Some New Gadgets Found
Ambrane 50,000mAh Stylo Max Power Bank launched in India
Ambrane has launched the Stylo Max Power Bank in India with a massive battery capacity of 50,000mAh. Designed for the hikers & campers, the power bank can power larger devices like digital cameras, and laptops and even give a phone a full charge several times to spend extended time.
The power bank is built with a tough exterior outer body and 9 layers of chipset protection, protecting it from overheating and short circuits. The manufactured in India power bank is encased in a high gradient matte metallic casing and is compact and robust.
The 50k Lithium-Polymer capacity is supported by 20W power output for exhilarating charging speed and Quick charge 3.0. High-speed two-way charging is supported by the power bank, which automatically regulates power output to securely charge each connected device.
Furthermore, the power bank itself can be charged via an 18W charging port. The maximum output current is 5V/2.4A. The power bank charges at a conversion rate with 20W quick charging. With two USB and one Type-C connection, the power bank can charge numerous devices at the same time.
Philips launches SpeedPro Cordless Vacuum Cleaner range in India
The Philips SpeedPro range of vacuum cleaners come with two operating modes. In normal mode, it delivers up to 50 minutes of cleaning while the Turbo mode gives you up to 22 minutes of fast, deeper cleaning. The Philips SpeedPro leverages the proprietary of an 1800 suction nozzle that, as per the company, delivers powerful pick-up of dirt on both hard floors and carpets.
The SpeedPro range of vacuum cleaners are designed for maximum reach, even under low furniture and appliances, says the company. The vacuum’s reach, combined with its Power Blade motor which is engineered for high air speed, enables precise pick-up at nozzle level. Additionally, the PowerCyclone 7 technology immediately separates dust from air.
The SpeedPro Aqua FC6728 features a 3-in-1 vacuum, mop and handheld functionality. This model has a vacuum and mop function that enables clean up for a various types of dust ranging from shoe marks on the living room floor, to the dirt in the kitchen. It is also easy to switch to the detachable handheld vacuum for when you need to clean pet hairs and dirt off your sofa.
The vacuum cleaner range starts at a price of Rs 29,995 and comes with a 2-year warranty.
Xiaomi HomeWiFi Tri-band Mesh router launched in China
The HomeWiFi mesh router is designed for large size apartments (150m²) or up to 5 stories of an apartment complex (1500m²). The router comes in pair of two units that automatically link together once turned on. At once, a maximum of 10 units can be linked together to cover the maximum area of 1500m².
The router offers a total of three band options including 2.4GHz, 5GHz, and mesh. Each HomeWiFi unit comes equipped with eight antennas and eight signal amplifiers for maximum range. The device is also capable of connecting up to 600 smart devices at once without much impact on performance.
Also, It allows users total control over connections, meaning you can easily connect or disconnect a device from the router by just pressing a tab on your smartphone. The router also offers a quick connection with the use of NFC. With this feature, guests need to just touch their NFC-enabled devices to the router and it will automatically connect to their smartphone without the need for a password.
The router can be purchased for a price of 1,499 Yuan in China.
Xiaomi 360° Home Security Camera launched
The Xiaomi 360° Home Security Camera 1080p 2i is quipped with enhanced night vision, intelligent motion detection (AI Human detection), and real-time two-way voice calling features. It supports 1920*1080p megapixels full HD video and can capture 360° horizontal and 108° vertical views. It also has 940nm infrared LEDs to assist in video recording in low light.
The camera also offers 2-way voice calling along with active noise reduction technology. The home security camera comes with a Xiaomi Camera Viewer App that allows the consumers to record videos and take snapshots. With the app support, the users can operate the camera remotely, set preferred recording times, and view historic recordings on the app. Mi Home Security Camera 360° 1080P offers two types of storage options: MicroSD cards (up to 64GB) and NAS (Network Attached Storage) devices.
It will be available at an introductory price of Rs 2,999 in India from today.
HTVRONT launches Worlds First Heat Press with Auto Pressure Exertion on Kickstarter
The HTVRONT Auto Heat Press is a stylish iron-on Heat Press with Auto Pressure Exertion that can be used to add original decorations and designs to T-shirts, tablecloths, canvas, etc. The HTVRONT auto press ensures optimal and uniform heat transfer that gives you a perfect finish every single time.
Key Features:
  • Worlds first heat press with automatic pressure exertion
  • Stylish design available in two gorgeous colors: Light Blue and White
  • Add original decorations and designs to T-shirts, tablecloths, and other fabrics
  • 15 x 15 inch large heat plate
  • Lightweight and Portable
  • Body: 20x12x16 inches, weight: 38lbs
  • Carrying handles on both sides
  • Single click temperature setting
For more information and funding details, check out their official page here
Ubon launches HULK SP-180 Wireless Speaker in India
The Ubon HULK SP-180 offers deep bass, an in-built phone stand, and 1800 mAh of battery backup. It is compatible and easily pairable with iPhones, Android devices, and laptops as well.
The wireless speaker features 4 hours of non-stop playtime, USB charging, and an inbuilt microphone port. Also, for the convenience of the users, it comes with multiple connectivity options, USB Port, Micro TF/SD Card, and AUX so that one can easily plug in ONE’S favourite playlist and dance ONE’S heart out.
It also has FM connectivity, which means you can enjoy listening to your favourite radio jockey as well. Also, with the v5.0 Bluetooth version, the TWS speaker provides a decent 10 metre range. The speaker also features an inbuilt LED lights. The speaker is priced at Rs 2499.
Xiaomi Smart Standing Fan 2 launched in India
The fan features a minimal aesthetic and is lightweight as well, weighing just 3 kilograms. Notably, the new Smart Standing Fan 2 can also have its stand extended or contracted based on the users’ preferences. It operates at a minimal noise level of just 30.2dB while its maximum noise level of airflow hits 55.8dB. The fan also features a smart algorithm that enables it to simulate a natural breeze.
The Smart Standing Fan 2 features 100 speed levels, which can be controlled through the Xiaomi Home App. Notably, the product also supports voice controls when used via Google Assistant or Amazon Alexa. In other words, it can be paired with smart home hubs and can be controlled remotely. The device can also be dismantled easily in a 6 step method for cleaning.
Xiaomi marketing this product as “Quiet Smart, Quiet Cool,” thanks to its silent BLDC motor that helps offer a natural breeze mode. Furthermore, the design of the fan itself is also unique, with a 7+5 wing shaped blade. The new smart fan even offers 3 dimensional air flow, with around 100 speed levels. It is priced at 5,999 INR .
Zebronics ZEB-Juke Bar 4050 75W soundbar launched in India
The Zebronics soundbar 4050 outputs 75W audio and delivers an immersive audio experience. It is yet another product from the Zebronics stable with a strong focus on quality sound output. The affordable price of the ZEB-Juke Bar 4050 together with its premium features are some of the key design goals of Zebronics. A 10.16cm subwoofer, a dual driver setup, and 3D audio equalization are some of the key specs of the soundbar.
Multiple modes are available in the ZEB-Juke Bar for a customizable listening experience. Connectivity options are wired and wireless. These include Bluetooth 5.0, HDMI (ARC), and Optical/ Aux input. The devices can connect to a TV, DVD Player, laptop, and others.
Zebronics is offering a 1-year warranty on the product and a huge discount of 55%. Its original price is Rs. 9,999.
Xiaomi Smart speaker launched in India
The Xiaomi Smart Speaker has a 1.5-inch full-range speaker and microphones with the capability to ensure voice commands are activated far-field. It can be paired with another speaker to provide stereo sound. Its LED digital clock display helps users keep tabs on the time. The speaker IR Control has Chromecast functionality, enabling users to cast content to other compatible devices. The speaker has Google Assistant embedded and this allows the user to control other smart home devices.
There are four buttons atop the new Xiaomi speaker for volume, music, and microphone control. The IR blaster on the speaker will control other smart devices via the Xiaomi Home or Mi Home app on your smartphone. It is priced at Rs. 4,999
The speaker IR Control can connect via Bluetooth 5.0 in addition to the in-built Chromecast. Power is supplied to the speaker via a 12V/1A DC input and the speaker weighs 6.28kg.
JamesDonkey launches RS2 Gasket mounted mechanical Keyboard
James Donkey has launched its latest RS2 Hot-Swappable Gasket Mounted Mechanical Keyboard. The new keyboard is designed with a Retro theme and holds a 99-key arrangement with a giant multimedia volume knob.
RS2 Hot-Swappable Gasket Mounted Mechanical Keyboard is made with an FR4 glass fiber positioning plate and suspended by a gasket mount suspension on the chassis. The keyboard comes with ABS+PC material chassis along with dual-toned injection-molded PBT keycaps that are known for their durability and resistance to wear and tear. RS2 uses newly developed Gateron G Pro mechanical switches that have better optimization with self-lubricating shafts. Moreover, the switches come with a transparent cover giving your keyboard a unique look. The keyboard plate on the RS2 supports full hot-swapping so you can switch your keys with ease. And as you can use both 3-pin and 5-pin switches, the keyboard is compatible with most of the switches available in the market.
For pro gamers and music lovers, the keyboard comes with a multi-media knob that gives you quick and easy access to the volume. It also features a bulti-in white backlight with 17 lighting effects that make it perfect for your game night.
RS2 supports both Windows and Mac operating systems and has triple connection modes viz. Bluetooth, Wireless 2.4GHz, and Wired USB Type-C. It houses a large 3000mAh battery that gives you up to 4 weeks of battery life on a single charge.
The mechanical keyboard which retails for $99 is now available at an early bird discounted price of $79 only.
Xiaomi S10T Robot Vacuum cleaner launched globally
Xiaomi has announced the S10T robot vacuum cleaner with an 8kPa suction. The new robot vacuum cleaner has multiple cleaning modes, and powerful suction and mopping capability. The device also comes with Xiaomi’s anti-tangle technology that prevents particles from clogging it. The new robot vacuum cleaner is capable of cleaning 180 square meters of space using an LDS laser for its navigation.
The S10T offers mopping services with three water volume settings to suit individual choices. Its 5,200mAh battery allows it to clean up to 180 sq. meters on a single charge. Its 450ml dustbin and 250ml water tank help to fast-track the cleaning and mopping process. The robot is capable of overcoming obstacles up to 2cm tall. It accurately maps the cleaning area and navigates using the LDS laser navigation. The map can be used to direct the robot to specific areas and its quad-core chip implements the SLAM algorithm for efficient operations.
The Xiaomi S10T robot vacuum cleaner can be remotely controlled via the Mi Home or Xiaomi Home app.
Dyson V15 Detect Cord-free Vacuum Cleaner launched
The Dyson V15 Detect Cord-free vacuum cleaner is said to offer up to 60 minutes of powerful fade-free suction. It also offers an advanced five-stage filtration system that captures up to 99.99 per cent of particles as small as 0.3 microns.
The new vacuum cleaner also sports a Dyson Hyperdymium motor which is said to be able to generate up to 240 watts of suction.
The Dyson V15 Detect also comes with de-tangling technology, allowing it to pick up long hair and pet hair with an anti-tangle conical brush bar. The device comes with laser dust detection feature which uses an angled green laser integrated into a cleaner head to reveal microscopic dust particles that can’t be seen by the naked eye.
Dyson Vacuum cleaner is priced at Rs 65,900. The device is available for purchase via Amazon, the Dyson website, and Dyson Demo stores.
Logitech unveils Aurora series Mouse, gaming headset & mechanical keyboard
The G735 Wireless Gaming Headset features ethereal RGB lighting and on-ear audio mixing. It is the first Logitech G device with the Blue VOICE microphone technology. It accommodates players of different head sizes and has 56 hours of battery life. The LIGHTSPEED wireless technology ensures that users enjoy an unrestrictive gaming experience, in addition to Bluetooth connectivity.
The Mechanical Gaming Keyboards reflect Logitech’s thrust for excellence and comfort, as well as the other models in the Aurora Collection. The keyboard can offer up to 25 hours of gaming with its rechargeable batteries. Other accessories include the Wireless Mouse, palm rest, keycap puller, and brush, as well as a customizable mouse pad.
These products can be purchased via the Logitech G’s website with the G735 priced at $229.99. More details can be obtained from the company’s website.
Daiwa launches new range of Aqua Wash Deluxe Washing Machines
Daiwa has launched its new range of Aqua Wash Deluxe washing machines with Spiral Wash Pulsator Technology in India. Daiwa has introduced Spiral Wash Pulsator Technology, giving the friction for clothes to remove dirt and knotty stains. This enables a powerful wash in each wash cycle. D68WMP01A, D68WMG01A come with a load capacity of 6.8kg, and the D75WMG01A of come with 7.5 kg load capacity. The washing machines also come with two wash programs – heavy and gentle, as well as 15 minutes of wash and 5 minutes of spin dry cycle.
The made-in-India Washing Machine is crafted with a premium design boasting a rust-proof body. This makes it optimum for the Indian weather conditions and ensuring durability in the long run. The machines are RoHS Compliant making them free from hazardous materials, which ultimately suits the green environment.
The models D68WMG01A, D75WMG01A feature a Toughened Glass Design, whereas the economical D68WMP01A model has a plastic build catering to the various preferences of the consumers. All three models have an inbuilt Shockproof and Waterproof Panel that ensures user safety during the washing process. They are priced at Rs 9490, 10490 and 8490 respectively.
Xiaomi Launched Mijia AR Glasses Camera with 15x Hybrid Zoom
The camera comes equipped with a 50-megapixel Quad Bayer four-in-one wide-angle camera and an 8-megapixel periscopic telephoto camera with split OIS optical stabilization. Moreover, the company claims that the Mijia Camera glasses can achieve 5x optical zoom and up to 15x hybrid zoom.
The Mijia Glasses Camera can be easily connected to the phone through the Mijia App. Connecting with a smartphone will enable users to quickly import photos, apply the template to a film, share pictures, and more. Xiaomi has also packed the Mijia glasses camera with a Snapdragon 8-core independent computing platform along with 3GB RAM, 32GB storage, and independent ISP so that it can provide a great AR experience.
The display on the Mijia Glasses Camera is a combination of a Micro OLED display + free-form optical prism. It has a light efficiency ratio of 60% and has also passed the German Rheinland hardware low blue light certification.
The AR glasses have cameras mounted on the sides and is equipped with multiple lenses. Even though the Mijia glasses look quite bulky in the pictures, the company claims that the device only weighs around 100g, which is great. It is priced at 2699 yuan
