Yes the points the mentioned are always there to consider,but i am aware of the lower viscous being preferred for modern engines,but even basic 5W oils seem to hold that viscosity until 0 degrees.(any lower would prefer syn or blend for sure)
Yes i know many friction less designs have come to place with engines & gearboxs(some Dsg tech are crazy)
I remember reading somewhere about 0w-20 being used on some Honda's(i hope am not imagining this),but here in Indian conditions we have our engines facing 40 Degree heat waves & i feel we need to check the manual for the proper rating oil,cos if you see the car manuals,the oil grade changes depending on the temp(climate) your car lives in.(i dont think its strict for diesels but petrols they change).
- One thing i saw among synthetic oil manufacturer(with proper record) even in videos or anywhere where they praise their products is they never say their Syn oil last longer than the avg mineral oil.
I mean thats the most common high lighted part (for example your regular oil change at 10,000,syn oils in same can last you 15,000 km is what most say).
-The conclusion i have reached is the ageing of the syn oil is very slow in comparison to a mineral oil.Meaning Syn oil would most probably be fine even spending two years in the car as long as its driven under the stated change interval. Where as mineral oil is vulnerable to oxidization & needs to be changed at the one year mark despite kms driven.
Also i hear that Syn appears to look fine even though the condition of the oil is not great,leading many car owners to believe the oil can still continue for many more kms cos they look for signs of ageing similar to mineral oils.
-But many car companies are going the recommended Syn oil route for one reason & that is cos of increased blend of ethanol(alcohol) in our fuels.
OT - There is a bad side effect to this method of adding ethanol to fuel & that is deterioration of fuel over time. Fuel kept idle for 6 months i hear are good as water in some cases.National oil import mite go down but fuel ages very fast(am very sure many are not aware of this).
-Another thing i wanted was to go for Syn gearbox oil for my Swift which uses mineral,am sorry if this is a bit OT but still oils in some cases.
So when i look into it,it was recommended i do not, cos the gearbox would probably do well with the Syn oil but the seals & other material parts can degrade faster as a result,Since the gearbox was not designed to handle a Synthetic oil.
But one thing i have noticed is gearbox oil change between regular(guessing mineral) & Synthetic gearbox oil is huge.
Gearbox(regular) oil change of Swift is every 20,000 km
Gearbox(synthetic)oil change of "i20" is every 60,000 km
![Surprise [surprise] [surprise]](https://www.theautomotiveindia.com/forums/images/smilies/Surprise.gif)
(except automatic which uses mineral)
But yes the moral of the story in this case(gearbox) is it seems a bad idea to go synthetic where mineral was recommended.
