Hello Shashi,
Received the gaskets today at 4 pm.
It was nicely packed, though it is thin gasket, not of rubber but looks like black foamy thing properly cut on machine with notches and holes for the screws to insert. I know it is to be fixed to the metal and not to the TL because TL is to be removed in case of replacing the bulbs and bulb holder if any.
What kind of glue did you you use? Quick fix or any other glue, pls do let me know.
The gasket has to be applied to your TL, and if you notice, it has grooves made which sits with the grooves of your TL(if there is a groove in TL but not in gasket, make a small hole there). Then simply tighten the TL as you normally would. SInce its a foamy gasket, it compresses and seals eventually.
I read on some facebook page most likely, some idiots had pasted the gasket using anabond and what not. No need to do such stunts. :)
Open your TL, remove the bulbs, place the gasket properly on the TL, put back the bulbs and install. Simply said, you have to put the gasket in between body and the TL.
Shashi
