Some New Gadgets Found
Xiaomi MIJIA Smart Bladeless Purification Fan
The MIJIA Smart Bladeless Purification Fan comes with a two-in-one purification cycle design and has the ability to filter 80-90mm particles with up to 99.96% efficiency. It also has antibacterial and antiviral coating in the filter which can inhibit and inactivate bacteria and viruses in the filter for a long time.
The company says that the product uses the innovative air duct structure design, with a 10-meter wide-area circulation, a maximum wind speed of 15.5m/s, and a maximum air volume of 1700m³/s. There are two groups of air outlet modes that can be adjusted in the front and rear. It also packs a built-in temperature and humidity sensor as well as a PM2.5 sensor.
The product supports XiaoAI which is Xiaomi’s own smart voice assistant. Similar to other Xiaomi products, the MIJIA Smart Bladeless Purification Fan can be connected to the MIJIA application for controlling it through the smartphone.
The product has been launched for open sale in the Chinese market and can be pre-ordered for the price of 1,599 yuan( around $250).
U&i launches Switcher Series 10000mAh 7-in-1 powerbank with flashlight
The U&i Switcher Series is a powerful 10000mAh powerbank that can fast-charge almost any device that needs it. A conventional smartphone can be recharged almost thrice, allowing you to be away from your wall adapter for up to 4 days in a row. The powerbank features four power cables for all three types of ports: Micro USB, Type-C, and Lightning. In short, any Android or Apple smartphone, headphones, and BT speakers can be charged up to 3 times.
The powerbank also has an attached USB-A cable that allows itself to charge directly from any USB port from a laptop, desktop, or power adapter. Additionally, the powerbank also features a micro USB port for charging itself, a USB Type-C port for charging itself and power output, and two USB Type-A ports for charging two devices with the help of a USB Cable. In short, you could charge up to six devices simultaneously. A battery charge indicator is also available so you can see the amount of power remaining in the internal batteries.
Further, the USP of U&i UiPB 3483 is the built-in flashlight or COB light— 20 micro LEDs on the face of the powerbank that produces a very bright illumination in the room.
The Powerbank is available at Rs 2,999 and It comes with a 1-year warranty.
Baseus 600W Power Station is now on Sale
Baseus Power Station 600W comes in a cuboid design with two side handles, that make it easy to store and carry around. It weighs around 7kgs and comes with a massive 18000mAh battery that can be fully charged within a few hours. . In the front you have a TFT display that shows all the relevant data including battery percentage, charging status and more.
The battery pack is designed to power your device and home appliances and the power supply is divided into 6 different modules which makes it easy and simple to use. The 6 modules viz. the inverter module, charging module, DC module, protection module, BMS module, and Bluetooth module carry out specific activities and are packed separately. This means you can easily take apart each and every part of the module separately in case of emergency repairs.
The Baseus Power Station 600W comes with 2 Wall charging AC ports, 2 Type-C charging ports, 2 USB ports, 1 car charger spot, and 1 DC port. These 8 ports are more than enough to fulfill your basic power requirements. It is now on Sale for $497.
Sennheiser Sport True Wireless earbuds unveiled
The Sennheiser Sport True Wireless earbuds are a sports-focused device that delivers high-octane audio performance. The earbuds have three sizes of ear tips and four sizes of fins for maximum comfort. The earbuds come with water, sweat, and dust resistance via its IP54 rating.
The Sennheiser Sport has 7 mm drivers and a Qualcomm chipset that is compatible with AAC, aptX, SBC, and Bluetooth 5.2. Without the charging case, the earbuds can last up to 9 hours on a single charge.
The Sennheiser Sport True Wireless earbuds are powered by Qualcomm’s aptX and offer up to 27 hours of battery life. The earbuds are priced at $130 outside Europe and €130 in the Europe.
Logitech G PRO X Superlight Wireless Gaming Mouse launched
The new PRO X Superlight is less than 63 grams and nearly 25% lighter than the standard PRO Wireless. In addition, the mouse features a more responsive 2.4 GHz LIGHTSPEED wireless for untethered play. It offers up to 70 hours of battery life. The new mouse has large, zero-additive PTFE feet, for a low-friction experience that delivers unrivaled precision, speed, and maneuverability.
More details
Lenovo YOGA 7000 smart projector announced
The Lenovo YOGA 7000 smart projector will be available in Cherry Blossom White and Storm Gray colors. It has a striped pattern on the top surface. The specifications of the device remain a mystery as of now, however, it is expected to be a higher offering compared to the projector under the Xiaoxin brand. It is expected to be launched alongside the 2022 YOGA and Xiaoxin series notebooks in the country.
We will know more details about the Lenovo YOGA 7000 in the coming weeks at the launch event.
Samsung launches Jet Cordless Stick Vacuum Cleaners in India
Samsung Jet’s capabilities are made possible by its Digital Inverter Motor and the Jet Cyclone system. The Digital Inverter Motor incorporates an ultrasonic welded cover and diffuser that optimize airflow. It allows Samsung Jet to maintain a high level of energy efficiency needed to generate a significant level of suction power.
Users can also enjoy longer cleaning times with the Samsung Jet’s high-capacity battery. The long-lasting battery addresses consumer needs for a reliable vacuum cleaner that can maintain suction for up to one hour. And since the battery can easily be removed and replaced with a spare, users can clean for up to two hours in one session if needed, with an optional additional battery.
Read more
Epson introduces New Document Scanner with Built-In Networking Connectivity
Epson has announced the launch of its WorkForce DS-790WN Wireless Network Color Document Scanner. Priced at Rs 72,999 the Epson WorkForce DS-790WN Network Scanner comes with a 1 year onsite warranty and will be available from authorized Epson dealers.
Read more
Roborock T8 Plus Robot vacuum with a 5100Pa suction launched
The Roborock T8 Plus series comes in two variant – the Roborock T8 Plus and Roborock T8 Plus Smart Dust Collection. The vanilla variant starts at 2,799 and 3,598 yuan respectively.. The major highlight of the Roborock T8 Plus is the massive suction power of 5100Pa. With the main brush that is not easy to entangle hair and the adjustable speed side brush, it can easily handle ground dust, floor gap dust, carpet dust, etc.
Roborock T8 Plus also uses TPU soft rubber material omnidirectional floating glue brush. The brush is designed with five long and five short strands that ensures effective wind pressure and dust removal. It is more suitable for the carpet/hair environment than the rubber-hair integrated main brush, and it is not easy to get stuck.
The T8 Plus equally packs a large 2.5L dust bag and can automatically collect dust from the robot vacuum for up to 60 days without a need for evacuation. The dust bag adopts a sliding dust bag mouth sealing design to avoid dust and ash leakage.
The vacuum cleaner also comes with a flat vibrating mop with antibacterial properties. Specifically, the built-in electronically controlled water tank of the Roborock T8 Plus can be used for constant-humidity wiping, full-width floor cleaning.
Lenovo announced a new Electric Lift Table T7 for ¥2,699 ($403)
The Lenovo Legion Electric lift table T7 has a rectangular top. The tabletop comes with a matte finish and has round corners. Its legs are triangular in structure and are made with the help of a cold-welding process, which makes them more stable than the traditional T-shaped legs.
According to the company, the lift of the table uses two 1600N motors from Jiecang. Its lifting speed can reach up to 55mm/s while producing noise as low as 48db (decibel). The rated load during the lift is 125kg. Judging from its features, the Electric lift table T7 appears to be fast, quiet, and sturdy. The lifting range of the table is between 68 to 128cm, making it suitable for users with a height of 130 to 190cm.
In addition to its lifting function, the T7 lift table also features magnetic cable organizers, storage compartments, harnesses, and other storage features. Moreover, it can be equipped with accessories like perforated boards.
The Electric lift table T7 can be used as a computer desk. Its magnetic block cable management system makes organizing cables easy and hassle-free. The T7 table adopts an integrated table frame structure, which can bear up to 250kg in the non-lifted state.
Scosche launches AFP2-SP FrescheAir HEPA Portable Air Purifier in India
The Scosche AFP2-SP FrescheAir is a highly portable air purifier-cum-deodorizer that is designed with a cylindrical shape to fit in the cup holder of any vehicle. Built to work on low power requirements, it runs off any USB Type-C charger (wall or car charger) and also includes a rechargeable battery within.
Scosche AFP2-SP FrescheAir makes use of a HEPA filter to clean and deodorize the ambient air. IT can filter up to 99.5% of PM2.5 (2.5-micron Particulate Matter) that is suspended in the air which can be anything from smoke fumes to pollen and dust.
The filter helps capture these particles and also neutralizes the air to release fresh, clean air that’s safe to breathe. Not only does it clean the air of dust, it also helps neutralize any bad odors that could be lingering around inside closed spaces.
FrescheAir also features two operating modes Automatic and Manual. Automatic mode switches on the purifier the moment you turn on the car. The Manual mode allows you to set two fan speeds for efficient and faster purification. The fan is designed to be powerful and super quiet to help it silently work without making itself obvious.
The FrescheAir will be available in India at an introductory price of Rs 6,999. It can be purchased from Amazon.in and Tekkitake.com with a 1-year warranty period.
Anker launches the Soundcore Motion Boom Plus speaker
Anker Soundcore has released its latest speaker with an improved sound and IP67 water resistance dubbed Soundcore Motion Boom Plus speaker. The Motion Boom Plus includes two 30W woofers and two 10W tweeters, delivering an output of 80W of sound. It has the same titanium drivers as the 2021 Motion Boom but adds PartyCast 2.0 to the mix. The Soundcore Motion Boom Plus has a 13,400mAh battery, which is bigger than that of the Motion Boom.
The improved output of the Motion Boom Plus means that its larger battery offers less mileage than its predecessor. While the Motion Boom Plus delivers about 20 hours of activity, the Motion Boom gives 24 hours.
The IP67 rating of the Motion Boom Plus is also an improvement from its predecessor. Although the new model is slightly heavier at 2.4kg, it comes with a strap. The PartyCast 2.0 feature enables the Motion Boom Plus to connect to more than 100 individual speakers for a more powerful performance. Some Soundcore speakers can also be synchronized to provide lighting with the sound.
The Motion Boom Plus supports Bluetooth 5.3 connectivity ahead of its predecessor. The product comes with a discounted price of $141.99 (original price $ 179.99)
DJI Mini 3 Pro with a flight time of 47 minutes announced
The DJI Mini 3 Pro is a pretty lightweight drone that offers several impressive features. The DJI Mini 3 Pro’s 249g weight allows the device to be deployed without a license in many jurisdictions. The Mini 3 Pro comes with substantial improvements in its camera capabilities and it is compact. The Mini 3 Pro’s camera can shoot 48MP photos and 4K videos in HDR. The maneuverability of the DJI Mini 3 Pro is brought to focus as it can also shoot vertical images and videos.
The DJI Mini 3 Pro has an improved battery that offers a flight time of 30 minutes. The standard battery pack of the Mini 3 Pro can be further extended to deliver a flight time of 47 minutes. The flipside of using a bigger battery is that the drone will weigh above 249g. True to rumors, the Mini 3 Pro will feature ActiveTrack, a tri-directional obstacle sensing technology. The drone, with its obstacle-avoiding technology, can be easily operated by even amateurs.
The DJI Mini 3 Pro is already available for pre-order and will cost $669 for the base model. There is an intermediate model with a DJI RC-N1 remote which costs $759. However, the flagship model of the DJI Mini 3 Pro comes with the DJI RC controller and this package costs $909.
Sony announces WH-1000XM5 Noise Cancelling headphones
The Sony WH-1000XM5 wireless headphones sport multiple microphone noise cancelling which keep out more high and mid frequency sounds than ever. “With four microphones on each earcup, this is our biggest ever step forward in noise cancelling”, says Sony. Ambient sound is captured even more accurately for a dramatic reduction in high frequency noise. Thanks to Auto NC Optimizer, noise cancelling performance is always and automatically optimised based on wearing conditions and external environmental factors such as atmospheric pressure.
Read
Huawei AX3 WiFi 6+ router launched in India
The Huawei AX3 router is equipped with the company’s Gigahome dual-core 1.2GHz processor. It uses dynamic narrow bandwidth technology based on Chipset Synergy that ensures network connectivity and signal don’t get hampered due to walls and floors. The router is claimed to deliver speeds of up to 3,000Mbps.
The Huawei AX3 router features WiFi-6+ connectivity with support for 160MHz frequency bandwidth. It comes with multi-router mesh networking that lets multiple routers work together and deliver greater WiFi coverage. The device packs OFDMA multi-device technology that is capable of connecting maximum of four devices on 2.4GHz and 16 devices on the 5GHz band.
The Huawei AX3 router features one WAN and three LAN Ethernet ports. The device comes with one-key pairing and can be controlled via Huawei AI Life app.
The Huawei AX3 router is priced at Rs 3,999 and can be purchased from Amazon.
