Some New Gadgets Found
Xiaomi releases the OCooker Multipurpose Electric Cooker
The OCooker Multipurpose Electric Cooker comes with an interior cooking surface made from 304 stainless steel and has a 400ml capacity. The cooker utilises a split design where the pot is separate from the heating surface.
The OCooker electric cooker also comes with the ability to retain heat, making it possible to leave hot food on top of the hotpot and still meet it hot several hours later. There is also the ability to adjust the firepower or heat intensity. The cooker comes with control buttons for switching on and also increasing or decreasing the heat intensity. It also features 7 cooking modes with different heat intensity.
Read:
Orient Electric launches new Desert Air Cooler in India
Orient Electric Limited has announced the launch of a new Orient Knight desert air cooler in India. The air cooler comes with a price of Rs 16,790.
The state-of-the-art air cooler comes equipped with IoT technology which gives you the freedom to operate it remotely with utmost ease via Orient Smart mobile app or with voice commands via Alexa and Google Assistant. The company says Orient Knight is ideal for living rooms, bedroom, shops, gyms, restaurants and closed outdoors
Orient Knight desert air features fan blades with AeroFan technology to ensure longest air delivery with low operating noise and Honeycomb pads with DenseNest technology to provide 25% more cooling with 45% more water retention. Other salient features include a large 70-litre water tank, Auto Fill function, anti-mosquito breeding, anti-bacterial filter, ice chamber, motorised louvers and castor wheels, among others.
Read:
Soundcore 'Rise' wireless Bluetooth headphones launched for Rs 1,999
The Soundcore Rise is a lightweight neckband that is designed for a secured and reliable fit without compromising in-ear comfort. The company has claimed 10 hours of music playback and 12 hours of talk time over the battery of its wireless earphone.
The headphones have 8-mm drivers and can be paired via Bluetooth with Bluetooth 4.1 version, that ensures super-stable transmission speed. The Neckband streams, up to 33ft from the device.
Its In-line remote and microphone allows users to manage music without touching the device. You can Skip tracks, manage volume, call hands-free and more. The earphone comes with the magnetic earbuds, that prevents tangling of wires as the magnetic panels of the earbuds lock together when not in use.
Read:
Xiaomi launches the Redmi TV Soundbar priced at 199 yuan (~$28)
The soundbar features two 45 x 80mm runway-type full-range speakers with 30W output capacity. The speaker is also equipped with a duct-type sound cavity. The gadget comes with two connectivity options, wired and wireless. It can be connected via S/PDIF and AUX wired connection as well as via Bluetooth. The soundbar features support for Bluetooth 5.0.
In terms of hardware, the Redmi TV soundbar is 78cm long, 6.4cm wide, 6.3cm high, and weighs 1.5Kg. It has a minimalist design and comes in Matte Black colour. The soundbar comes with an opening at the rear in case the owner wishes to mount it on the wall. It can also be mounted on top of a shelf.
Read:
Realme Power Bank 2 with 10,000mAh capacity and 18W two-way quick charging launched in India
The Realme Power Bank 2 supports 18W Quick Charge and there is also support for two-way quick charge. It adopts the USB Type-C port and the power bank itself charges faster through the 18W adapter. Realme claims it takes three hours and 40 minutes to fully charge the second generation power bank. It fully charges a smartphone with a 4,300mAh battery in 2 hours and 40 minutes. There are dual output ports including one USB Type-C port and one USB Type-A port.
Read:
Xiaomi announces Mi 18W Dual Port Charger, Precision Screwdriver Kit in India
The Xiaomi Precision Screwdriver Kit comes with 24 anti-rust precision bits and an aluminum alloy handle. This is a rather sleek looking screwdriver set which is rather convenient as well. The case itself is magnetic which means that the bits will not fall off. It has an aluminum alloy cover. Users has to press a button to open the box. The handle of the box has a rotating cap which is also designed to be anti-slip for a better grip. Here’s a look at the bits that are included in the Xiaomi Precision Screwdriver Kit.
Read:
HaierTAB Tabot, a versatile Robot Vacuum/mop launched on Indiegogo
The Haier Tabot Robot Vacuum is a 2-in1 device, as it combines vacuuming and mop functions in one. It even extends beyond as there is a handheld vacuum cleaner that can be detached and used on surfaces where the robot cant be used such as sofas.
The ultra-strong 3200Pa suction power of HaierTAB Tabot is powerful enough to lift steel balls, easily lift dirt off hardwood floors, deep clean carpets to remove hair and get rid of dust mites.
Read:
Hero Electronix introduces Qubo Smart Home security camera in India
The Smart Home Security camera is very easy to set-up and can be installed anywhere in your house within minutes. One can simply mount it on a wall or use it as a tabletop device in the baby’s room. It comes with an IP65 rating, making it weather resistant. The smart home camera comes with COVID guard feature, which uses the AI-based solution developed by Hero Electronix to detect whether a person is with a mask or without a mask. The Camera’s AI on detecting the absence of a mask will inform the user via Qubo App as a smart notification.
Qubo Smart Home security camera comes with a 1080p Full HD camera with 10x digital zoom and night vision. It also features two-way talk feature with echo cancellation for clear conversations. In terms of security, it uses the Q-Crypto framework and the brand claims that all access to the device is only from authenticated and authorized users.
Read:
Xiaomi launches Fengmi 4K Laser Projector Pro: 2400 ANSI lumens,150-inch screen
The Fengmi 4K Laser Projector Pro brings support for 4K resolution which is four times the resolution of a 1080p screen. For a giant 150-inch screen which it supports, that means a mammoth screen on ultra-sharp and clear content. The Pro version is powered by a high-performance Amlogic T972 chip with a maximum clock frequency of 1.9GHz. The chipset is said to have a performance improvement of 63% with 55% reduction in power consumption compared to the Amlogic T962 chipset used on the previous generation. The chipset is also claimed to the first to support 8K video decoding.
Read:
Belkin’s latest smart speaker+wireless charger and 3-in-1 charging dock now on sale
The star of the pack is no doubt Belkin’s Soundform Elite Smart Speaker + Wireless Charger which combines wireless charging capabilities with speaker technology from Devialet. The smart speaker looks very much like a HomePod but one with the top cut off to provide a wireless charging spot for an iPhone. The speaker is also compatible with Google Assistant. It comes with a $300 price tag.
The second product is the Boost Charge 3-in-1 Wireless Charger priced at $120. The wireless charger can be deployed to charge an ‌iPhone‌, AirPods, and an Apple Watch all at once. The gadget adopts a sleek, compact design which includes an upright charging platform for the phone as well as a charging puck for the ‌Apple Watch‌. There is also a space between the ‌Apple Watch‌’s band to charge the ‌AirPods‌.
Read:
Skullcandy introduces new range of wireless earbuds
Skullcandy has announced the launch of new range of wireless earbuds. The company has introduced Skullcandy Push Ultra, Indy Evo, Indy Fuel and Sesh Evo wireless earbuds.
The Push Ultra comes with premium features and it is focused for outdoor workouts. The earbuds come with moldable ear hooks that provide secure customisation. The earbuds offer 40 hours of battery life with a charging case. They are IP67 rated making them waterproof, dustproof and sweatproof.
The Indy Evo and Fuel comes with wireless charging features, multi-function button. The Indy Evo offers a battery life of 30 hours. Lastly, the Sesh Evo is the cheapest model from the company and it comes with a battery life of 24 hours. The wireless earbuds offer improved connectivity options along multifunction buttons for different controls.
Read:
Gionee GBuddy 10,000mAh wireless Power bank launched in India for Rs.1299 (~$17)
The GBuddy True Wireless Power Bank adopts a design which looks like a regular power bank but on one side of the flat surfaces is a 5V wireless charging pad along with a digital power meter that displays the charging level.
The Gbuddy wireless power bank adopts an all-metal body. It features a single USB-A port that can be used to charge other devices. The port has a 5V/2.4A rating. In addition, there is a micro USB input port rated 5V/2A and a USB Type-C input with the same 5V/2A rating. It can simultaneously charge devices through the wireless charging pad and the USB-A port.
Read:
Xiaomi launches Mijia smart electric Kettle 1s in China
Xiaomi says the kettle has capacity of 1.7 litre. It has a button which makes sure the temperature remains at 55-degree Celsius, making the water suitable for drinking.
It generates power via a 1800w high-power heating ring, something which is also there on the Pro model. Xiaomi says the kettle can boil the full quantity of water in around six minutes. It comes equipped with British Strix thermostat which is able to control the temperature and stop heating if the water is boiled.
The kettle has been built to insulate the heat from the outside. This has been done using the double-player anti-scalding design. Because of which the person can easily hold the kettle even when the water is hot inside it. Talking about other features of the kettle, it’s easy to clean, offers triple safety and protection from electric shock among others.
Read:
Xiaomi launches Mi Inkjet All-in-One Wireless Printer for a price of 499 yuan ($70)
Xiaomi has today announced its new Mi Inkjet All-In-One Wireless Printer in the Chinese market. The device, which is priced at 499 yuan (approximately $70) is currently up for pre-order with a deposit of 50 yuan (~$7) and will go on sale from 11th June.
This new wireless inkjet printer from Xiaomi comes with three modes of operation — printing, copying, and scanning. Although one of the features of the printer is wireless connectivity, it still has supports for wired USB connection.
The new Mi Inkjet All-In-One Wireless printer has a visual panel on the device for settings and the company says that the drivers will be automatically installed on the computer when it is connected for the first time.
Read:
Smartmi DC inverter floor fan 3 with built-in battery, Bluetooth remote launched
The Smartmi floor fan 3 has a built-in negative ion generator, which is claimed to be able to sterilize and reduce dust and protect sensitive people. The fan uses a Japanese Minebea DC brushless motor with seven feather blades which enable a noiseless operation. The blade and its protective cover are manufactured from ABS plastic.
The floor fan has a built-in 33.6Wh battery, which can be used wirelessly for up to 20 hours and weighs 3.5Kg. When plugged in, it will be fully charged in 4 hours. The fan has a total height of 960mm. The frame has a display strip which shows the battery level, WiFi connectivity level and a few other parameters when the fan is working.
Read:
