Hyundai Verna CRDI - My Ownership Experience!
The horns must be fitted in such a way that water doesnt collect at the funnel type.
That is the funnel part must be ground faced.
Roots is one of the best brand. Roots relay cost 200/-
Dubai / Mumbai
no, i have fitted these in place of the original ones, that is, the original horns are replaced.
regarding water entering them, yes thats a huge issue. as ilango said, i have angled the cone downwards so that water does not enter them.
Thread Starter #108
@ Raj Yes even if i was to replace the original horns then it would have costed me only Rs.650!! But i din want to throw away that horn which is still working fine , so used the relay to have both the horns hence the higher cost!! Yes the shopkeeper told me that Roots brand horn is available for Rs.500 but without warranty , so i felt i din want to take a risk as the cost difference is only a little!!
But guys if the horn funnel is facing downwards then water will enter inside when water servicing is done on the underbody after lifting the car in the hydraulic lift right??
Thread Starter #110
I got my wheel rotation done for my car as it is nearing 10k kms now! I got it done from a local CEAT tyre dealer who is my dad's close friend!!
These are the things i have learnt coming here to TAI!![cheers]
Thread Starter #112
Alignment costs does not vary with cars i guess! Computerized alignment centers charge here Rs.250 for alignment and rotation was done free for me! Maybe they will charge Rs.50 for rotation thats all! We can do the rotation ourselves but we will take more than an hour to do it but the guy working there did that in 10 minutes!
Here in south through out
for small car some cost 150 , rest charge 200/-
For sedan , from indigo to laura/jetta etc its 250/-
and for bigger one its 350/-
ANd balancing cost 50 for a steel rim
and for alloy its 100(crap they use the same weights! we must insist on alloy wheel weights-i do)
tyre rotation is alwas free , some times they do edge rotation , that is 25 per tyre
Thread Starter #114
Hey guys i got a call from KUN Hyundai now saying the one year Warranty for my car expires tomorrow! They said i can extend it for one more year paying another 10k! Is it wise going in for extended warranty?? And what all the things will be covered in extended warranty??
My running is generally high , i have now covered almost 10k kms now in approx 6 months! help me out guys asap because i have to taken a decision tonight!
Personally, I’d recommend you to go for the extended warranty if your use-age is really high and you plan to keep the car for more than a couple of years. There are quite a few things which you’ll need to look at before opting for one and ask as well as re-confirm the question whatever you have about extended warranty with the dealer, such as for how long it'll be valid? What all is covered? What is not covered? Is it given by Hyundai itself or your by the dealer? etc. Also make sure to read the T&Cs carefully.
Thread Starter #116
Yeah i plan to keep the car for atleast 3 years from now!! ( dad keen on selling it after 3 years but i want to have it for long)
What are things to be looked at 350Z??
Thread Starter #118
Well okay thanks 350Z , looking for suggestions from others also!
Am not yet able to make my mind , don know whether dad will accept for it also!!
Bokaro/Bangalore
Just read the extended warranty document properly. If you are satisfied, take it. Though the charges is on higher side - 10K for 1 year.
For my Punto, extended warranty is is 5K for 2 years.
Its always recommended to go for extended warranty.
