Use a good coolant and change it after every 20k or 2 years. And before draining flush it with a good radiator flush. For flushing you can use Wurth Radiator cleaner 250ml.
and for Antifreez you can use Wurth new age coolant which is used in 1:4 ratio as compared to conventional 1:2 coolant that means you can fill up the coolant sump of 4 litrers with just 1 liter coolant, more over it is hard water compatible and 100% Biodegradable.
Prior to wurth i was using Elf glacelf supra the best ever coolant to enter the indian market it was so good and so expensive that due to its skyrocket pricing this product got flop and was discontinued . A 500ml bottle used to cost 125rs in 2008 where as u could have bought 2 liter of Puroguard or delphi or 1 liter of golden cruise at the same price in 2011.
Use only distilled water to mix with coolant.
