Mukesh,
Brake fluid reservoir was full.
ABS has been working fine, no error or a warning light has ever occured.
I didn't inspect the brake pads, but the SA told me they are fine and should be good till the next service.
What other parameters you want me to share? Let me know.
Past few days I didn't out my scorpio and was instead using my other cars. I had to take it out today for cargo hauling and that poor brake phenomena is very much existent. I'm left wondering as to what should I do, the guys at Koncept Mahindra don't seem much competent to me. Will be registering a complaint with Mahindra corp. today. So any inputs as of now?
Attached is pic of the invoice generated, have a look.
Going by the bill, every thing should have been fine.
Well with the brakes i have never faced issue on brake bite.
However after service the brakes tend to be smooth as they would have cleaned the brake disc.
So to make the bite better, one has to brake and leave, brake-leave(Keeping in mind no vehicles at the rear.) By doing this the bite just improves.
Can you post the pics of tyres, and what make is the tyre.
Brake pad on my car was changed at 41,000 kms (The 1st OEM one).
In the bill i could not see OCA brake adjust, where they clean the discs, rear drum for any asbestos collected in the drum.
The labour of paid service seems to be less in Delhi.
Here it has now been raised to 3100/- which was 2600/- earlier.
Hope you are not over inflating the tyres as well.
As this leads to less efficiency in braking.
I usually fill 33 psi at rear and 31 psi in the front.
Check the tyre pressure, do follow that braking-leave, braking-leave when you attain 50-60 kmph.(Make sure no vehicle is behind you).
If nothing works drop a mail to CC of M&M, raising the concerns.
So that they again can do a OCA brake adjust.
If possible check the brake fluid reservoir, red fluid in color(TVS Girling) Yellow Cap.
Don't get confused with clutch fluid reservoir.
A quick question guys. What is the optimum Tyre pressure to be set in MRF wanderer AT. Recommendation from m&m says 32 but steering feels very hard at this level. I usually set it to 35 to 36.
Found from web which says 35 to 38 is the best for this..
Is this OK? help Plz!!
Hi Krish i had already answered this in my current post.
31 Psi Front, 33 psi Rear. (Make sure you fill it early morning).
By moving slowly on any potholes or humps till you reach the fuel bunk.
