock starts with verification and authentication of the request. After the successful verification, the main door lock will retract to grant access to the user. You can push or pull the handle to enter in. The door will automatically lock thereafter.
The powerful main door lock of the M20 can withstand up to 6000N lateral external force and prevent its disassembling. The device features several alarms that are activated to notify the owner of an abnormal door look, multiple trial and error attempts, external panel prying, and so on. The Xiaomi Smart Door Lock M20 uses 8 AA batteries that can deliver up to 10 months of service. It also features emergency unlock capability via the Type-C port of the outer lock.
Xiaomi launches the Mi Box 4S MAX with HDMI 2.1 port
The Mi Box 4S MAX is powered by a 64-bit quad-core Amlogic S905X3 processor. The chip pairs with 4GB of RAM while there is 64GB of storage onboard, making it a perfect fit for storing your pictures and videos. The TV box also comes with an HDMI 2.1 interface, supports 4K/8K image quality output and dynamic HDR. It also supports 8K hard decoding, Dolby & DTS sound effects, dual-band Wi-Fi, wireless casting and more.
The flagship TV Box comes with MIUI for TV pre-installed bringing support for the MIJIA app, XiaoAI voice prompt and Bluetooth voice remote control. You can also watch movies from your phones , hard disk or USB flash drive. The device also allows the installation of games and other apps just like most TV boxes.
The Xiaomi Mi Box 4S MAX is positioned as a 4K flagship smart voice set-top box which happens to be the flagship model of the fourth-generation Mi TV Box 4 that was launched in 2018.
Blaupunkt BTW100 TWS earbuds launched in India
The Blaupunkt BTW100 TWS have a straight stem that features chrome edges while the charging case has a clamshell-like design. The earbuds are powered by a 10mm driver that produces punchy bass along with clear mids and highs, according to the brand. The brand also claims that the device produces “Stereo high definition sound”.
Each of the earbud packs a 40mAh battery pack while the charging case packs a large 400mAh battery. The earbuds are claimed to last up to 4 hours on a single charge and up to 40 hours when paired with a charging case. The BTW100 case charges via a USB Type-C charging port. There’s support for fast charging so the earbuds are capable of providing 1 hour of playback time with 15 minutes of charging. Additional features include sweat, water & dust resistance, and touch controls.
The earbuds also come with the “ENC CRISPR Technology” that filters ambient noises while on a call and only picks up human voices. For connectivity, the earbuds use Bluetooth 5.1 which enables a maximum range of 30ft without signal loss or mic dropout. Lastly, earbuds also feature an 80ms low latency mode for gaming.
The Blaupunkt BTW100 TWS earbuds are currently listed on Amazon India for Rs 1,499/-
Bose SoundLink Flex Portable Bluetooth Speaker launched in India
The Bose SoundLink Flex has a custom transducer which maximizes clarity so you can hear each instrument and vocal, and delivers powerful bass. It combines with dual-opposing passive radiators, which turn vibration into powerful audio output from the compact speaker. Bose proprietary digital signal processing (DSP) technology minimizes distortion so you hear natural, full sound.
Read
BLUETTI EP500/Pro power station officially launched
Bluetti has introduced its latest power station in Europe. It is the EP500Pro Power Station which has a battery capacity of 5,100Wh for long-lasting performance. You can charge the Bluetti EP500Pro at speeds of 4,000W via an AC outlet or through a solar panel.
The EP500Pro is housed inside an airtight aluminum case capable of withstanding pressure changes, punctures, and heavy impact. The battery capacity can be sustained for up to 6,000 charging cycles before its capacity reduces by 20%. The Bluetti EP500 weighs just 76kg and it comes with four wheels for easy mobility. The dimensions of the power generator are about 23 x 1 x 30 inches and it can operate in a range of about 60 degrees Celsius (-20 to 40 Celsius).
The Bluetti EP500Pro Power Station has multiple ports to cater to many gadgets. The outlets include AC (2,000W), USB-A (100W), USB-C (100W), and wireless charging pads. There are three AC outlets, four USB-A ports, one USB-C port, and two wireless charging pads on the generator. Power conversion is achieved through its 3,000W sine wave AC inverter and the Lithium Iron Phosphate (LiFePO4) battery offers thermal stability.
The Bluetti EP500Pro Power Station is originally priced at €5,299.
HyperX Alloy Origins gaming keyboards & Pulsefire Haste wireless gaming mouse launched in India
The HyperX Alloy Origins 65 comes with dedicated arrows and keys, as well as a form factor of about 65%. It also offers HyperX Red linear switches or Aqua tactile switches, as well as dedicated keys for arrow, delete, and page up/down. The HyperX mechanical switches are present to enhance the performance and longevity of the device.
The HyperX Alloy Origins 65 keyboard has RGB backlit keys and an LED design. This provides an illuminating and radiant lighting experience, as well as five adjustable brightness levels. Software support for the keyboard is from HyperX NGENUITY which offers up to three profiles and the opportunity to personalize several options. Some of the customization options include lighting, the game mode, and the macro settings.
The HyperX Pulsefire Haste wireless mouse is designed to offer quick movements and greater comfort. It also offers increased ventilation due to its honeycomb hex shell design. Being a gaming mouse, it comes with the relevant wireless technology and provides low-latency connections. It operates on 2.4GHz while its rechargeable battery can last up to 100 hours. Its effectiveness can be sustained for up to 80 million clicks. There are six customizable buttons on the wireless mouse with onboard memory also available.
The HyperX Alloys Origin 65 and 60 keyboards are both priced at Rs. 8,990 and the Pulsefire Haste wireless gaming mouse is priced at Rs. 7,490.
Lenovo Smart Clock Essential with Alexa Built-in launched in India
Smart Clock Essential with Alexa Built-in is the latest addition to Lenovo’s range of smart devices with digital smart clock features and hands-free voice control with Alexa. It comes with the same 4-inch LED display as Smart Clock Essential with Google Assistsnt and Smart Clock 2, for showing weather, humidity, and the temperature outside. It further confirms that this is the Smart Clock 2 without a charging dock and comes in different colours with a new voice assistant. Talking about the voice assistant, it has Alexa built-in, using which one can set timers, alarms, reminders and add items to their Amazon shopping cart with simple voice commands.
The Smart Clock Essential is available for Rs 4,999/-
Thomson launches Fully Automatic Washing Machines range with inbuilt heater
The newly launched Thomson Washing Machines range comes with an inbuilt heater that improves the wash quality and removes even the hardest stains. Because the heater is intended to withstand scale and rust, it ensures that the garments are allergen-free 99.9% of the time.
These are claimed to remove 99.9% of germs and bacteria from a wide range of fabrics without destroying them by boiling water at three different temperatures. Scrubbing, steeping, rolling, and swinging are all possible with this machine’s built-in heater and pulsator, especially when using warm water to assist clean the garments.
There is a One-touch function to soak, wash, rinse and spin. The machines work at low water pressure making them energy efficient. Further, there is a Child lock and memory function for the family’s safety. Lastly, Wrinkle-free with a special feature is to minimise the wrinkles.
The new range offers two models, 8kg and 9kg priced at Rs 15,999 and Rs 16,999 respectively.
Noise launches i1 in India
Noise i1 is the first pair of smart eyewear from the Indian brand which includes a guided audio design to ensure a proper flow of music. Furthermore, it blocks out ambient noise as well. The device offers over 9 hours of playtime on a single charge. It is equipped with Bluetooth 5.1 for connectivity, ensuring that your eyewear connects to your phone as soon as the temples are opened.
The device has a connectivity range of up to 10 metres and is claimed to deliver 120 minutes of playtime on a 15-minute charge. The smart eyewear also features multi-functional touch controls that enable users to accept and reject calls, manage music, and activate the voice assistant.
It comes with UVA/B 99% protection against sun rays in sunglasses lenses and changeable blue light filtering transparent lenses for reducing eye strain and providing clear vision when using laptops, etc.
Noise i1 is available at Rs 5,999 and buyers can purchase this limited edition device from the brand’s official website.
Eufy by Anker’s Robovac G20 Hybrid robotic vacuum cleaner launched in India
The Robovac G20 Hybrid runs on ultra-pack dust compression technology. It efficiently utilizes the attached dust box and can detect when extra vacuuming power is needed. The user can customize the cleaning areas using the Eufy application.
The AI Map 2.0 technology in the Robovac G20 Hybrid makes it to seamlessly map the cleaning area for optimal cleaning. Voice Assistants like Google Assistant and Alexa are also supported. Dynamic navigation is fully supported in the Robovac G20 Hybrid robotic vacuum cleaner.
The Eufy by Anker Robovac G20 Hybrid has up to 2,500pa of suction power, dynamic navigation capability, and other smart features. It offers four suction modes, increased airflow, and quiet operation around the house. The Robovac G20 has a maximum sound output of 55dB and offers an excellent operation due to its Boost IQ technology. It is priced at Rs. 23,999.
Portronics launches TWS Boombox Speaker
Portronics launched a new Boombox speaker — Dash 12. It is the successor to the Dash 11 speaker. The new wireless speaker combines dual bass radiators, includes a Karaoke mic, and can operate in TWS mode too. Apart from that, the company has a playback time of 9 hours.
The Dash 12 TWS Boombox speaker has twin drivers that provide 60 Watt of audio power. Built with a Bluetooth V5.0 TWS-capable chip, one can pair two Dash 12’s working in sync to deliver 120 watts of peak audio. If you have a large home, the TWS mode can also give you multi-room audio delivery to extend your music to other rooms, says Portronics.
The speaker has in-built multi-colored LED Lights that strobes in different colors on every changing beat. Then there’s also a karaoke mode where you can use the bundled wired microphone to sing those songs you love. One can seamlessly using Bluetooth, or plug in a USB pen drive loaded with a playlist.
It has a built-in voice assistant feature so one can access controls hands-free. The Portronics Dash 12 is also portable so you can carry it along wherever you go
The product carries a standard 12-months warranty through Portronics.com, Amazon.in and other leading online and offline stores.
Philips Hue Go table lamp with a 2-day battery life launched
The Philips Hue Go table lamp is a portable rechargeable lamp that can be used both indoors and outdoors. Its long battery life means that the lamp can be used for extended periods.
The Philips Hue smart lighting products also include the Perifo track lighting system, the Signe gradient lamp with a new wake feature, and the Tap dial switch. Perifo is a fully customizable track lighting system. The system can be used to combine multiple rails and different designs and lights. The Perifo will be available first in Europe.
The Tap dial switch uses a dial to moderate the brightness of smart lights. The Tap dial has four buttons to control the room lighting and set scenes. It can also be used as a remote control or mounted on a wall. The Tap dial switch can be attached to metal surfaces magnetically.
The Philips Hue app now features a Wake Up function which slowly turns on the lighting to mimic sunrise. The effect is that you are roused gently from sleep. The Wake Up feature is compatible with all Philips Hue gradient lights.
The table lamp is priced at €149.99. The Perifo comes with a starting price of €49.99, which is the same price as the Tap dial switch. The Philips Hue Signe gradient lamp starts from €239.99.
Tata Play partners with Google to launch the Nest cam in India
Google Nest Cam was launched last year and it provides intelligent alerts that can be customized to meet security needs. You can be notified when the camera picks a moving object (human, animals, vehicles, etc.) It also offers advanced familiar face recognition alerts using the Nest Aware subscription. The Google Nest Cam (Battery) offers two-way communication thanks to its built-in microphone and high-quality speaker. It offers Full duplex 2-way audio and noise cancellation.
The Google Nest Cam (Battery) is built for all conditions and corners of the home. It is weather-resistant and does not need any wires for connection. It can also see clearly in any light with HDR and night vision capability. It also has an Event Video history using the Google Home app. You can get up to 60 days of Event Video History and 10 days of continuous video history. The in-built memory of the Google Nest Cam can store up to one hour of recorded events.
The Tata Play Secure and Google Nest Cam will be available in at least 10 cities including Delhi, Mumbai, Bangalore, Hyderabad, and Kolkata. Subscribers to the Nest Aware service will pay the sum of Rs. 11,999 inclusive of installation of the Nest Cam. The yearly subscription for the basic plan is Rs. 3,000 for up to 4 devices, while the Tata Play Secure+ plan starts at Rs. 5,000 annually.
Mammotion KUMAR wireless robot lawn mower with a 1.2-hectare range unveiled
The KUMAR wireless robot lawn mower that can cover an area of 12,000 square meters (1.2 Hectares) has been revealed. The Mammotion KUMAR wireless robot lawn mower is designed for commercial use. The robot’s ultrasonic radar enables it to avoid bumping into obstacles.
The KUMAR is coming on the heels of the Kickstarter campaign for the LUBA lawn mower which has more than 2,000 backers. The LUBA is a wireless robotic lawn mower priced at $2,499. It has an all-wheel drive and a range of 5,000 square meters (0.5ha) on a single charge. Its ultrasonic radar offers the LUBA a 220-degree field of view and excellent obstacle avoidance.
The Mammotion KUMAR is a more powerful robot lawn mower than the LUBA. It has a range more than twice that of the LUBA and is primed for commercial applications. It can mow large lawns, parks, river embankments, and other large areas. It is fitted with a GPS-RTK satellite positioning system and boundary setting capability. It has four ultrasonic radars to enhance its obstacle avoidance capabilities. The KUMAR has two 24Ah batteries and the company says the device is seven times cheaper than a regular lawn mower.
Pricing and availability details are not yet available for the Mammotion KUMAR robot lawn mower.
Belkin BOOST CHARGE PRO 3-in-1 Wireless charging stand unveiled
Belkin has announced a new 15W wireless charging stand for Apple devices. The new BOOST+ CHARGE PRO 3-in-1 Wireless Charging Stand comes with stainless steel finishing and will fit snugly with the latest Apple flagships. A white LED indicator provides the charging status. The LED turns to amber when the charging process is being hampered. The Apple iPhone 13, iPhone 12, AirPods, and other devices will enjoy 15W wireless charging using the device.
This Wireless Charging Stand is MagSafe-enabled. This assures perfect alignment and fast wireless charging at all times. MagSafe remains the most convenient way to charge electronic devices. The MagSafe keeps the device secure from falling off while charging. You can simultaneously charge three devices using the Belkin BOOST+ CHARGE PRO 3-in-1 Wireless Charging Stand. The package comes with a 2-year warranty on the device which is available in black and white colors.
The Belkin BOOST+ CHARGE PRO 3-in-1 Wireless Charging Stand is priced at $149.95. It will be sold this month via Apple stores in the US, Asia, Australia, and other select markets.
