Maruti 800 AC Carburetor Version four gears Feb 2004 has following issue. Any suggestions to troubleshoot would be deeply appreciated.
Once the car starts, as soon as the accelerator pedal is pressed to raise speed or move, the engine stops.
Any idea what could be wrong with the system please.
Rahul
Hello Rahul,
There could be 2 -3 issues and you have to check up one by one.
Alternator ( Dynamo) issue- check the Voltage at idle, must be at least 13.5, if not so, get the Alternator checked, may be Regulator is gone> if so, while replacing the regulator, get the Dynamo serviced, and get the bearing greased. TVS Regulator costs you Rs 650 and the service charges may be around Rs 300- 350.
If Alternator is fine, then it could be Drive shaft problem. If Drive shaft has gone, then go for only MGP and may cost you around Rs 3500 for one drive shaft.
If above 2 are fine, possibility that your Carburetor is jammed and not firing the petrol and air mixture. Need a expert mechanic who knows how to overhaul the carburetor. You can read my post in this thread about the Carburetor o/h.
One more point that comes to my mind is - check the spark plugs and also point condenser.
Share your experience once you solve your problem.
Good luck
