Hello people,
It's been 6 months since we purchased our new Maruti Suzuki Swift Zxi. I have been wanting to write an ownership review but couldn't find time.Shall definitely write it very shortly!. I shall be giving my car to the 2nd service this week, had some issues and niggles as usual.It would be great if you guys could help me out.
Issues:
1.Co-passenger's window pane makes loose sounds when slightly open on the move and also when the door is closed.How common is this?
2.I feel the idle RPM is a bit on the lower side.There's a slight vibration when the car is moved from standstill.Can the idle RPM be increased?
3.I can feel the clutch vibrations when i keep my leg on it.I can also feel the vibrations when my leg is kept on the brake pedal.
4.The engine doesn't rev past 4000 RPM in 5th gear even when the accelerator pedal is floored.And even the car struggles to move past 140km/h. Is it common or is it because the Maruti guys would have deliberately limit the revs until 2nd/3rd service?
5.The steering doesn't roll back to the dead center position at certain low speeds(say 20-30km/h) until i manually turn.
6.The hatch door needs to be closed with quite a lot of force.The service guy said this is common for the Zxi models as it's operated electronically!
Hi. My friend also has a Zxi and I get to drive it quite often.
1. Yes. It is common in both the front windows. If you leave then halfway open, then they do vibrate and make some noise on bad (not that bad) roads.
2. What is the idle RPM? Try leaving your foot off the clutch a bit more easily (slowly) and see if it still vibrates. The car should not judder when accelerator input is given when moving from standstill. If you are a new driver, the problem will disappear as you clock more distance and gain experience. Idle RPM can be increased at the ASS.
3. No. I didn't feel anything on the pedals. How are the overall vibrations at idle in the car? It might vibrate a bit more if the idle RPM is too low.
4. I haven't tried such speed and neither is it advisable. There is no RPM limited till 7k (or 6800) and the speed lock, if there, can be removed by fiddling with the ECU. It is not a good idea anyway, as you won't touch those speeds very often.
5. No it doesn't. It will roll back but not exactly at the center position.
6. Yes boot door requires some effort. It is an electromagnetic lock (button) and not electric release (
). Putting too much effort can damage the lock, and also pressing the button many times at short intervals or trying to close the boot (in a second attempt) within 10 seconds can do damage. So be careful and easy on the boot door.
