Again, those are very good figures.![Smile [:)] [:)]](https://www.theautomotiveindia.com/forums/images/smilies/Smile.gif)
Can you please share your gear shifting speed / rpm.?
I am not sure whether the gear shift pattern that I follow is as per standard or not [thinking] but by adhering to the following gear shift pattern I manage to get above mentioned FE.
1st - 0 to 10
2nd - 10 to 15
3rd - 30
4th - 40 to 45
5th - 50 onwards
I never pull/revv the engine much with clutch pressed to get required momentum in upper gears, I prefer to shift downwards it its need be.
And I Always drive above 2K rpm up to 3rd or so then it must be above 3.5 k atleast.
Besides that I maintain average speed of 80-90 kmph on highways with some 100-110 kmph at times.![Drive [drive] [drive]](https://www.theautomotiveindia.com/forums/images/smilies/Drive.gif)
Could you please share your pattern ?
1st - 0 to 10
2nd - 10 to 15
3rd - 30
4th - 40 to 45
5th - 50 onwards
^^And the same answer this time as well.
