Hello All,
Its good to see post from Doctor after ages..
Finally I have upgrade my stock horn to Bosch Symphony and today will share the process. Horn upgrade is already shared by other guys in the thread from which I got very useful information. My sincere thanks to @cracing for his help.
Horn setup of City comes as dual horn i.e. Low and High tone which makes installation pretty straightforward. No extra wiring or relays are required for installation. Only problem is the horn connector, Its not standard one so wither you need to make connector on own or have to cut wires. Cutting stock wiring is not the way for me to install, so I searched online for connectors and got it on AliEpress. I got them around 2 years back and since then installation was pending with me.
You can see those connectors
here.
Got Bosch Horns for Amazon.in for Rs. 630/- Product Link
here.
Some Pics of the actual product,
Now Installation part began,
As its dual horn setup to install Horns Bumper needs to remove which is straight not that complicated IMO. High Tone Horn is located at the Passenger side and Low tone horn in the middle of car which can be seen easily.
Removal Of Bumper
Passenger Side Horn
My earlier plan was to install center horn at the driver side so that it will get protection from water and dust. Same was done by Cracing but couldn't mange to find holes and position for horn. Will figure out that sometime later, as of now I have installed both the horns on the original position of the car.
Cracing Setup L And R
To connect Bosch horns with the car wiring used connectors and for earthing made connectors which is pretty simple. As stock horns comes with single connector and other aftermarket ones with dual connector, you need to connect other connector with earthing which is done by homemade connectors.
Homemade Connector Used for Earthing
Connector for Stock Wiring
How to
Earth Horns
On the Car
I forgot to click passenger side horn image on installation, Sorry.
They are very loud, I used stock horns for almost 4+ years so for me these Bosch ones are more than enough. Somehow I used to like stock horn tone, it's very different and you can tell Its Honda. But sound was very low which is not practical at all for Indian driving scene.
Another Upgrade coming soon which is,
Will update on this soon, till then cheers drive Safe..
