@BHVM:
Sir your case is not exactly the same. Let me quote your case as well as of Mr. Sagar and Mr. Parate. As much I know, your father parked the car instantly after he observed the clutch pedal not returning back and called the MASS. Right?
In other two cases, the owners have actually driven the faulty vehicle. I hope you understand my point here.
My purpose is not to demoralize anyone, I am just comparing two situations which have had different outcomes.
BHVM's case:
Car was parked at the instant of clutch failure and hence only slave cylinder issue occurred. Replacement done under warranty. Why? Because customer has followed what is written in the manual; "park the vehicle at the place and call WYH helpline".
Cparate's case:
2500 kms old car gets the clutch pedal fail to return while he was in some jungle area. No mobile network, no facilities and hence he drove the car to the point where all the facilities were available.
Outcome: Entire clutch assembly replaced and customer charged 45k. No warranty, no free replacements and the blame is passed on to customer for not driving properly. He was even offered a tutorial class
What went wrong IMO: He drove the car despite of having the issue instead of following the instruction written in the manual.
Sagar's case:
56000 kilometers old vehicle faces the clutch issue. The customer calls the WYH helpline and then drives the vehicle to his home and that also 450 kilometers away. This is a direct denial of the instructions given in the manual as well as by the WYH exec (they gave the details of RSA).
Outcome: Maybe the A.S.S. will provide him free repair under warranty based on the goodwill or because they provide it to everyone. But A.S.S. can easily deny a warranty repair here because warranty remains intact only under 'standard/normal vehicle usage and not in case of driving a defective vehicle'.
What can go wrong: Not following the instruction.
BHVM sir, I hope now you understand what makes your case different from that of Mr. Parate's and MR. Sagar's. THere is a minute detail which has made a major difference.
@Sagar:
Leave the vehicle in A.S.S. and follow up with them to find out if they are giving an under warranty free replacement or they are going to charge you for this one after analyzing the clutch of your vehicle. This seems to be a case where the clutch doesn't get completely disengaged and hence one can expect some major damage to clutch assembly too. Although ethically M&M should give you a free replacement but in case they refuse to give you a free replacement then tweet this issue to Mr. Mahindra and try your luck. Still if it fails then post here and maybe we can help. BTW your vehicle is under yours or company ownership?
Here IMO, Mr. Parate still has a stronger case as he can site the reason being stranded in the middle of nowhere but Mr. Sagar has to completely rely on his luck that dealer simply agrees to replace the clutch under warranty or they charges him for the same.
Sigh of relief/piece of luck: Sagar buddy, just pray that your XUV comes out to have only slave cylinder issue but not the entire clutch assembly one. IF that happens then you have a warranty replacement confirmed as there have been numerous cases of under warranty replacement of many parts including this one too.
BHVM's case:
Cparate's case:
Sagar's case:
@Sagar:
