Bit the bullet and bought myself a pressure washer from amazon .The brand is StarQ model W3B. Have used it about a dozen times and have found it to be very useful .Added a snow foam cannon to it and it has become a weapon
![Cheers [cheers] [cheers]](https://www.theautomotiveindia.com/forums/images/smilies/Cheers.gif)
.Pressure is fantastic.The nozzle is adjustable to create a laser water jet with high pressure or a wide fan pattern for watering plants .
PROS:
1)conserve water : I can routine wash my SUV with just 1.5 buckets of water .Detailed wash with foam cannon takes about 2.5 buckets of water only .
2)save time: clambering all over the SUV with hose and wash mitt was time consuming. Now i can wash 1 SUV ,1 hatchback and 2 two -wheeler within an hour!
Tough grime and hard to reach areas are simply a breeze to clean due to the high force especially under-body and the suspension areas .
3)the machine has self priming motor so direct water source is not needed from water tank;a bucket of water with a hose dipped in it is enough.
This i was able to use as I had to clean the terrace of algae.
4) compact easily stored in my tools cabinet
CONS:
1)the inlet and outlet threaded pipes on the machine are made of plastic which eventually can be damaged making usage a problem .
2)no storage case
3)buying quick disconnect accessories are difficult ;would be great if the company markets them along with the product.
