Maruti Swift Dzire ZXi 2015 Sangria Red Ownership Review
No suresh it won't.. It is well above hand brake..
And we can fold it up if required
Hi Suresh while browsing for kissankraft i got to know their factory is in Bangalore itself.They gave me a local shop address to buy the sprayer.. But i ended up booking electric pressure washer.I got good deal .
Thread Starter #77
Which brand and at what price, in earlier post I have asked part no of the fuel filter, that you can check in your service bill.
-suryaputhra
Thread Starter #78
It is not fuel filter its oil filter part no required because dealers using different oil filter, I want to cross check that .you can check in your service bill for part no.
-suryaputhra
Hii suresh
Do I need to change oil filter? I haven't given car for service yet. I will be giving it on Thursday. Will let you know about filter.
Pressure washer is kissan kraft.. 5800rs.. 1600watt. 300l/hr. 101bar pressure
Thread Starter #80
Go for kacher or Bosch washers kissankraft is newbie in electric pressure washers any link to item.
-suryaputhra
Thread Starter #83
Hi Doc, check your car oil filter part no, just check at under the car near oil sump area there you can see oil filter, note down the part no if it is 16510M68K00 then you stick to same part no, Dealers are using oil filter part no with 16510M68K10, when I asked for the maruti circular regarding the same there is no circular from maruti stating that use 16510M68K10 instead of 16510M68K00.
Oil change interval is 10000, but you insist them first service 1000km oil change. There after you can change engine oil as per your wish.
-Suryaputhra
Arm rest pictures in different positions
Armrest for new dzire installed at mga
Thread Starter #87
Excellent Doc, good to know they have used correct oil filter. In the morning you check oil level in the dipstick on perfectly levelled floor, oil level should not cross MAX mark can be little low. 0W20 oil, resin coated pistons and low tension piston rings have tendency of excessive blow by. Added to this type 3 K12MN engine oil sump do not have baffles so blow by increases.
To reduce this blow by Type 3 engine oil capacity is 3.1 ltr instead of 3.4 ltr in type 2 engine.
I have ordered DRLs on eBay
-suryaputhra
Thread Starter #90
Philips Extreme Vision Plus H4 Head Lamps
Recently changed my OEM head lamps to Philips Extreme Vision Plus H4 Head Lamps, no extra wiring harness required, no relay required, regular wattage 60w/55W bulbs only but using new tech gives extra 130% more light, its successor to previous model Philips Extreme Vision. No warranty problems and no RTO issues. Just plug and play. They are excellent. Rs.1300 bucks.
I brought from Philips Distributor at below address
AK Traders(Rajender)
22/23 1st floor
3rd cross
JC road
Ph: 9844166794
41143199, 41143958, 26707295
-suryapythra
