Some New Gadgets Found
Xiaomi launches the portable DOCO Ultrasonic Dry Misting Fan for ¥69 ($10)
The fan utilises a DC brushless motor with a lower noise level, low power consumption and doesn’t get hot even with prolonged usage. The lifespan of the brushless motor is said to have been increased by 50% compared to other such fans.
It comes with three-speed wind speed control while the misting speed can be adjusted in two different levels. For the fan, the first gear has a rotational speed of 3200 rpm. The rotational speed of the second and third gears are 4100 rpm and 5100 rpm respectively.
Compared to the traditional fan, the misting fan can cool the temperature by about 3 ℃. There is a compartment for water and the water is blown through misting nozzles or a centrifugal misting system, producing a fog of water droplets so fine they can barely be seen. This fog is so fine that your skin and clothing won’t feel wet; instead, you’ll simply experience a fresh coolness.
Read:
Xiaomi Youpin launches Morfun Pocket Hot Water Dispenser, boils water in just 4 seconds
The primary selling point of the Morfun Pocket Hot Water Dispenser is its portability. Its body size is 117x62x190mm, making it a pocket water heater that allows it to be carried in a bag, suitcase, and more. Another notable aspect regarding the product is its heating technology, which uses the new non-thermal bile boiling technology. This method allows for the water to be boiled within the container in just 4 seconds.
Furthermore, the top of the gadget also sports touch screen enabled display, which allows users to control or adjust the water temperature in real time. The Morfun Pocket Hot Water Dispenser has 5 temperature settings that include 45°C, 60°C, 85°C, and 100°C. So, users can choose the amount of water and its temperature at the same time. The water dispensing option includes 120ml, 250ml, 360ml and 500ml.
Read:
Anker Soundcore 'Life Note' True Wireless Bluetooth Headset launched in India
Soundcore Life Note comes with waterproof casing to resist water ingress. The IPX5 protection makes the device ideal for sweating it out at the gym or running in the rain. Its GripFit technology ensures control and extremely comfortable use. The earbuds are ultra-lightweight and are designed for a more compact look
Life Note’s graphene coated drivers produce precision oscillation for superior sound across the entire frequency range to deliver immersive sound. Bass is further enhanced by upto 43% by the exclusive BassUp technology which analyses low frequencies in real time and instantly intensifies them.
Read:
Zhiyun Smooth X smartphone gimbal launched to aid smooth video creation for $59.99
Zhiyun Smooth X smartphone gimbal can easily fit into the bag or pocket for easy portability. the new gimbal enables to record stable and steady video without the need of any additional accessory. The Smooth X is easy-to-use gimbal with only three buttons to effectively control it. The rotatable axis easily folds and holds the camera position at different angles. It can smoothly shift between horizontal and vertical positions using Smooth-X Quik ROll function.
The Zhiyun Smooth X has its smartphone app which further improves the possibilities. Users can unlock smart filmmaking after downloading the app on their respective Android or iOS device. It reduces the tedious editing or processing work and integrates custom filters, effects, music, and movements. Other features of the ZY Cami app are as follows:
Read:
Xiaomi crowdfunds the Wanbo T2 Free Projector priced at 599 yuan (~$85)
The Wanbo T2 Free Projector has a 150 ANSI lumen light source and is compatible with 1080 pixel resolution. The device can project on screen sizes ranging from 40 – 120 inches from a distance of 1.5-3.0 meters. The projector will need to be focused manually and the scrolling button to do that is located at the rear. It also supports ±40° vertical keystone correction.
Projectors are known to be affected by dust especially when it settles on the lens, causing black spots on the screen and poor heat dissipation in the optical part. The Wanbo T2 Free uses a fully enclosed internal circulation heat dissipation optical machine technology. The design can completely eliminate the impact of the buildup of dust on the optical path and thus extend the lifespan of the projector.
Read:
Xiaomi XiaoAI Mouse announced for crowdfunding at 129 yuan ($18)
The new mouse looks similar to the Mi Wireless Mouse previously launched by the company. However, it adds a new button which when long-pressed, triggers voice assistant.
It comes with an antibacterial casing, a metal roller, and a hidden microphone. It has a USB Type-C interface and is powered by a built-in 750mAh battery which the company claims can offer 30 days of usage and 180 days of standby time.
It comes with dual-mode connectivity options — Bluetooth and USB. It can also be connected to two computers at the same time. Users can hold the left and right keys for about three seconds simultaneously to switch between the computers.
Read:
Sony launches WF-XB700 and WF-SP800N true wireless headphones in India
The Sony WF-XB700 and WF-SP800N boast of an IPX4 and IP55 rating respectively for water and dust resistance. They also offer an easy way to access controls but in different ways. The WF-XB700 earbuds get tiny physical keys to let you play, stop, or skip through tracks and adjust the volume. For WF-SP800N, the smart control technology enables users to play, stop or skip through music and adjust the volume by simply placing a finger on the right earbud and then turn down the music by placing a finger on the left earbud.
The Sony WF-XB700 true wireless earbuds price is Rs 9,990 for India and these will be made available in Black and Blue color options. On the other hand, the Sony WF-SP800N headphones will be available for Rs 18,990 and in three color options of Black, Blue and White. Both these Sony true wireless headphones are up for purchase staring today.
Read:
Boult Audio Tru5ive Pro true wireless earbuds launched in India for Rs 2,799
The Tru5ive Pro TWS earbuds feature the latest QCC3020 chipset, upgraded aptX codec, micro woofer driver construction, and a high sensitivity mic to deliver good audio quality. The device also comes with a Bluetooth 5.0 with dual-mode compatibility. This lets the buds automatically pair themselves with a phone as soon as they are removed from the case.
The Boult Audio Tru5ive Pro gaming-oriented TWS earbuds also feature ultra-low latency, 6-8 hours of single playtime with a total of 24 hours of playtime with a charging case. The battery life makes sure gamers need not take frequent breaks to charge their earphones. The Ultra-Low latency also means the buds deliver minimal delay between sounds from your device and the buds themselves.
Read:
Western Digital introduces 1TB pendrive for USB Type-C smartphones in India
The company claims that the latest pendrive comes with seamless transfer of content between USB Type-C smartphones, tablets, laptops, and computers. The pendrive comes with an all-metal body and it is loaded with USB 3.1 Gen 1 drive that offers a read speed of up to 150MB/s.
SanDisk Ultra Dual Drive Luxe USB Type-C Pendrive is available in capacity options of 32GB, 64GB, 128GB, 256GB, 512GB, and 1TB. The Pendrive comes preloaded with the SanDisk Memory Zone app. Once installed on the smartphone, the app helps organize content from different devices, whether it's on the phone, a microSD card, or on the cloud, in one view. It also backs up photos, videos, contacts, and social media accounts.
Read:
Sony launches Reon Pocket, a wearable Air Conditioner
Sony has just launched a new product in the market that will likely be quite useful in the Indian subcontinent. The product that we are talking about is the new Sony Reon Pocket, a wearable Air Conditioner (AC). As per the information available, the device is currently available on sale in the market. The interesting thing to note about this device is that it launched as a crowdfunding project back in August 2019. Now, almost a year after the initial reveal, the device is available for sale along with design, pricing, and more. Let’s check out all the details regarding the Sony Reon Pocket AC here
Read:
Play launches PlayGo T44 true wireless earbuds for Rs 2,999
India-based startup Play has launched new set of affordable wireless earbuds and headphones in the country. The company has come out with two products T44 and N82 out of which the first one gets a price tag of Rs 2,999. The T44 wireless earbuds weigh around 3.5 grams and it gets a familiar design.
These earbuds feature echo cancellation and noise reduction for improving audio quality. It gets IPX4 rating making the earbuds sweat-proof. The charging case comes with USB Type C port which can charge from 0 to 100 percent in less than 2 hours. The T44 offer battery life of 20+ hours with the charging case. And with the fully charged earbuds you get 4+ hours of music playback support. The company will reveal pricing and details for the wireless headphone in the coming days.
Read:
Samsung HW-Q950T and HW-Q900T soundbars announced
Samsung has announced the launch of a new Q-series of premium soundbars for the market. The brand has introduced HW-Q950T and HW-Q900T soundbars.
The company claims that the soundbars are tuned at the Samsung Audio Lab in Valencia, California. To start with HW-Q950T, it comes with an audio quality of 9.1.4-channel, which is the maximum number of channels for the currently available home-theatre system in a single soundbar. It comes with two wireless rear up-firing speakers along with left and right wide channel speakers to provide the previous 7.1.4-channel system, allowing the audio output to express the motion on the screen.
Read:
JBL One Series 104-BT and 104-BTW speakers launched in India
The speakers come with a special launch price of Rs 11,499 and it will be available for purchase from Flipkart starting today. The company has also revealed that customers will get a 10 per cent prepaid discount on the purchase of the speakers on all card transactions along with no-cost EMIs.
The latest speakers are meant for the professionals and enable content creators and audio professionals to stream accurate, studio-quality audio via Bluetooth or playback audio using a standard wired connection. The JBL 104-BT comes with a coaxial driver that pairs a contoured low-frequency woofer with a soft-dome tweeter for professional audio output. The cabinet comes with a low-frequency port that works with the driver to deliver low-frequency performance down to 60Hz. It comes with a Class D power amplifier that distributes 30 watts per speaker. It also features acoustic design, which is optimized for desktop.
Read:
Huawei FreeBuds 3i launched in India for Rs 9,990
Huawei FreeBuds 3i comes with an in-ear design. There is a total of four tips with different sizes to make sure the earphones fit perfectly. Huawei FreeBuds 3i have 10mm dynamic drivers which claims to deliver authentic, balanced audio with powerful bass.
It has a three-microphone system, two on the outside and one on the inside in the ear canal, for active noise cancellation and voice calls. The company claims that the Freebuds 3i is capable of reducing the noise level by up to 32dB.
The Freebuds 3i support Bluetooth 5.0 connectivity and charges through a USB-C port. The 37mAh battery capacity is claimed to last for up to 3.5 hours on a single charge. The case charges via USB-C and will deliver a battery life of up to 14.5 hours.
Read:
Viomi VSLAM Smart Robot Vacuum Cleaner launched for 1099 yuan (~$157)
The Viomi VSLAM Smart Robot Vacuum Cleaner uses a Japanese imported NIDEC fan with a large suction power of 2600Pa, and 4-speed suction mode adjustment. The new-generation cleaning system which has extended bilateral brushes only collects dust and does not raise dust. With the V-shaped anti-winding roller brush, it can remove difficult-to-clean hairs in one go.
The robot vacuum cleaner supports three sweep and mop modes which include an integrated sweep and mop, single sweep, and a single mop mode. The vacuum cleaner has a slim body which is just 7.8cm thick, making it easy to penetrate under the bed and clean under the sofa.
Read:
