This definately makes sense.
In my personal opinion Not to hurt anyone:
Also, not sure why need to spend extra time, money and effort searching for engine oils and pouring them into the engines when the dealers themselves are well equipped for that of recommended by OEM. Not sure what we are trying to achieve here. Don't engine life prolongs or doesn't it be clean if we use OEM recommended oils? Do we have data to back that outside oils prolong engine life as compared to OEM recommended oils? Aren't OEM oils are branded?
Previously I had this experience and finally decided to stick to dealer as it is much safer also in many aspects especially if something goes wrong in the engine. It also removes my headache to waste my fuel going to shops that sells the oil, purchasing them with extra money, and asking the dealer to change which the dealers are relunctant about. What is the outside oils are spurious by chance?
Because of this it is actually quite logical to use an oil grade that is more suited to the life and usage of your vehicle, to allow you to get the maximum out of it!
If you select an oil carefully, it is highly unlikely that you will do any harm to the internals of the engine. I don't think it's a huge problem to go buy some oil every 10,000 km, especially if you love your car!
It's usually not too difficult to identify spurious oils...
But still you are not aware about 5W-40 thats what I said.
Viru, Instead of being confused why cant you make sure is it true or not.
IMO its better if you could find few more trusted mechs for the better updates
Viru, thats wrong man, no where I said 0W-20 is the best because I dont have experience with 0W-20. Please don't try to script. I'm only responsible for what I said. Things I said about 0W-20 is the details I got from different MASS and also from MARUTI SUZUKI via emails and calls. I have even provided the contact details of them. So I request you to blame me only after contacting them.
Thats a big lie.[ In my previous post what I have quoted is YOUR OWN WORDS blaming on 0W-40, then how can you say you did't say anything about 0W-40?I request you to click on to the quote to get into your post saying about 0W-40.
We human beings use to forget what we said. Seriously no offense bro.
Today Had a visit to POPULAR service center(MASS) to replace the door handle. When I asked about 0w-20 they said newer kseries wagonr are using 0w-20.
Anyways my doubts with you is not about 0W-20. Its about the way you talked about 0w,5w and 5w,10w.
You said 0w is bad for engine when I said I use Mobil1 0w-40 instead of 5w-30
But here you are saying "The difference between 5W and 10W is quite minor"
So What I'm saying is
Viru, can't you agree with this???
First of all, thats a very good car.
I think what you have used is not the brand CALLED MOBIL1. Most probably it is MOBIL or MOBIL SUPER. I dont know whats the difference between them, but what I could know from Mobil1 staffs is they are different and Mobil1 is far far superior to them.
The reason for saying is I dont think Mobil1 had 10W-40 FULLY SYNTHETIC engine oil in India in those times.
I request you to collect the reviews about the the new Mobil1 5w-30 esp from the people who are using it and if you are ready to spend few more bucks on your engine oil, then have a try with it.
So let's just ignore the 3 days you firmly defended 0W20 as being the best, and call it 'scripting'. Yes, very constructive attitude Kichu.
Initially you also claimed that 0W20 made your engine run smoother, now you're admitting you haven't actually tried it?
Anyways, if you want to use 0W20 use it, I have one car with the same engine on 5W30, we'll see whose lasts longer.
0W is harmful, that fact stands. Let me put it this way: We know protein is healthy, but that doesn't mean you should only eat lentils and nothing else. Basically, Yes the difference is minor, but there is also an extent past which you are going too low and will cause some damage.
I can't agree with an incorrect statement.
It is an amazing car, and mine had a Nismo remap (which was quite hard to get).
That's called marketing, but those oils were also synthetics, neither was this in India.
I'm going to stick to 5W30 Magnatec because of it's additives. I may also take my M800 to 10W40 Magnatec. It's not any cheaper than Mobil oils, but it's more VFM.
Am a bit late here guys,but i just need a quick answer,
I have misplaced the manual & bills for my Swift Petrol 1.3(G13BB) but am sure it uses 15w -40 & i feel at last service 05w-30 was added instead & that made me run low on engine oil at 8000km after service(had to top up).
Planning to send car to an authorized garage so i can overlook everything.
Planning to get Shell HX 7 (semi syn) & see the results as car has done last 74000 on only mineral oil from company.
Just to clear things if recommend is 15w40 & i use a 10w40,the 10w should give better cold start protection while providing same viscosity or protection at higher temp as the other ?
As far i understand the new k series petrol use 05w30 which mean less thick but older engines like the esteem & my Swift petrol 1.3 need w40 atleast for protection.
Waiting for advice to clear the confusion.
The 10W has a lower cold viscosity than the 15W. This will make cold starts easier, but not necessarily always provide better protection when cold. In Indian conditions, however, it will be a good choice.
Once warm, both the oils will have the same viscosity (40 grade) which means the level of protection will depend on the Friction rating of the oils.
