Thread Starter #182
mayankdixit
kanpur
My XXL sized scissor set. As can be compared by my hands and fingers near the grip,they are really big sized scissors-viz. 8, 9, 10 ,and 12 inches from left to right.
Cross wheel spanner for scooter cars and bike.Larger one is for XUV. Very handy there. Y shaped spanner is for my scooty.
Speeder Brace with Steel Handle, 1/2" Drive, 440mm Length.
T-shaped spanner set. I have almost all the sizes with me.
L-shaped spanner set in phosphate finish.This caters for cars and SUV sized lug nuts viz 18,19 and 21.This thing ,because of this peculiar finish never rusts, despite of rough usage like being left out on a wet floor overnight,and being forgotten inside the bucket with car wash foam etc etc..
Hi doc,
Is this pump actually effective for car tyres? It looks so small!
BTW here is what I brought
http://www.theautomotiveindia.com/f...ytvs-tdi-22-vacuum-cleaner-tyre-inflator.html
Not sure - did not try yet.
But, last week, back tyre of my scooter got punctured and brought a puncture guy to remove the particular wheel and take to his place for attending the puncture. He brought couple instruments to remove the wheel, but after seeing my scooter (Maestro Edge) he said it is different fit and not able to remove here and wanted to take the scooter to his place.
He enquired if any foot pump available and I got it one from my neighbour who use the pump mainly to inflate his cycle, which was useful to inflate around 80% of air in my scooter tyre and that too within a minute or so.
So, at least I can use it for scooter tyres, even if not fully useful for car.[:)]
Hubli
I have bought Dewalt Cordless Drill Driver from Amazon on last Great Indian Festival sales. Being a fan of Stanley B&D brand, I'm proud to add this machine to my collection. [:D]
Quick review: Along with cordless drill driver, it includes charger, 1 extra battery, 109 unbranded accessories set and a nylon bag to carry machine only.
Drill feels solid and powerful. I did some testing and it can remove tight screws easily. Sometimes the screw head may break if its too tight but correct torque setting will prevent it. Battery takes 2 hours to charge and I'm yet to know how long they last. Extra battery will be helpful when there is prolonged work. Provided 109 accessories is generic so quality is average and you can see one bit is already rusted but the whole kit is VFM.
Cost: Rs 5,600 effectively (7k listing offer, 10% bank discount & 10% cashback)
Link: Amazon
p.s Also bought oil can (Rs. 200) so I can use used gear oil for general purpose.
Hubli
does the drill have light source which can fall on the workplace when in use ?
Yes, there is a small led right below the chuck but it has drawbacks. 1. The chuck obstructs the light so the screw (for example) will not be clearly visible. 2. Everytime the trigger is pressed, light turns on. Instead a separate switch would have helped to turn on light before pressing trigger and set it off when not needed.
Some expensive drills have led light away from chuck or on battery mount and also separate switch.
Thread Starter #190
mayankdixit
kanpur
It is a very useful product. Congrats. The price is okay too. The drill bit box is very interesting. Its having a lot of small tools and bits.
How much is the capacity of the oil can? JCB brand is good.
Hubli
Thanks. Yes, accessories will be very helpful for my woodworking projects and other DIYs. I have got few items from gearbest; will share pics tomorrow.
The oil can is 1 pint. I think JCB is just a sticker and has no direct link with JCB company. Initially it had original logo (as shown in listing pics) but later manufacturer changed it, may be due to complaint from company. However, quality of the can is excellent and works nicely.
Hubli
Recently I got these tools and accessories from gearbest. Description and cost of each item is given below.
Center Punch - Spring loaded punch for making pilot hole. With this tool I can make pilot hole with one hand. - Rs. 186/-
Socket Adapters - Adapter for 1/4, 3/8, 1/2 sockets, short and long each. With these I can attach different size sockets on my cordless drill. - Rs. 340/-
Drill Bit Collar - Stopper for drilling depth. No need to apply tape on drill bit and watch till it touches the surface. - Rs. 210/-
Right Angle Clamp - To hold two materials at 90 Degree for fastening. Now I can make frames, boxes, cupboards, cabinets easily. - Rs. 272/-
Stanley Nose Plier 84-096-23 - Rs. 126 (Got this from Flipkart)
Thread Starter #193
mayankdixit
kanpur
I have seen right angle clamp for the first time.Its a unique tool.I have had c-clamps of all sizes.I will post some pics of them soon.
You have got a very good price for these tools.Presentation is nice too.Where are you storing them at present.Just asking,if you have a dedicated tool box.If yes,well then ,pics would be welcome.
Thread Starter #194
mayankdixit
kanpur
Here are my C-Clamps. I have most of the sizes. For those who are not aware of these ,A C-clamp or G-clamp is a type of clamp device typically used to hold a wood or metal workpiece, and often used in, automotive ,carpentry and welding. They are very handy when working on brake calipers. These C-Clamps have been used in carpentry for quite awhile, they help hold pieces steady. When we stick 2 pieces of wood together with fevicol, it may end up twisting and getting deformed. But by using a c-clamp to hold it in place while it dries ,we can prevent that to a large extent.
Thread Starter #195
mayankdixit
kanpur
Taparia steel centre punch.This thing doesn't rust.Maybe due to phosphate finish.Its very sturdy and has not ballooned or ruptured( in the head) even after repeated hammering with a heavy hand.
Aviation snip/cutter for tin. It's a dangerous piece of equipment in that One has to be cautious with fingers here,while using.
Taparia and PYE Screwdriver set with a testers.
Ball point hex allen keys set Note the long endings of this one. Its very typical,not used commonly but when a slot like this appears no other allen keys work in its place.
