Maruti Swift Dzire ZXi 2015 Sangria Red Ownership Review
Thread Starter #106
Mr. Suryaputhra
What's the best clutch setting, having moderate play distance or little play,i have heard that more play is better than little play ,is it true?
Yes, more play is better, it saves clutch plate, when there is more play there will be good enough distance between flywheel and clutch plate so no chances of plate rubbing to flywheel when clutch plate engages and disengages. Releaser bearing will travel short distance to engage or disengage clutch plate so it rotates less and this promotes its life.
-suryaputhra
chennai
-suryaputhra
Bro wont more play give a hard time in b2b traffic ? [confused]
Thread Starter #111
@akmalazim more play will not give a hard time in b2b traffic , more play will give you easy shifting, clutch will start engage or disengage from a low distance from the floor. But too much more play gives you clutch shudder.
In case of less play you need more clutch pedal travel to engage or disengage. But if very less ply clutch plate will stick to flywheel when you engage or disengage and leads to premature failure.
It was the reason manufacturers specify free pedal travel range to adjust and suit to ones own preference.
-suryaputhra
Trivandrum , Sydney
Mr.Suryaputhra
I have setted the clutch play set that it has 1-2 settings left,isn't that right.
I felt gears are slotting perfectly, i have 3 bite positions-
1.Full deppressed
2.Half clutch + Slight movement
3.Released fully
Is this right?
chennai
-suryaputhra
more play means that the clutch has to travel a long way or not ?[confused] if yes then obviously your legs have to be worked alot . correct ? pls correct me if im wrong [:)]
Trivandrum , Sydney
Actually i have felt vice versa
Case- Clutch in less play
In B2B traffic, vehicle control difficult,clutch will be in constant work(Load from foot),press ,depress.
Case- More play
Less load on clutch ,as clutch engage and disengage in medium way.
New cars (I drive Verna occasionally),it has hydraulic ,play is variable according to drive.
The play sets in as per driver's driving style.
Disadvantages- In high traffic conditions ,over heating can cause burnt clutch and clutch can be jammed.
Thread Starter #116
Mr.Suryaputhra
1.Full deppressed
3.Released fully
Is this right?
Your clutch setting is ok, in my car I have the same setting, its my preference
I did not understand below points if you explain me I can suggest you.
1.Full depressed
3.Released fully
you mean method of clutch release?
-suryaputhra
Case- More play
Pls check the below link
Adjusting the clutch | How a Car Works
-suryaputhra
Case- More play
More play means less travel legs will work less.
Less play means more travel legs have to work lot.
Pls read I have told the same thing.
-suryaputhra
Hii
Am looking to do some decent stickering work on my car. Areas am planning to do is on bonnet over the headlight on one side.
I saw few "Suzuki sports" stickers online. Shall I go for it.please share some ideas
Thread Starter #118
Suryaputhra sir could you please let me know the part number for Dzire Dashboard Glove compartment or the Glove compartment lock. Mine got locked up and damaged when the workshop guys forced opened it. [cry] Thanks in advance!
