Some New Gadgets Found
Xiaomi Water Purifier C1 Enhanced Edition with 5-level RO filtration unveiled
The new version has the same design and dimension as last year’s model. However, the filtration has been upgraded from a 4-stage filter to a 5-stage filter. The five filter elements include folding PP, front carbon rod + scale inhibitor, Reverse osmosis, and rear carbon rod. The five-level filtration brings the water to the level of packaged drinking water. Also, the wastewater ratio on this new version has also been upgraded from 1:1 to 2:1.
The Mi Water Purifier Enhanced version adopts a 127mm slim body and is installed under the kitchen. It is opened by 500 gallons and produces 1.3L of water per minute.
Read:
Vivo TWS Neo with 14.2mm drivers and Bluetooth 5.2 announced
The true wireless earbuds use a new technology of two-channel data transmission, which allows it to reduce the delay and increase battery life. In normal sound mode with the AAC codec, the headphones are ready to offer up to 5.5 hours of battery. While the adaptive AptX codec is working, the company promises up to 4.2 hours of operation on a single charge. But in any case, this is better than the original and more expensive model.
The Vivo TWS Neo headphones highlight the presence of IP54 certification, quick connection, Jovi voice assistant support, and touch controls. Using the latter, you can start/pause playing music, answer/reject incoming calls, change the volume, and command the voice assistant. It also has an intelligent noise reduction system that uses two microphones and reduces external noise. For example, in windy weather, or while running, and riding in vehicles.
Read:
Xiaomi launches 65W PD fast charger for around Rs 1,050
Xiaomi has launched a new 65W PD fast charger in China. The latest charger from Xiaomi offers a single USB Type-C port and a foldable pin. This makes the device more portable. The charger can power up smartphones, notebooks, and more. The new charger is also much more compact than Xiaomi’s previous adapters.
The Xiaomi 65W PD charger comes with a price label of RMB 99, which is around Rs 1,050 in India. The device charging pin can also be folded at 90 degrees for easy carrying. It can even charge the MacBook Pro and Xiaomi’s own laptops that max out at 65W maximum charging.
Read:
Xiaomi MIJIA Display Hanging Lamp launched for around Rs 1,780
The newly launched Xiaomi MIJIA Display Hanging Lamp can also get its power supply from a display, a USB adapter, and a power bank. It offers support for wireless remote control, and a handle so that you can hang the lamp on a monitor or anywhere else. The latest Xiaomi lamp also supports magnetic rotation, and has a Ra90 high color rendering index as well as preset computer mode.
The MIJIA Display Hanging Lamp also sports a customized optical lens and a photomask to avoid screen reflection. It uses the 2.4GHz wireless connection tech to pair with the remote control. The remote uses two No. 7 batteries, as per a report by ITHouse. Customers can use it to adjust the brightness of the color temperature.
Read:
Weiyuan Smart Handheld Bladeless fan is Xiaomi’s latest crowdfunding product
The bladeless fan adopts a simple but impressive design. The design is such that it blows air from a ring with no external blades. Due to the absence of physical blades, the fan will not generate dust or hurt children’s fingers. The Bladeless Fan adopts a working mechanism similar to other known brands like Dyson. The air is drawn in by a compressor in the base and then directed up into a ring. It comes out of a slit around the ring and passes over a shape like that of an aircraft wing (Coanda effect).
The bottom of the Weiyuan Smart Handheld Bladeless fan adopts a 7-wing diagonal flow impeller, which can form a high-pressure airflow into the air. When the air guide vane is pressurized due to the high airflow, the air is then pushed toward the air outlet at a wind speed of 7.52m/s.
Read:
Selpic P1 – the World’s Smallest Handheld Printer coming to Indiegogo for $99
The Selpic P1 Handheld printer is quite a useful portable accessory that can accomplish any printing jobs on the go. It is efficient in printing logos, texts, photos, barcodes, QR codes, etc. The printer can effectively print on different surfaces like metal, textiles, plastics wood, leather, paper, and other printable materials. The user just needs to hold the printer with stable hands while moving it across the material.
Selpic P1 measures 5.12*1.22* 0.94 inches in size and weighs 0.4 pounds (180 grams). It is a highly-portable printer that can be easily tucked into the pocket like a normal pen.
The lightweight, small and easy-to-use printer can work for 3 hours upon a full charge of its 7-volt lithium-polymer battery. It has the capacity to print over 90 pages of A$ paper within a single refill. Overall, the new handheld printer is quite useful for business travel, events, classes, and office work.
Read:
Oppo Enco W51 TWS with ANC launches in China for 499 Yuan ($70)
The newly announced Oppo Enco W51 TWS has a similar design to the already available Enco W31. But it is a better model with extra features like ANC and wireless charging.
It uses Bluetooth 5.0 to connect with devices and features a new updated dual-core chip. The main highlight of this TWS is its ANC (Active Noise Cancelling) function, which can reduce noise up to 35db with the help of 3 mics on either bud.
Further, the brand also claims it to have a lower latency of 94ms for gaming and video consumption. Whereas for protection, it is IP54 certified, which generally means sweat-resistant and thus can be used during workouts without any hesitation.
Read:
Mobvoi launches TicPods ANC true wireless headphones for $89
In terms of specifications, the TicPods ANC headphone comes equipped with 13mm emitters and Bluetooth 5.0 connection. It also has an IP5X certification for dust and water resistance up to a specific limit. Like previous TicPods headphones, it also features touch-sensitive controls for volume, skipping songs, and accessing Google Assistant.
The headphones feature a battery capacity of 50mAh, which should be enough for 4.5 hours of playback time with ambient noise cancellation turned on. If this feature is turned off, they should offer 5 hours of playback. The charging case has a battery capacity of 400mAh, which should be enough to charge the headphones for two full cycles.
Read:
Noise Shots Ergo true wireless earbuds launched in India for Rs 2,499
The company notes that the Noise Shots Ergo true wireless earbuds support Bluetooth 5.0 along with voice assistant (Google Assistant and Sir) on Android and iOS. These earbuds are IPX7 rated for water resistance from sweat and rain.
The Noise Shots Ergo come with a charging case with 400mAh battery and Type-C charging port. These wireless earbuds can offer 5 hours of standalone playback and 15 hours of additional playback with the charging case battery. So the total backup is 20 hours.
Read:
Harman Infinity Sonic B200 soundbar, Infinity Glide 510 headphones launched in India
The infinity Sonic B200 soundbar comes with a price tag of Rs 17,999, though it is available at an introductory price of Rs 7,299. The Infinity Glide 510 is priced at Rs 3,999, however, the company is offering it at a special price of Rs 1,699. Both the audio products are available for purchase from Amazon and Harman official website.
To start with Infinity Sonic B200, the soundbar comes with a stylish design and it comes with a 160W peak power along with a dedicated wireless subwoofer. It offers two 20W speakers and 40W subwoofer with a total 80W RMS power that the brand claims deliver deep bass providing an incredibly immersive sound for movies, music and even video games. The soundbar comes with Bluetooth connectivity that allows users to connect and pair with any compatible device. The soundbar also offers multiple connectivity options including Aux, USB and optical input.
Coming to the Infinity Glide 150 headphones, it offers a 36mm driver along with dual equaliser that provides enhanced audio experience. Users can switch from normal to bass mode with the touch of a button. The wireless headphones come with Bluetooth 5.0 connectivity and it also supports hands-free calling and it is loaded with voice-assistant integration. The headphones come with 72 hours of playtime and it offers foldable design with soft cushioned earcups. The headphones are available in Black and Blue colour options.
Read:
Redmi AX5 Wi-Fi 6 Router officially announced for 229 yuan ($32)
The new router comes with four independent signal amplifier antennas, increasing the signal strength by 4dB and increases the coverage by 50 percent. As per the company, it can download an HD movie in just eight seconds, at 1775Mbps speed, which is about 52 percent faster than Wi-Fi 5.
It also comes with support for Mesh Networking and Mixed Networking with Xiaomi’s own Wi-Fi 6 routers. For those who are unaware, Xiaomi has so far launched two Wi-Fi routers in the market this year — Mi Router AX1800 and Mi AIoT Router AX3600.
Read:
Sony WI-SP510 neckband earphones launched for Rs 4,990
The Sony WI-SP510 neckband earphones feature 15 hours of battery life feature 12mm drivers and a built-in microphone with support for HD voice calling. The earphones also support Google Assistant for voice access to music, information, and more. The IPX% protection makes the earphones a great choice for workouts and outdoor activities as they are splash-proof, sweat-proof, and even washable.
The Sony WI-SP510 neckband earphones are available in two colors, both of which are priced at Rs 4,990. These are the black and blue color variants. The earphones will be available to purchase at Sony retail stores, including both Sony Center and Sony Exclusive stores. They can also be purchased at the brand’s online portal and other e-commerce websites in India.
Read:
Sony WH-CH710N wireless headphones with 35 days battery life launched in India for Rs 9,990
Sony has launched a new wireless noise cancelling headphones in India - WH-CH710N. Priced at Rs 9,990, the product can be purchased via Sony retail stores along with major electronic stores and online commerce websites. It comes in two colours - black and blue.
The Sony WH-CH710N headphones feature Automatic Artificial Intelligence Noise Cancelling function (AINC) which constantly analyses environmental ambient sound components, and automatically selects the most effective noise cancelling filter for your surroundings.
The Noise cancellation automatically senses your environment with Dual Noise Sensor Technology. They promise to deliver up to 35 hours of battery life. Plus, with quick charging, you get 60 minutes of playback from just 10 minutes of charging.
Read:
Xiaomi has announced the new MIJIA DC Portable Fan, with airflow reaching 10 meters away
The MIJIA DC Portable Fan arrives with a few interesting features. This includes a direct airflow that reached up to 10 meters in distance. In other words, it can potentially even cover an entire room or a small house through its powerful air blow. The portable fan can also turn left and right by up to 120 degrees and up and down by about 90 degrees.
This offers it a three dimensional swing that can send air in varying angles, as per the users’ needs. The MIJIA DC Portable Fan uses a dual circulation fan that also simulates a natural wind. It is a lightweight and smart gadget, with energy saving technology, which allows it to consume less than 1kWh in 40 hours of continuous use.
The airflow from the MIJIA DC Portable Fan can reach up to 10 meters, blowing about 18 cubic meters every minute. Through its dual fan system, it can circulate the air within the room and even be used with windows open, to improve ventilation inside the house. The portable fan features a brushless motor that offers 5 different levels of wind speed adjustments as well.
Read:
Xiaomi launches the 30,000mAh Mi Power Bank 3 18W fast charge version
Tthe power bank is similar in several aspects to the Mi Power bank 3 50W version. The major difference is that it presents with support for 18W fast charging. The power bank also packs a bigger 30000mAh capacity battery whereas last year’s 50W fast charge-supporting Mi Power Bank 3 has a 20,000mAh battery capacity.
The power Bank is compatible with most digital equipment and can charge three devices at the same time. It features two USB-A ports and a USB-C port. There is also a separate USB-C port with 24W Max input for refuelling the power bank. It comes with support for several charging ratings and can charge models with such ratings seamlessly including Apple and Android phones.
Read:
