No dhaya, Rs. 2820 for fuel filter, clutch pedal nut, WD40, door switch & labour cost of fuel filter, door switch, spring pivot & clutch pedal adjustment.
best part about mahindra's A.S.S is cost of spares are cheap but labour charge is sky high.
this is what i read from the scorpio website:
so if i look at my bill,
1) labour charge for replacing fuel filter: Rs. 230 = 0.61 hrs = approx 37 mins (do they need 37 mins to change a fuel filter?)
2) door switch: Rs. 80 = 0.21 hrs = 13 mins (reasonable)
3) clutch pedal adjustment = Rs. 110 = 0.3 hrs = 18 mins (reasonable)
4) spring pivot DR SH = Rs. 380 = 60 mins (i dont know what this means!)
Labour charges for services rendered are by an hourly flat-rate as per A, B, C classified cities. These have been pre defined by M&M and each job is charged by the standard number of hours that is necessary for the job. (The calculation will be done on the basis of - hours for job multiplied by flat rate for the city. For example: If you’re in Mumbai, where the hourly rate is Rs. 375. A two and half hour job would be charged at Rs. 375 x 2.5 hours = Rs 937.50.
