Some New Gadgets Found
Meizu launches a wireless charging pad, GaN charger, Backpack and more!
Meizu GaN three-port charger features an ultra-high 65W power support. It is fully compatible with QC3.0, FCP, PD3.0, AFC, PPS, PE2.0 and other fast charging protocols. The charger is designed with three ports – two USB-C and one USB-A output port. Any single port can output 65W full power when used.
The charger comes with up to 27W power support for the Meizu 17 Pro and can also provide up to 10W output for other Qi-standard gadgets.
Read:
Xiaomi crowdfunds the world’s first zero-blue light Bedside Lamp
The bedside lamp features an LED light source and is developed by scientists from the Chinese Academy of Sciences of Nanchang University. The lamp uses a high-efficiency yellow LED as the core and red LED to achieve a phosphor-free, low colour temperature pure LED light source. This design is said to be different from the blue light filtering method adopted by similar products on the market. Instead, the Midian Zero-blu-ray Bedside Sleep Aid Lamp eliminates the use of blue light from the source and is entirely blue light free. Thus, will not harm the human eye structure, even for babies.
Read:
Huawei’s Honor Ultra-wide-angle Natural Wind Fan with app support launched
Honor ultra-wide-angle Natural Wind Fan has the qualities of softer wind speed, three-step assembly of the whole setup, DC frequency conversion and so on. The fan uses a Japanese Minebea DC frequency motor which has lower power consumption and less operating noise. The low-end operating sound is as low as 22.2 decibels.
Compared with ordinary electric fans that can only blow within a small range, the ultra-wide-angle natural wind fan head can swing up to 120 ° to the left and right. You can also manually tilt it up to tilt 90 ° such that it faces the ceiling directly. With the ultra-wide-angle wind output, it can effectively accelerate indoor air circulation and balance the room temperature. The fan’s rotor has a total of nine blades.
Read:
360 65W GaN Charger with three ports and foldable pin launches for 169 Yuan ($24)
The new 360 GaN charger is similar to the Meizu SuperCharged GaN charger released at the launch of Meizu 17 series. Both have three ports – 2 x USB Type-C (65W, 30W) and 1 x USB Type-A female (24W), in addition to foldable electric pin.
Being a Nitride charger, it is comparatively smaller in size than the standard charges that utilize silicon. It measures only 76 x 39 x 34mm in dimensions for a 65W charger weighing 144g For context, it is 45% smaller than Apple 61W charger and 40% smaller than other common 65W chargers.
Read:
Xiaomi launches the MIJIA Smart Clothes Dryer for 899 Yuan ($126)
The MIJIA Smart Clothes Dryer, as the name suggests, is a product that helps dry clothes. Although, how it does so is what sets it apart from conventional home products. It adopts a crossbar design alongside various hooks that enables it to carry a total load of 35 kilograms, while its bar can be extended up to 2.2 meters. It hangs off of the ceiling and can be pushed upwards or lowered with a light push or lifting action.
In terms of use, a person can lower the MIJIA Smart Clothes Dryer up to its maximum length to hang clothes and then proceed to raise it again. This form of design also helps in saving space on the inside of houses. The device has an LED indicatory as well, which is also large enough to illuminate the machinery during evening or night if needed.
Read:
Xiaomi launches Mi Router AX1800 with Wi-Fi 6 support for 299 yuan ($42) in China
It features hidden dual-band high-performance antenna that aims to offer a strong 360-degree signal coverage. Both frequency ranges — 2.4GHz and 5GHz have two Qorvo high-performance independent signal amplifiers which increased signal strength by 4dB which should increase coverage by 50 percent.
The router comes packed with 256GB of RAM and has Mesh Networking support for seamless signal coverage in the house. The Xiaomi Mi Router AX1800 supports connection of up to 128 devices simultaneously.
It is powered by a quad-core Qualcomm APQ6000 chipset with dedicated NPU, and comes with support for OFDMA technology (Orthogonal Frequency-Division Multiple Access) which allows the router to send data to multiple terminal devices using only one transmission.
Read:
Xiaomi launches the Mi Air2 SE TWS Earphones priced at 169 yuan (~$24)
In terms of appearance, the Mi Air2 SE adopts a similar half-in-ear design as its sibling but comes with a unilateral weight of just 4.7g. The Mi Air2 SE utilises a built-in 14.2mm composite moving-coil diaphragm and has an impedance of 32 ohms. The earbud supports SBC / AAC audio codec, Bluetooth 5.0 protocol, dual noise reduction, etc. Each of the earbuds supports up to 5 hours of playback on a full charge. The charging box can extend the battery life to 20 hours. With a USB-C interface, the charging box can be refilled quickly.
As for functionality, the Mi Air2 SE is said to have deep customization with Xiaomi’s custom MIUI ROM. When the charging box is opened, the phone will pop up the headset connection interface. After connecting, you can check the power of the headset and the battery level of the charging box.
Read:
Xiaomi backed Jisu Life launches cheap handheld fans that are perfect for summers
The new Jisu handheld fans come in the same series but they are different from each other in terms of both size and features. The smaller model is called ‘Mini Version’, whereas the slightly larger variant is called ‘Jade Edition’.
Both the models feature brushless DC motor but the smaller version has four blades compared to 5 blades on the larger model. Another difference is the former has aromatherapy function, whereas the latter can be used as a power bank.
Read:
Honor announces Clea Antibacterial Wireless Vacuum Cleaner & ULTTY Sterilization Bladeless Fan
This wireless vacuum cleaner features 10-cone cyclone dust separator and 350W 100,000 rpm motor. With a suction power of 125W, it is capable of removing minute dust.
As the name suggests, it also sterilizes the surface after cleaning dust. The vacuum cleaner’s sterilization is rated as high as 99.99% Further, its battery is rated to run for up to 65 minutes on a full charger, It comes with necessary brush kits and being a smart IoT product, it can connect with an app and record the number of calories consumed while using it.
This product is a bladeless fan that can output both sterilized cold and hot air based on weather. It features a patented turbocharging technology to provide a stable flow of strong cold and warm air.
It supports four levels of airflow speed and changes the condition of air based on the room thermal reading via accurate temperature sensing. As for appearance, it comes in two colors namely Black and White.
Read:
ZOOOK Infra Temp thermometer launched at Rs 3999, checks your temperature without contact
French brand ZOOOK, has launched a contact-less Medical Grade thermometer developed in accordance with the requirements in the wake of Covid-19.
The infrared digital dual mode thermometer, named Infra Temp, enables quick detection of the temperature of a body or a surface. ZOOOK Infra Temp is available on Amazon and is priced at Rs 3999. Without touching the surface, it acquires accurate temperature reading within one second.
The non-contact thermometer, which comes with a one-year warranty, has an inbuilt alert mechanism and rings an alarm if the temperature is beyond the permissible limit. Also part of the mechanism is light-based alerts, wherein screen light turns white, orange and red for normal temperature, high temperature and fever, respectively.
Read:
Logitech Circle View camera with built-in privacy controls launched for $160
The Circle View is capable of recording 1080p videos and has a wide 180-degree field of view. The camera can capture infrared footage at night up to 15 feet away. The camera only supports WiFi 2.4GHz.
As regards working with Apple’s HomeKit smart home system, the camera is capable of streaming videos, send alerts about animals, people, and vehicles, and store recordings in iCloud if you are on a plan with enough storage. There’s no Android support but we could see that happen in the near future.
Read:
Xiaomi Mi camera SE PTZ launched with 360-degree viewing angle
The camera comes with a 940nm infrared fill light. The brightness of the fill light is controlled using optical structure and software optimization. The camera also allows for stronger permeability with the night vision. The smart camera also uses a new generation of H.265 video encoding technology. Those using this smart camera will be able to watch 1080p HD videos smoothly even under 1M uplink bandwidth. According to GizmoChina, there is support for 32GB microSD card slot as well as NAS or cloud storage support.
The Xiaomi Mi camera SE PTZ comes with a retail price of RMB 149 (around Rs 1,600).
Read:
Roborock T7 Pro Robot Vacuum cleaner with dual-5MP surveillance cameras launched
The major upgrade on the Roborock T7 Pro is the ReactiveAI obstacle recognition sensor onboard. The system deploys two cameras in front which improves its ability to avoid obstacles. The cameras also afford the user the opportunity to view the video of the vacuum cleaner in operation via the app.
The T7 Pro is equipped with Roborock’s new RR Mason 7.0 real-time data management algorithm which is responsible for managing and distributing the environmental data collected by the sensors. The data is then transmitted to the “perception and mapping algorithm” for data fusion and analysis and then the “navigation and motion algorithm” performs dynamic navigation and planning based on the analysis results.
Read:
Xiaomi launches XiaoAI Art Speaker in China for 299 yuan ($42)
After teasing it a few days ago, Xiaomi has today officially launched the XiaoAI Art Speaker in its home market. With this launch, it has become the first XiaoAI speaker from the company to come with a metal body.
It has a textured metal body design with 16 million color aurora light strips. The outer body has a matte fine stone pattern and comes with seamlessly integrated touch buttons. The device comes packed with a 2.5-inch full-range speaker.
There’s also a special paper carcass and voice coil and a U-shaped duct for bass enhancement, along with DTS professional sound tuning and Stereo 2.0 support. So, two of these can be connected together for a true stereo sound experience.
Read:
Lumi launches the Aqara Smart Curtain Motor A1 (WiFi version) for ¥399 (~$56)
The Aqara Smart Curtain Motor A1 is a Wi-Fi-enabled device which can realize many functions such as timer switch, voice control, and remote control directly from the Aqara Home app without the need to connect with a smart home gateway device. The app equally allows homeowners to customise the opening and closing degrees from the smartphone.
Further, the smart curtain motor can be connected to the Xiaomi AI speaker, making it possible to perform tasks such as control the opening and closing of the curtains and adjust the opening and closing ratio simply by giving instructions to XiaoAI voice assistant. However, if you want to link it with other IoT gadgets like the smart door and window sensor, wireless switch and MIJIA smart door lock, you need to connect it to the gateway device.
Read:
