Sleek Silver Hyundai Verna 1.6 SX VTVT - Sleek Indeed!!
Mumbai MH01/MH46
bottom line is hyundai would be the korean range rovers.
you need to experiment a lot to find the best efficient speed and driving pattern. engine is tuned for max efficiency on long highway stretches but body and suspension is tuned for a city drive.
What i have found is quick gear changes and being in a higher gear most of the time seems to increase the FE a bit. Rather then 8.7 it goes upto 9.3 kmpl.
Mumbai MH01/MH46
yeah but i noticed when i get to 60 faster and then shift to 5th i get more fe then being slow to reach to 60 and then changing, also if i change above 2000 rpm the fe is good. I wonder how they even programmed their gear shift suggester(their eco mode)
and when your in 5th gear all speeds between 80-120 give good fe not below that.
great [thumbsup] you gave a nice wash before polish right [;)] ?
and you polished the black trims as well. what did you use for the black plastic in the grill and the side view mirror ?
Thread Starter #187
Yep buddy, washed the car well before the polish.
Thats a nice work, clean finish whats the products used here Aristo!
Thanks Bazooka - I would consider this as a certificate from a pro!!
I used meguiars quik wax.
Mumbai MH01/MH46
ahh no wonder the gloss is top notch cause its a meguiars gloss, the car is still glossy after almost a month of using it still beads well.
but what did you use for the black plastic trims?
Thread Starter #189
I used a plastic / rubber polish bought from a local shop - I dont remember the name on top of my head. Will check and post here once I get back home.
Thread Starter #193
I used something called Vista car care. It is good on Vinyl and plastics. Something like what allhyundaicars has posted on the pic above.
so aristo i went through all the posts and saw you said you got 16 kmpl on highways. i still don't have any plans for a highway trip but
what's the current fe your are getting in city ? you mentioned 10.2. now what's the current fe you are getting [confused]
