Xiaomi launches the MIJIA Electric Shaver S600
The MIJIA Electric Shaver S600 uses a metal aluminum body with a compact dimension of just 5.6×2.9×8.5 cm. It is lightweight and portable. It is also equipped with a refined sheepskin protective case which brings a warm and delicate touch.
It adopts a magnetic top cover and the sensor locks when the lid is closed. The gadget ises a high precision ceramic blade that is wear-resistant and designed to remain sharp for long. The blade net floats up and down with a flexible veneer that captures every broken beard in other to deliver a smooth shave.
The electric shaver is equipped with a brushless motor that can turn on the surging power in seconds up to a maximum speed of 7400 rpm. The gadget has a low operating noise. It also comes with an IPX7 waterproof build making it suitable to be washed under running water.
It charges via a USB Type-C charging interface which delivers a full charge in just 2 hours. A full battery can last for 60 days if the shaver is used for 1 minute each day.
The Shaver S600 priced at 399 yuan (~$58)
