I was overwhelmed to have a Car Ionic Air Purifier, attracted to those words in the advertisement … Oxygen, Ozone ... as they are always perceived to be good for healthy living!
Overenthusiastically I have ordered one such gadget (MODEL JO-6271) after thorough marketing research as I came across many fake ones those only emit beautiful light.
I ensured that I am ordering the really working one though little expensive.
But after ordering the same my Doctor Mind started asking me ‘
Are they really SAFE? ’
NOT AT ALL!
Ozone is found naturally in the earth's atmosphere and it protects us from the sun's harmful rays. However, Ozone produced by air purifiers can be harmful. Companies selling these air purifiers claim that they are using the Ozone at safe levels to clean the air, but the truth is that the same ozone emitted by the air purifier can cause respiratory illness.
The real Ozone layer which is far away from us acts as a filter (to avoid harmful UV rays reaching earth) but If you are breathing it, it is always the bad kind. Ozone is a toxic gas with vastly different chemical and toxicological properties from oxygen. Breathing ozone will cause inflammation of lungs, worsens Asthma.
Regarding manufacture’s claim of killing germs, Ozone can be used to combat viruses, bacteria and mold, for this to have any measureable impact, the ozone would need to be present in qualities far above what humans can safely tolerate.
Studies have also found that Ozone can cause rubbers, upholstery, and paint to deteriorate more quickly. If ozone can eventually crumble the paint and the material covering seat / sofa, what can it do to our lung tissue?
Ionic air purifiers will cause particles in the air to fall to the floor. Therefore, the particles falling from the ionic air are attracted to the room's surfaces. As a result, the area around the ionic air purifier tends to get dark and dirty. The science behind it is a negative ion generator is the main part of an ionizer or ionic air purifier & that negative ions are oxygen atoms or molecules that have an extra electron. These negative ions are attracted to the positive particles in the air. Ultimately, both the negative ion and the positive particles join together in the air. This union results in the particles in the ionic air becoming too heavy. Due to their own weight, they ultimately drop from the air to the floor.
Therefore electronic air purifiers should never be recommended and one should go, if at all needed, for approved mechanical air filters like 3M Filtrete™, True HEPA (High Efficiency Particulate Arrestance) Air Purifiers.
Foot Note:
You may be wondering what happened with My Aliexpress order. The item came damaged, applied for refund. Fortunately I am and my money saved.
ESCAPED
